Gas Octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, May 9, 2009.
Which fuel octane do you use?
  1. 87
    2,159 vote(s)
    64.4%
  2. 89
    454 vote(s)
    13.5%
  3. 91
    773 vote(s)
    23.1%
  4. Other fuel additives
    57 vote(s)
    1.7%
  1. Jul 17, 2013 at 10:09 AM
    #901
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Where did you get those numbers?
  2. Jul 17, 2013 at 10:45 AM
    #902
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    Huh???
    I know we are in a Tacoma forum, but I am going to use the new 5.0 engine in the Mustang as an example. The Copperhead ECU found in the 5.0 can adjust for different octane. I have no clue if the Tacoma's ECU is like this.
    Anyways, the 5.0 is designed to run on 91 octane but can also run 87. The CR in the 5.0 is 11:1 FYI. If you run 91, the knock sensors should not detect any knock in the engine, thus advancing the timing in the engine and allowing for maximum horsepower.
    If you run 87, the engine will probably detect some knock and retard the timing, which equals to less HP and tq.
    I am new to the Tacoma scene, but I would imagine it also detects knock. If there is knock present the ecu backs off timing and saving your engine from continuous detonation. If the Tacoma ecu does not detect knock, I'm sure the ecu advances the timing and will allow a minimal HP bump.
    Higher octane will advance timing if no knock is detected, not retard it. This is of course, if the ecu in the Tacoma is this sophisticated.
  3. Jul 17, 2013 at 2:40 PM
    #903
    JHG57
    JHG57 Active Member
    James
    Oviedo, Florida
    You misread, the fuel itself (higher octane) is slower burning which retards or slows down the ignition of the fuel. This is a fuel characteristic, I was not talking about engine timing.
  4. Jul 17, 2013 at 5:55 PM
    #904
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    One thing I noticed at some stations in our locale is a decal on the pump stating that 87 octane contains 10% ethanol 89 octane contains 5% ethanol and 92 octane contains no ethanol.Most pumps only say gas may contain up to 10% ethanol.Now this could account In itself for better gas mileage using premium gas would it not.What I am not understanding is if all the gas in our locale comes from the same refinery would the same ethanol content not apply at every station?
  5. Jul 17, 2013 at 6:00 PM
    #905
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    E0 vs E10 is what makes the biggest difference.
    Use E0 87 and you will get better mpg than E10 91.
  6. Jul 18, 2013 at 5:33 AM
    #906
    ostroud18
    ostroud18 Well-Known Member
    Odis
    Grayslake, IL
    2017 4x4 4 door silver TRD Sport
    None
  7. Jul 19, 2013 at 5:17 AM
    #907
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DCSB,4wd,TRD Sport, tow pkg, MGM
    katzkin leather, toyota step bars, pro grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflector, tinted windows, Firestone ride-rite air bags, ARE camper top with tool doors, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, 2020 Tacoma Pro styled wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed, blacked out badges, tinted taillights, upgraded climate control knobs, ultimate headlight upgrade with Osram superbrights and wiring harness along wit OEM pro headlight housings.
    Here is the quote from Wikipedia:
    The 1GR-FE is the 4.0 L (3956 cc) version, designed for longitudinal mounting in RWD and 4WD pickup applications. It has a 94 mm bore and a stroke of 95 mm. Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane. This engine features Toyota's VVT-i, variable valve timing system on the intake cam and a compression ratio of 10.0:1. An updated version of this engine features Dual VVT-i, increasing output to 254 hp (189 kW) and 270 lb·ft (366 N·m) on 87 octane and 285 hp (213 kW) and 289 lb·ft (392 N·m) on 91 octane.
  8. Jul 19, 2013 at 6:16 AM
    #908
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    The additives, detergents, etc., (or lack thereof) are the same across the range and not just added to that which has higher octane levels. There was a link in one of these many fuel threads showing which stations had "better" gas due to added detergents, etc., but I can't find it.
  9. Jul 19, 2013 at 7:44 PM
    #909
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    There was a guy on the Texas Fishing Forum that works for a gas distributor. He said there are 2 octane levels delivered to the gas station. Midgrade is a blend of high and low. I cannot confirm this but there are a lot of guys on this forum running high performance outboards. Some of these guys go as far as to carry test kits to the gas station.
  10. Jul 27, 2013 at 8:23 PM
    #910
    DocHolliday
    DocHolliday Well-Known Member
    Charleston SC
    13 PreRunner SR5
    With 87, I averaged 18.6mpg combined
    Now running 89 non ethanol! Not filled up since, but judging by the gas gauge/odometer I'm going further and needles moving slower will repost with mpg
  11. Jul 29, 2013 at 5:56 PM
    #911
    stump jumper
    Bill
    Texas
    non-ethanol will raise your MPGs regardless of octane. One of many reasons why ethanol is crap. With all our oil we do not need it. Ethanol producers have top much clout now so I guess we are stuck with it.
  12. Jul 30, 2013 at 9:44 AM
    #912
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    via XRU
  13. Jul 30, 2013 at 4:06 PM
    #913
    DocHolliday
    Charleston SC
    13 PreRunner SR5
    Got gas today after using 89 ethanol free, 21.3 with some city driving, compared to 18.6 87.
  14. Jul 30, 2013 at 5:49 PM
    #914
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Will run 87 unless I'm towing or seriously working the engine. Only Then would I run the higher octaine!
  15. Jul 30, 2013 at 6:10 PM
    #915
    stump jumper
    Bill
    Texas
    I think people are getting better MPGs from the ethanol free and thinking it is the octane. It is like doing 2 performance mods at the same time. How do you know which one was responsible for the result. I would like to see the effects of running 87 ethanol free versus 91 or 93 ethanol free.
  16. Jul 30, 2013 at 6:17 PM
    #916
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    Just filled up with 89. I got 280 on my last tank with another 20 dollars more of 87. I'll see if it's worth the extra $ to fill up.
  17. Jul 30, 2013 at 6:19 PM
    #917
    DocHolliday
    Charleston SC
    13 PreRunner SR5
    Yeah, i dont think its the Octane, just the Ethanol, but the gas station where i fill up only has it in 89. So thats what i get, there is a place that sells 87 but im not driving out of my way to get it. . . .
  18. Jul 30, 2013 at 6:58 PM
    #918
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    280 miles?
    I can hit about 350 if I push it, and 320 no problem
    And I drive the truck hard
  19. Jul 30, 2013 at 7:06 PM
    #919
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    I'm sure the MT tires and the lift don't help the MPG lol.
    That's also when the gas light came on. I usually just fill up when it comes on.
  20. Jul 30, 2013 at 7:19 PM
    #920
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Yeah.... Must be heavy tires.
    320 and my lights not on yet.
    Ur half an inch taller and I'm only running authorities in load range c.
    But the truck sees boost on a regular basis.
