Gas Octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, May 9, 2009.
Which fuel octane do you use?
  1. 87
    2,159 vote(s)
    64.4%
  2. 89
    454 vote(s)
    13.5%
  3. 91
    773 vote(s)
    23.1%
  4. Other fuel additives
    57 vote(s)
    1.7%
  1. Mar 25, 2010 at 10:18 AM
    #261
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
  2. Mar 25, 2010 at 11:05 AM
    #262
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Wow guys...just read your owner's manual.
    My manual RECOMMENDS 91+...so I use 91+.
    My dad's Suburban RECOMMENDS 87...so I use 87 when I drive the Suburban.
    Not that hard, fellas.
  3. Mar 26, 2010 at 7:34 AM
    #263
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    I'm running 85 and the Taco doesn't mind it at all.
  4. Mar 26, 2010 at 7:41 AM
    #264
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    Unless your truck is supercharged or turbocharged there is no reason to buy premium gas. Our truck engines are not high compression ratio engines, therefore do not need premium gas. Go ahead and buy the more expensive stuff If you have alot of expendable cash.
  5. Mar 26, 2010 at 2:49 PM
    #265
    dog tired
    dog tired Well-Known Member
    NE Ohio
    GTFO
    Link
  6. Mar 26, 2010 at 4:01 PM
    #266
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    MM oil in the fuel does lubricate the fuel system and the upper cylinder area so I use it in my off-road motorcycle fuel, 2oz per 5 gal premium. I really work that moto engine hard so it will benefit from the added lubrication. Have not used MM in any of my cars or trucks because I don't work those engines nearly as hard. Plus I'm afraid it would gunk up the cat with long-tem use (off-road bikes don't have cats... yet). You could put a few ounces MM oil in the engine. I have done that for years with good results (the cyl hones on my 65 mustang were mirror perfect and you could still see some cross-hatches after 120k miles, great compression, I just had to take the head off for valve guide replacement.)
    I have seen an increase in fuel economy about 2mpg using Lucas Fuel Treatment. No I don't work for Lucas.
  7. Mar 29, 2010 at 6:26 AM
    #267
    punkassprettyboy
    punkassprettyboy President
    Tommy
    North Jersey
    2010 sr5 v6 4.0 trd SPORT
    tints, led interior lights, debadged, security system w/ auto start, 2 800w 10" woofers, rain guards and tow package so far.....
    HOLY MOTHER OF GOD..i should use 91/93..JERSEY GASOLINES THE CHEAPEST!! =)
  8. Apr 6, 2010 at 6:24 PM
    #268
    detnight
    detnight Well-Known Member
    David
    Texas City ,Texas
    Texas Edtion Sport Super White
    Bed cover, Borla exhaust,20in wheels The TEXAS edition
    My 89 3.0 v-6 would ping on anything less than 91,but I also got 26 mpg. My 09 Quad Cad gets 87 unless i am pulling my motorcycle trailer then it gets 91. There is a difference in the gas mileage between 87 and 91. With 91 I get 17mpg with the trailer and 15 mpg on 87, plus I can't use the overdrive on 87....over all under normal driving i get 15-17 in town and 20-22 on the highway. And yes I drive like an old man. But My Harley gets 43mpg.................
  9. Apr 10, 2010 at 12:26 PM
    #269
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    89 unless I go for a very long drive I'll use 91. Want power, performance, etc. Go for the racing fuel.
  10. Apr 15, 2010 at 10:34 PM
    #270
    dbiland
    dbiland Member
    Northern Cal
    07 TRD Off Road
    TRD: CAI, CAT Back, Doug Thorley Longtubes, URD: Y-Pipe, MAF CAL, SS. APR T-Stat(uninstalled) Bilstein 5100(4) eibach toytec coilover. Rear suspension TSB.
    I ran 10 gallons of 100 octane "Velocity" when I was in Pasadena, CA last week. There was under 5 gallons of 91 oct in the tank when I filled it. I paid 8 dollars at the pump. It was 5 dollars a gallon when I was in high school, that was fifteen years ago.
    Acceleration was marginally better... that's about it.
  11. Apr 15, 2010 at 10:48 PM
    #271
    DheadTaco
    DheadTaco Pill it till you kill it!
    Gulf Coast, Mississippi
    07 Tacoma PreRunner SR5 Impulse Red Pearl
    -Color Matched Grill & Toyota emblem -Headlights from WOTM -Tinted Fogs with Lamin-x (Tint) -Tinted taillights with Lamin-x (Tint) -6K HIDs in headlights and fogs -20% tint all around -Plasti-dipped badges -Plasti-dipped back bumper -Mud flap mod -'10 running-boards -LEDs all around -AFE drop-in
    All I use is 93 and it runs like a champ!!!
