Gas Octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, May 9, 2009.
Which fuel octane do you use?
  1. 87
    2,153 vote(s)
    64.5%
  2. 89
    454 vote(s)
    13.6%
  3. 91
    767 vote(s)
    23.0%
  4. Other fuel additives
    56 vote(s)
    1.7%
  1. Jun 19, 2013 at 5:56 AM
    #881
    gwos25
    gwos25 Well-Known Member
    Gary
    Calgary, AB
    2012 TRD Sport
    I think the debate here stems from the fact that Toyotas manual used recommend minimum of 87 octane, or 91 for increased performance. In this case, it has nothing to do with compression ratio, but ignition timing. Its possible the software was programed with more ignition advance to take advantage of 91 octane, with a "backup 87 octane" ignition map which it used when/if pinging or knock was detected. The new ford EcoBoost engines do the same. As a manufacture, it allows you to advertise great power/torque numbers, but still allow for the use of regular fuel. I have no idea if Toyota changed just the wording in the manual, or if they changed the tune as well. FWIW, the difference in mileage when using premium vs. regular could be attributed only to the fact that most regular (87) fuel is blended with ethanol and most top tier brands premium (91) is not. Being the ethanol blended fuel is less energy dense, you'll naturally get more mileage out of the premium.
  2. Jun 19, 2013 at 10:56 AM
    #882
    B11
    B11 Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    You need to either go back to school or go back to the school you just graduated from with that 4.0 and get your money back because you obviously don't know the difference between Detonation and Pre-Ignition.
    Detonation always happens AFTER normal combustion. Pre-Ignition, just like its name, happens BEFORE the spark plug fires.
    Also, a Dynamometer uses a "Correction Factor" to adjust to a standard temperature.
  3. Jun 19, 2013 at 3:11 PM
    #883
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  4. Jun 19, 2013 at 3:32 PM
    #884
    23dec2007
    23dec2007 Outlaw 525S member
    08 PreRunner SR5 TRD Sport 2wd
    tint, bed cover, weathertech bug guard, window trim and mats, FOX hitch cover, viper alarm and remote start, kenwood deck, 10 station xm sat, 12.1 flip down dvd player, all pioneer door speakers, AVS rear window vent shade
    87 when not towing/ around town...93 for towing and highways runs
  5. Jun 20, 2013 at 12:25 PM
    #885
    Dirtysouthmafia23
    Dirtysouthmafia23 Member
    Jake
    Pensacola, fl
    06 PreRunner SR5
    Blue strobe "cop lights" for now
    yes I know the difference. pre ignition melts parts detonation blows parts into pieces I know detonation happens after combustion I was trying to bring it down to lamence terms for the less mechanically inclined. I prolly used the wrong terms then I should have but no matter what terms you use the result is the same a higher compression engine can ignite with out a spark because it seperates the H from C in HC (hydrocarbon-also know as gas) with the compression. higher octane gas prevents this by making the H and C chemical bond stronger to where it requires a spark to combust. there it is in non lamence terms
  6. Jun 20, 2013 at 12:31 PM
    #886
    Dirtysouthmafia23
    Jake
    Pensacola, fl
    06 PreRunner SR5
    and what you are talking about is calculated horsepower. it is what the horsepower could be in perfect conditions but no one usually even looks at this numbe unless you are trying to sell an engine to someone across the country where there weather conditions are wrong.
    I do know we can dyno a nascar engine at 60 degrees F and get 900 hp (round numbers) and come back the next day at 50 degrees F and have 910 hp
    moral of the story no correction factor
  7. Jun 20, 2013 at 12:34 PM
    #887
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    layman's terms
  8. Jun 20, 2013 at 1:21 PM
    #888
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Lamence :facepalm:
    NASCAR tech don't English.
