Gas Octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, May 9, 2009.
Which fuel octane do you use?
  1. 87
    2,159 vote(s)
    64.4%
  2. 89
    454 vote(s)
    13.5%
  3. 91
    773 vote(s)
    23.1%
  4. Other fuel additives
    57 vote(s)
    1.7%
  1. Sep 7, 2011 at 1:31 PM
    #581
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It actually doesn't ignite as quickly... lower octane gas does ignite at a lower temperature... and older cars had pinging (pre-ignition) and dieseling on hot days because the low octane gas would ignite BEFORE the spark plug lit, and while the piston was still moving up!
  2. Sep 13, 2011 at 11:48 AM
    #582
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    I gotta test this out!!
  3. Sep 18, 2011 at 8:59 PM
    #583
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have the 4.0 engine. All ways ran 87 in it.
    So far, it's had all the power it's need to do what I ask it to.
  4. Sep 24, 2011 at 7:53 PM
    #584
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    I commute almost 100 miles each day so mpg is pretty important to me, used to drive a 3 series BMW and would always use 93 octane as I would get better gas mileage, been using 87 in my Tacoma since I got it two weeks ago, might try 91 to see if there are any differences.
    Been getting about 19.5 mpg with 87 with a very light foot, I burned through my first tank of gas the dealer put in, but was pushing the truck a lot.
  5. Sep 24, 2011 at 9:06 PM
    #585
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    I posted this is another octane thread, but recently on an all-highway trip where I burned an entire tank, I filled completely up with premium before and got 22.6 MPG (with cruise set at 70MPH for 350+ miles). On the same trip on the way back I got 21.0 by using 87.
    What I calculated at that time was that in this case, it was about a 7% increase in MPG using premium with about a 6.5% increase in the price per gallon. There was no statistically significant monetary benefit.
  6. Sep 24, 2011 at 9:24 PM
    #586
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The trip there is different from the way back, wind, altitude, temperature, traffic, many things could explain the difference in mpg besides octane.
  7. Sep 24, 2011 at 9:33 PM
    #587
    colder
    MN
    I agree, although there was no difference in elevation, my overall point was that there's no reason to suspect that mileage is much greater, to the point where it makes it worth the money.
  8. Oct 9, 2011 at 4:12 PM
    #588
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    91/93 gets me a tad better performance, but ultimately 1 mpg better on premium, so it pays for itself.
  9. Oct 9, 2011 at 8:21 PM
    #589
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    In a standard compression engine, the regular grade octane that is appropriate for your climate (here it is 87) will burn more completely and is more effective than higher octane grades that are intended for higher compression engines since higher octane rating increases the compressibility of the fuel before it spontaneously ignites. (So basically, higher octane fuels actually are more difficult to ignite and can actually increase your emissions (slightly) and decrease your MPG (slightly). Most cars' computers can compensate for both too high or too low; except carburetted engines.
    SOME higher octane fuels, usually the highest grade, contain more cleaning agents with the mid grade being a mix of the two.
    Don't worry about it. Regular isn't mediocre.
  10. Oct 11, 2011 at 10:00 PM
    #590
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    One doesn't need no dyno results, but when I tow I always use '91 gas
    for better performance.
  11. Nov 13, 2011 at 10:45 AM
    #591
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Its funny to read how much people are misinformed about high octane gas. Remember it is just a truck not a Ferrari.
    It would be interesting to see two identical stock trucks with auto trans (to eliminate bad shifts) do a 1/4 mile. One with 85 and the other with 93.
  12. Nov 13, 2011 at 12:20 PM
    #592
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I would like to run 87, and most of the time it runs fine on that, but when the humidity is right I'll get misfires at high throttle on the regular stuff. It has happened from different gas stations on different sides of the state in different months so it's likely not a bad batch issue. On days when it does this I put in premium and the problem disappears after about 15 miles.
    Maybe my truck is finicky, maybe something else is out of spec, but either way it runs better on premium.
