Gas needle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by russellgraham1988, May 30, 2022.
  1. May 30, 2022 at 11:07 AM
    russellgraham1988
    russellgraham1988 [OP] Member
    Russell
    2009 Toyota Tacoma double cab
    After market radio, lift, running boards
    Does anyone else notice with their gas guge. He will stay on the full mark for a longer bit of time. Then it almost seems like you can watch a fall from there?
  2. May 30, 2022 at 11:11 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yea pretty normal, many vehicles do that it's just how the gauge is calibrated.
    Mine stays pretty much on full till I use about 3-5 gallons then it starts dropping.
  3. May 30, 2022 at 11:19 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Same, it's normal
  4. May 30, 2022 at 11:24 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yeah. Mine stays there for a long time. Then drops fast to 3/4.
    Best I remember. The last 1/4 drops fairly quick too. But I try not to get much below 1/4 tank.
  5. May 30, 2022 at 11:26 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Mostly due to the shape / contours of the gas tank.
    The variable resistor for the gauge is pretty linear.
    TnShooter likes this.
  6. May 30, 2022 at 11:38 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Mine does the same, also. Once I go 20-30 miles, it starts dropping.
  7. May 30, 2022 at 11:42 AM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    Mine will go 40-50 before it moves below the full line. It seems to catch up somewhere around the half way mark to be accurate.
    TexasWhiteIce likes this.
  8. May 30, 2022 at 12:12 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    My Taco's gas gauge hasn't moved much at all in about a month.
    :anonymous:
