Gas Octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, May 9, 2009.
Which fuel octane do you use?
  1. 87
    2,159 vote(s)
    64.4%
  2. 89
    454 vote(s)
    13.5%
  3. 91
    773 vote(s)
    23.1%
  4. Other fuel additives
    57 vote(s)
    1.7%
  1. Jun 27, 2010 at 10:45 AM
    #341
    polansky568
    polansky568 Member
    87 - runs fine and im getting about 450 per fill up.
  2. Jul 31, 2010 at 1:04 AM
    #342
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    so if it burns slower does that mean better gas mileage?
  3. Jul 31, 2010 at 1:06 AM
    #343
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    I use 91 in the Taco and 4Runner mainly for peace of mind. I know that I'm probably just wasting money, but in both vehicles I do notice an ever so slight increase in performance, though it could just be my mind trying to justify paying up the extra $ at the pump. :eek:
  4. Jul 31, 2010 at 6:28 AM
    #344
    commtrd
    commtrd commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    Slower flame propagation in the cylinder does not mean better gas mileage. It means the flame "chases the piston down the hole" instead of jackhammering it down to create "pinging". Higher octane is only useful for high-compression engines to prevent pinging due to detonation. Typically used in high-performance engines where compression is greater and more air/fuel mixture is drawn (or charged to) the cylinders to create more net power per cylinder volume available. So the higher octane will burn slower which is easier on the engine than when the fuel is ignited explosively which can lead to broken and burned reciprocating parts within the engine (piston rods / pistons / wrist pins etc.). Better gas mileage as a result? Not going to happen.
  5. Jul 31, 2010 at 6:35 AM
    #345
    commtrd
    commtrd commtrd
    Corpus Christi TX
    Exactly! Which is why I am trading my taco in on a ford with a 6.7 litre turbodiesel. Tired of getting 16 mpg and driving a slug as far as power goes. The ford has 390 hp and 735 ft/lbs torque. And will get near 24 mpg doing it. If I put a supercharger in my taco (thought seriously about doing that) I would spend $4000 which I would not get back in resale (on top of everything else I have done to the truck to make it right) and then would have to burn premium gas which costs the same as diesel and still would not be able to tow over 6500 with it. What's the point? Good money after bad.
  6. Jul 31, 2010 at 11:56 AM
    #346
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    The new 6.7 Powerstrokes claims are untrue. Even with the DPF removed the Dyno showed a RWHP 267HP and 615 ft lb of torque. This engine is a disappointment, the 6.4 Powerstroke had more power with a DPF delete alone.
    Heres the video.
    http://www.youtube.com/watch?v=iBiw3cW5ImM&feature=related
  7. Jul 31, 2010 at 11:59 AM
    #347
    2.7taco
    Texas
    No the power of gasoline does not change, it still produces the same BTU's of heat. The only difference is the fuel is more stable as as the octane increases.
  8. Jul 31, 2010 at 12:12 PM
    #348
    TRDfly
    TRDfly Well-Known Member
    Traverse City, MI
    Silver 07 DC, TRD off-road....it's the bomb!!
    DRL, Black Headlight mod, H.I.D's, Wet Ass Seatcovers, White instrument cluster, Illuminated 4x4 switch.
    Track your fuel MPG with Fuelly! It's easy and I've got a better idea what my own MPG is compared to other Taco's out there! It's also a lot more consistent then listening to all this jabbering we all do........including my own jabbering! :D
    See how most Taco's do---->http://www.fuelly.com/car/toyota/tacoma
  9. Jul 31, 2010 at 12:40 PM
    #349
    2.7taco
    Texas
    I hand calculate my own and its pretty accurate.
  10. Aug 1, 2010 at 5:25 AM
    #350
    PPower05
    PPower05 Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    You aren't going to notice any difference. Higher ratings are for high performance engines that are higher compression...... It does make difference in some knock issues, but you really wont notice anything....
  11. Aug 1, 2010 at 2:19 PM
    #351
    bobby15
    bobby15 Well-Known Member
    SoCal
    09 DC LB 4x4 magnetic grey tacoma
    haha me too !!:D
  12. Aug 1, 2010 at 5:52 PM
    #352
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Correct in most cases but running too high of octain will cause runability issues too. The ecu can only add so much timing without a reflashing a new map.
    Also, Ethanol will also keep knock counts down but leaves more deposits in your fuel system.... damn it... I sound like a commercial haha
    Does anyone know of the actual hp differnces between 87 & 93?
  13. Aug 1, 2010 at 11:28 PM
    #353
    myname150
    myname150 Well-Known Member
    Yeah im liking shell too, i used to use that typical grocery store gasoline (HEB for me) for over a year, and about a month ago i switched to regular shell. And i drive with a lead foot and i noticed my gas needle didnt go down as fast. Im happy with shell. And thanks to that grocery store ,HEB being right across the street, shell is always more or less the same price as them (usually a .01 or .02 cents in difference). Competition ftw :D
  14. Aug 2, 2010 at 10:42 AM
    #354
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    sunoco 87 = about 20 mpg. proof in the pic
  15. Aug 2, 2010 at 10:46 AM
    #355
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
  16. Aug 2, 2010 at 1:23 PM
    #356
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    straight from the QT website
    i still run 89+ in my truck at all times
  17. Aug 4, 2010 at 6:45 PM
    #357
    jandrews
    '09 FourDubDee TRD OR
    Fixed that for you.
  18. Aug 4, 2010 at 7:31 PM
    #358
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    yes and no, def driving habits, but dif companies, which have gas provided from different refineries = dif mpg , my opinion is due to dif levels or dirt and particulates in the gas....nj has some of cheapest gas in country due to the ports here get them delivered and travels a lot less. Hess for exmple has storage tanks all over the hudson river.... but i seem to get best mpg albeit slightly better, from sunoco vs other companies.
  19. Aug 4, 2010 at 7:33 PM
    #359
    jandrews
    Difference in impurities/contaminants in the gas would be moot once the gas hits the fuel filter.
    I'm willing to bet it's outside factors like your driving habits, the weather that day (which can make a big difference in mileage), tire pressure, etc. that widdle things around a bit. The differences aren't due to brand or octane.
    The only reason I'm brand-picky about gas is detergent levels. Certain brands (top tier, BP, Texaco) have higher volumes than others when it comes to detergent.
  20. Aug 4, 2010 at 8:14 PM
    #360
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    ditto on better gas mileage with premium. I can typically go 20 more miles per tank.