    I have noticed that when running premium the ignition advance at 55 mph will stay between 29° and 31° BTDC even on fairly substantial hills around here (meaning maybe a 3% grade, they're not that big), and on regular fuel it likes to dip down to the 18°-20° range with even a slight increase in load. The average difference across the tank isn't much but the instantaneous mpg values at that speed are much better.
  13. Nov 13, 2011 at 4:30 PM
    #593
    T A C O M A
    T A C O M A Well-Known Member
    I run the highest grade and my tailpipe looks like it still came new from the dealership....it's sooo clean
  14. Nov 13, 2011 at 5:19 PM
    #594
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I prefer to run the highest octane I can get. Around Ohio, that is usually 93 octane. Through 40 years of driving, I have found better performance and better mileage per gallon. I get enough mileage increase that it always offsets the higher cost and then some.
    As for brand name gas verses discount, you get what you pay for. I try to run only brand name, here it is Marathon and Shell, There is a mileage and to a lesser noticable extent performance differance between national and discount gas.
  15. Nov 13, 2011 at 8:49 PM
    #595
    ShawnR
    ShawnR Roads?? We don't need no stinkin' roads...
    Shawn
    Denver
    10 Taco TRD OR access cab
    PIAA driving lights,Pioneer AVH-P3300BT stereo with HD radio and Axxess steering wheel control adapter,rearview mirror mod,ReTrax rolling cover,Demello front bumper,WeatherTech,10 inch woofer,500 watt amp,CB in armrest, heated Wet Okole seat covers,Spidertrax spacers, ARB twin compressor,Ikon 10,500lb wireless winch,A-pillar RAM mount,Pull-Pal,electric locking tailgate
    Everyone claiming better mpg is.
    You must be getting more power per gallon if your mileage goes up.
  16. Nov 13, 2011 at 9:27 PM
    #596
    4x4Noob
    4x4Noob Well-Known Member
    I think a lot of you are confused. It has nothing to do with 91>87, or horsepower, etc..The fact of the matter is the 4.0 V6 has the VVT-i engine. It requires 91! Your engine is not performing adequately if not supplied with 91. VVT-i is similar to Honda's V-TEC(also requires premium).
    Engine knock,ping,etc..are bound to happen.
    If you have the V6 id say 91+ octane and for the V4 87 octane
  17. Nov 14, 2011 at 4:51 AM
    #597
    myname150
    myname150 Well-Known Member
    You've got to be kidding me....so all these little civics with their vtec require premium? looool
    On our trucks the ECU controls the timing. You put in regular 87, the ECU retards the timing (if it's knocking)...Put in Premium, the ECU advances the timing.
    I think toyota revised the manual eventually, but in my 08 it says 87 is the minimum, and Premium is recommended, not required.
  18. Nov 14, 2011 at 5:35 AM
    #598
    SilverTacoEater
    SilverTacoEater Well-Known Member
    Pasadena, MD
    11 Tacoma SR5 4X4
    Stock
    Not all Honda's with v-tec use premium. Only certain models. The civic si has a 2.0
    Liter engine that has 11:1 compression and revs to 8500rpms. Plus it can advance and.retard timing similarly to toyotas vvt-I but Honda takes it one step further. It actually switches.between two cam.profiles. One cam profile is for gas mileage and when the engine hits a certain rpm range, that is determained by the computer depending on several different factors it switches to a more agressive cam profile for more torque and hp. So those Honda engines really do need premium in order to not detonate.
  19. Nov 14, 2011 at 8:17 AM
    #599
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    You seem confused too... octane reguirement of the engine has nothing (directly) to do with VVTi, V-TEC or any other variable valve timing technology. It's compression ratio and FI that drive octane requirements and tuning can mitigate it.
  20. Nov 14, 2011 at 8:33 AM
    #600
    worthywads
    V4 :facepalm:
    Some one is confused.