    -Last tank of gas i got 401 miles/17.1 gallon=23MPG
  12. Apr 16, 2010 at 2:02 AM
    #272
    JKD
    JKD Well-Known Member
    Many modern vehicles (since the early 1990s at least) adjust ignition timing to compensate for lower-than-optimal octane. If the vehicle is designed to tolerate 87, but to take advantage of 89 or 91, then you will get better performance on 89 or 91 even though you don't get pinging on 87.
  13. Apr 16, 2010 at 6:12 AM
    #273
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    used 91 for the last 2 tanks, not a bit of difference, execpt the price about $6 - $8 more per fill up, needless to say I will be going back to 87 next fill
  14. Apr 16, 2010 at 9:50 AM
    #274
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    87 for my 4 bangah.
    every time i put 92 its slower, gets worse mileage and runs a bit rougher lol
  15. Apr 16, 2010 at 9:57 AM
    #275
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I still get 15-16mpg with 93, same as the 87. I don't get as much pinging. I think I'll drop down to the 89 and see what that does for me. I'm on my 5th tank of 93 with no noticeable difference. My phone has a neat app to track my mileage history.
  16. Apr 18, 2010 at 2:25 PM
    #276
    ASE_MasterTech
    ASE_MasterTech Well-Known Member
    Monmouth County, NJ
    2010 TRD Sport DBL\Cab
    Wet Okole seat covers, Westin Platinum Oval tube steps, Rear spring TSB plus Super Springs, D-Rings in all bed bolts, Tailgate reinforcement mod (for loading Harley)
    Fuel 'octane ratings' have very little to do with engine performance in modern vehicles which have not been considerably modified (ie-modified cylinder compression ratios). Modern engine controls, such as variable valve timing, computer controlled ignition & fuel delivery events, & most other emission/performance control components, have rendered the 'higher octane' argument obsolete.
    Octane ratings were used in a time when cylinder compression ratios were the main 'tool' for performance gains, today however, they seemed to be used as a marketing tool to increase oil company profits from the uninformed..
    Here are a few links to learn what 'octane' really means;
    http://www.green-planet-solar-energy.com/what-is-octane.html
    http://science.howstuffworks.com/gasoline3.htm
    http://auto.howstuffworks.com/fuel-efficiency/fuel-consumption/question90.htm
  17. Apr 18, 2010 at 9:04 PM
    #277
    Bull Winkus
    Bull Winkus Well-Known Member
    Herb
    N. Arkansas
    Jeep Wrangler
    Agree 100%! (EDIT: And that makes us both wrong. :eek: Sort of.)
    High compression engines cause preignition, heard as pinging. It is the gasoline self igniting under pressure during the compression stroke before the spark. (like a diesel) To make it practical to design higher compressions into an engine, a way was found to increase the self ignition pressure of gasoline, and that was by using additives to increase octane which makes the gas less explosive. That's all you're getting for your extra dough.
    If Toyota's engine was a high enough compression to need higher octane fuel, it would be in the owner's manual that 91 or higher octane fuel is recommended.
    I don't have a Taco manual yet. Does it say that?
    When I had a 2004 4Runner with a V8, it did say that in the manual. As a result, I used 93 octane all the time. Truck ran like a scalded rabbit as soon as you put your foot into it. But, ... it was the higher compression that gave the performance; not the higher octane.
  18. Apr 18, 2010 at 10:14 PM
    #278
    Bull Winkus
    Herb
    N. Arkansas
    Jeep Wrangler
    This article from Wikipedia sums up any question about possible advantages of using higher octane fuel than an engine is designed for.
  19. Apr 18, 2010 at 11:34 PM
    #279
    Bull Winkus
    Herb
    N. Arkansas
    Jeep Wrangler
    Well, I just looked up the 1GR-FE on Wikipedia.
    87 OCTANE
    Output is 236 hp at 5200 rpm with 266 lb·ft of torque at 4000 rpm
    91 OCTANE
    Output is 239 hp at 5200 rpm with 278 lb·ft of torque at 3700 rpm
    There you have it. This engine is designed to use higher octane. However, it should adjust and run smoothly on 87 octane.
    Check out the Wiki page. It is very interesting.
  20. Apr 19, 2010 at 4:29 AM
    #280
    jandrews
    '09 FourDubDee TRD OR
    Yeah, this is what many of us have been saying since day 1...higher octane is not required, but there is a real advantage. The 1GR ECU is apparently able to open up some extra timing with higher octane and thus produce more power. People can pick their poison...economy or engine output.
