Gas Octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, May 9, 2009.
Which fuel octane do you use?
  1. 87
    2,159 vote(s)
    64.4%
  2. 89
    454 vote(s)
    13.5%
  3. 91
    773 vote(s)
    23.1%
  4. Other fuel additives
    57 vote(s)
    1.7%
  1. May 10, 2009 at 8:53 AM
    Joe B
    Joe B Well-Known Member
    93 before and after the supercharger install.
    Usually Shell.
  2. May 10, 2009 at 8:56 AM
    wired_af
    wired_af Well-Known Member
    Alex
    Colorado Springs, CO
    '07 DC TRD Sport S/C, Rivian R1T
    +1. I calculated it once, I think I was saving nearly $1 per fill up using 91. :cookiemonster:
  3. May 10, 2009 at 9:22 AM
    downey
    downey Active Member
    Montana
    2009 Mag Gray 4x4 TRD-Off Road
    Leer 100r
    Where is 85 octane on the poll for those of us at altitude in colorado??...It's equivalent to 87 at lower altitudes:)
  4. May 10, 2009 at 9:46 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    If your truck has knock sensors as most modern ones do it retards the timing when it detects it to stop detonation or pinging. Higher octane will allow it to use more timing before the sensor says whoa there pardner.
    So more timing will get you a bit more power.
    We are stuck with only 91 here as many states.
  5. May 10, 2009 at 10:04 AM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    I run 93.
    Like other have said, the engine just feels happier with higher octane gas.
    That, and when gas was 3-4 dollars a gallon I would actually save money over the long haul using 93 as opposed to 87.
  6. May 10, 2009 at 11:03 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Ah, so that's how it works: lower octane for higher altitude (believe me, I'm no engineer). I wondered about that.
  7. May 10, 2009 at 11:04 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    That is correct, sir.
  8. May 10, 2009 at 11:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yeppo! The higher the Alt., the less likely your gonna have Knocking issues (pre ignition) as there is less air ( o2 )....:)
  9. May 10, 2009 at 11:58 AM
    sdnicker2000
    sdnicker2000 Well-Known Member
    Nebraska
    Mostly Stock 08 TRD Sport
    Rear spring TSB, Fumoto Valve, No A/C on defrost mod., tailgate theft mod.
    Where I live we either have 87 with no ethanol or 91 with it. I get better mileage (usually 3-4 mpg over a tank) using the 87. And like one here said "It seems happier" using the non-ethanol. Have found this with both my Tacoma and the wife's Honda Pilot.
  10. May 10, 2009 at 12:01 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I noticed the same milage between 89 and 91 personally. However, I do notice the engine is more responsive with the higher octane.
  11. May 10, 2009 at 12:10 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Detonation, not pre-ignition. :)
  12. May 10, 2009 at 1:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thank you. :eek:
  13. May 10, 2009 at 1:51 PM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    There is nothing to notice. It is a calculation. If you do the math you’ll find that you save money (or not). During the gas crunch last summer I saved about a buck per tank. Not much considering a fill up was about $80. However, why run 87 when you can run 91 for a buck less?
  14. May 10, 2009 at 5:36 PM
    geoff5093
    geoff5093 Well-Known Member
    Goffstown, NH
    2013 Subaru BRZ
    I tried running 93 octane for two tanks and didn't really see a difference, at least not for paying a $0.20 premium every time I fill up. So I run 87.
  15. May 10, 2009 at 6:16 PM
    #35
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    where do you buy 93 octane? Can we even buy this in CA at a pump station
  16. May 10, 2009 at 6:19 PM
    #36
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    93 is all we have in VA, 87, 89, and 93
  17. May 10, 2009 at 6:45 PM
    #37
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    In NH most stations sell 87, 89, and 93. Some sell 91 as well.
  18. May 10, 2009 at 6:58 PM
    #38
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Same here. I don't even remember seeing 91.
    HOWEVER, we only have 10% ethanol gas here. I've searched and searched, asked on multiple forums, but it seems that's all that we have in SC.
  19. May 10, 2009 at 7:33 PM
    #39
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    Same here, I was never able to find any stations that did not have 10% ethanol.
  20. May 10, 2009 at 8:16 PM
    #40
    commtrd
    commtrd commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    Well I will try a tank of 91 (we get that here in TX) especially if it does not have any ethanol in it. Just not having any ethanol is a huge plus. Ethanol does not have the same energy density as does gas. It is also corrosive. Ethanol also hurts fuel mileage. I can see the argument about timing retardation if knock is detected but neither of my V6 engines have ever knocked on acceleration or towing that I could detect. It won't cost a lot to try it anyway.