  9. Jun 20, 2013 at 2:40 PM
    #889
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2013 Super White Baja
    all has ethanol in town. When you get out of town you can find 87 without but higher has ethanol. Ethanol is used to increase the octane. It sucks because I like to run non-ethanol in boat but it takes 93. Some of the diffs that people see in MPGs could be dur to ethanol content
  10. Jun 20, 2013 at 6:11 PM
    #890
    stump jumper
    Bill
    Texas
    you trying go blow that thing up? As far as the ethanol sticker placement on the pump it just happens to be near the 87 nozzle because that is where they put it. Since I own an older outboard running high compression I have done a lot of reading on ethanol and the impact on outboard motors. A lot of people around here who are serious about their boats use ethanol test kits. I can tell you most all premium has ethanol even at stations that sell ethanol free regular. Mid grade is a blend of the 2 at the pump.
  11. Jun 21, 2013 at 9:58 AM
    #891
    Dirtysouthmafia23
    Jake
    Pensacola, fl
    06 PreRunner SR5
    Lol so I can't spell "laymans"
    And yes NASCAR don't "teach" English
  12. Jun 21, 2013 at 10:01 AM
    #892
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    NASCAR == Redneck ;)
  13. Jun 21, 2013 at 3:50 PM
    #893
    B11
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    LMAO!!! That has to be one of the best excuses yet.
    Yeah, I always give incorrect information and contradict myself when I'm trying to make it easier for others to understand and I ALWAYS tell everyone how smart I am while I'm doing it. Mmhmm, sure you really knew the difference. ;);) Still LMAO!!!
  14. Jul 15, 2013 at 8:03 AM
    #894
    field76
    field76 Well-Known Member
    Bozeman
    2012 PM TRD OR DCAB
    Debadged, audio upgrade, silex organizers, AVS in channel window vents, 5100s on all corners with Wheelers 3 leaf HD AAL
    Agree with Brunes, I'll through a tank of the 91/93 for road trips or what not.
  15. Jul 16, 2013 at 4:16 AM
    #895
    gocky
    gocky Well-Known Member
    canyon lake
    CCLB 4X TRD sport
    urd intake, race runner coilovers, fox 2.0 piggy back rear, tsb leafs, pro comp light bar, kc 6x9 hid, bfg mud terrain km1, tailgate anti theft mod, banks exhaust, oil filter drain hose extension, optima yellow top. debadged and peeled all the stickers off
    Minimum 91 octane is what's recommended by Toyota in my manual... I trust Toyota over a bunch of yahoo's and I own mine so I want it to last
  16. Jul 16, 2013 at 4:40 AM
    #896
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    I'm willing to bet money your manual does NOT say that, go back a page and look at my post. Research octane rating and octane rating aren't the same, yours has a recommended octane rating of 87. Nobody yet has answered my question about why the recommended octane changed after 06, but since 07 it looks like toyota has been saying you only need 87.
  17. Jul 16, 2013 at 6:08 AM
    #897
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    2010 4 X 2 Regular Cab
    Chrome exhaust tip
    Maybe Toyota stopped getting money under the table from the big oil companies. :confused:
  18. Jul 16, 2013 at 9:17 AM
    #898
    OZ-T
    Peter North
    British Columbia
    Mine says 87 and up
    Not 87
  19. Jul 16, 2013 at 9:25 AM
    #899
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DblCab,shrt bed,4wd,TRD Sport, tow pkg, mgntc grey
    katzkin leather, chrome toyota step bars, chrome sr5 grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflectorII, tinted windows, Firestone ride-rite air bags, UWS slimline aluminum toolbox, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, Tundra / Sequoia wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed.
    In my area 93 octane costs roughly 10% more than 87 octane. I can't precisely replicate driving conditions for each tank full, but I am relatively sure that I get 10% more miles per gallon out of the 93 (only 1.6 - 2.3 more mpg=10%) therefore I am convinced that fuel cost is at worst the same, but there may be some benefit in fuel detergents, additives, etc. So for me I can rationalize buying the higher octane stuff.
  20. Jul 17, 2013 at 8:55 AM
    #900
    JHG57
    JHG57 Active Member
    James
    Oviedo, Florida
    An engine that was designed to run on a lower octane fuel can actually suffer with higher octane. The higher octane RETARDS the ignition to keep auto combustion from happening in high compression engines. 91 octane burns SLOWER than 87 octane.
