Gas moving around in tank - feel thumps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ReconRider46, Dec 19, 2016.
  1. Dec 19, 2016 at 11:53 AM
    ReconRider46
    ReconRider46 [OP] Well-Known Member
    Joe
    Landenberg, PA
    '16 MGM Sport DbCb
    Has anyone else noticed when they're close to a full tank they feel the gas moving forward and backwards causing thumping sounds coming from the back? I've owned many cars and never experienced this before.
    BOZOJUICE, SK bassin and ChadsPride like this.
  2. Dec 19, 2016 at 11:58 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    dont think its the gas you are feeling. probably driveline "lash". have you greased your u joints? they come dry from the factory and i noticed a big difference in the thunk immediately after letting off accelerator after i greased mine
    ChadsPride likes this.
  3. Dec 19, 2016 at 11:59 AM
    breader3
    breader3 2016 TRD Off-Road 4x4
    Brad
    Las Vegas
    Could be the fuel inside moving? Especially when it's full
    Mush Mouse likes this.
  4. Dec 19, 2016 at 12:02 PM
    safaristeve
    safaristeve Member
    2016 Access Cab TRD Sport
    Mine did the same thing with a thump a second or two after coming to a complete stop. It was at the dealer for a week and they spent about 20 hours trying to diagnose it before telling me it was fuel sloshing and giving it back to me. It seems like a (somewhat) logical explanation because it only did it around 3/4 tank and I also noticed my loaner Tacoma starting to do it as I was driving to return it, but it's a poor tank design if that's the case.
    BOZOJUICE and breader3 like this.
  5. Dec 19, 2016 at 12:03 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Nope. Sounds like something could be loose.
    Edit: Sloshing or thumping? Thumping... no. I haven't really heard sloshing either.
  6. Dec 19, 2016 at 12:15 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My driveline clunks when rolling to a stop at times. Reminds me of a 1989 Ford Aerostar van my trailer park uncle owned.
  7. Dec 19, 2016 at 12:22 PM
    ReconRider46
    Joe
    Landenberg, PA
    '16 MGM Sport DbCb
    I agree if it is the gas tank it's a very poor design! I haven't greased my u joint, is there a grease fitting for that? I don't notice it nearly as much when my tank is low on gas. More noticable when it's full.
    Fwiw, only have 6,000 miles.
  8. Dec 19, 2016 at 12:25 PM
    brich999
    Bryan
    all tore up already
    if its a 4x4 there are 5 in the 2 driveshafts. i thought my truck was broken because it always had a clunk the moment i stopped accelerating. like a constant love tap but there was nobody behind me. found dry u joints were the main culprit. they caused fair amount of drag on the drive line and it caused a lash effect. even if it isnt your main issue, it cant hurt to hit em with grease to rule em out
  9. Dec 19, 2016 at 12:33 PM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Just an FYI, they changed the joints in the rear shaft to not be greasable sometime in June 2016. Based on OP's build date, he may or may not have the ability.
    OA
  10. Dec 19, 2016 at 12:35 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Sometimes they don't get the spare seated right and that will cause some 'noise'.
    CusterFan likes this.
  11. Dec 19, 2016 at 12:43 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    This was the case on the '15 Colorado I traded off.
    OP just reach in the fender well and push on your spare. Maybe all you need is to raise or tighten the what-cha-ma-call-it. :thumbsup:
    Spare Parts and ChadsPride like this.
  12. Dec 19, 2016 at 3:40 PM
    ReconRider46
    Joe
    Landenberg, PA
    '16 MGM Sport DbCb
    Great suggestions, thanks guys! I'll check and see if I have fittings and my spare. Now that you mention it, I recall my wife's Rav4 had a similar problem caused by a loose spare.
  13. Dec 19, 2016 at 6:08 PM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    If it doesn't do it with half a tank of gas then it's the gas in the tank. Mine does it too.
  14. Dec 19, 2016 at 7:01 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Mine does this too, stop, pause, thunk.
  15. Dec 20, 2016 at 6:22 AM
    ReconRider46
    Joe
    Landenberg, PA
    '16 MGM Sport DbCb
    This is exactly how it goes, stop , pause...thunk! What have you chalked it up to, gas?
  16. Dec 20, 2016 at 7:02 AM
    aero90
    I highly doubt it is gas. I'm not sure what it is at the moment. I'm due to regrease my u joints, so I'll see if that has any effect on it. I've been noticing the thunking a lot more lately than before.
    I've also had my rear differential replaced by Toyota a few thousand miles ago so that could be a contributor. Im also pretty sure the driveline angles have always been slightly out of spec due to the slight rumbling that happens when I am coming to a stop (maybe there is some sort of binding and release?).
    Also a possibility none of it is related and it's just inherent to the design.
  17. Dec 20, 2016 at 7:14 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    ReconRider46[OP] likes this.
  18. Dec 20, 2016 at 6:17 PM
    sja
    sja Well-Known Member
    2018 TRD Sport, 2WD
    Hey Joe(ReconRider46), I have a 17' TRD Offroad. After listening to your description, I'm convinced it is your fuel sloshing around. I have also noticed this on my truck when my tank is 3/4 of a tank full to completely full. I know because when I stop, especially when pulling into my garage, I feel and hear the thump you're talking about followed by the faint sound of gas sloshing around. If you have your AC and radio off you'll be able to hear the sloshing after the thump if everything is quiet. If it was something else, it would do it all the time, not just when your tank is full. No worries buddy. I noticed this on my 2013 Tacoma as well.
  19. Dec 20, 2016 at 6:22 PM
    sja
    2018 TRD Sport, 2WD
    Initial thud is from the momentum of all the fuel hitting the front of the tank before it settles down when you stop. Not as noticeable as your fuel level drops.
  20. Dec 21, 2016 at 11:30 AM
    ReloadX
    ReloadX Well-Known Member
    I get the same thump noise too and its from the gas in the tank. Usually happen when to tank is close to full.
    I know it's the gas because when I pull into the garage late at night (and it super quite), I can hear the gas moving in the tank coincide with the thump.
