Gas Octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, May 9, 2009.
Which fuel octane do you use?
  1. 87
    2,159 vote(s)
    64.4%
  2. 89
    454 vote(s)
    13.5%
  3. 91
    773 vote(s)
    23.1%
  4. Other fuel additives
    57 vote(s)
    1.7%
  1. Jun 6, 2009 at 6:31 PM
    #101
    BreezyTaco
    BreezyTaco [OP] Well-Known Member
    Corpus Christi, TX
    Pioneer Indash GPS, JL Audio Speakers, FM Alarm, Euro Tail lights, Blue Dash Lights, Trailor Hitch, Painted Fiberglass A.R.E. Tonneau Cover
    That is pretty much the reason why I wanted this thread...My Toyota Matrix had a fuel injector "O" ring start leaking which was not covered by my warranty and cost over $250 labor and $20 parts to fix, I wanted to know if these stations like shell, mobile1, and so on help prevent things like this. Same with fuel injector cleaner additives or getting them professionally cleaned, is it necessary at some point or ever?
  2. Jun 6, 2009 at 7:08 PM
    #102
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have never run an injector cleaner, or had the service performed on any of my trucks, and I have never had an injector go bad.
  3. Jun 7, 2009 at 11:57 AM
    #103
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I will put a can of seafoam in an empty tank of gas every oil change or so (10,000 miles). Just because their not bad yet doesn't mean they're working at the full capacity. I have had injectors go bad in an s10 but I think it was more because it sat all winter without being ran.
  4. Jun 7, 2009 at 12:25 PM
    #104
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    I have run 87, 89 and 91 in my truck. With the 91 it definately does seem to run smoother with a tad more power. I have not noticed any increase in mileage however.
  5. Jun 7, 2009 at 3:40 PM
    #105
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I may try the Shell next fill up. QT out here is much less expensive than the Shell, so we'll see.
  6. Jun 7, 2009 at 4:29 PM
    #106
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I have been using shell the last couple of tanks. I use 87. My MPG average has been 23-24 in town. I just filled the tank, after a couple of miles, the SG is reading 22.8 MPG.
  7. Jun 7, 2009 at 4:36 PM
    #107
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, ok, Gottcha!
  8. Jun 7, 2009 at 8:24 PM
    #108
    XR-Ace
    XR-Ace //TRD
    O.C. California
    08 SWB X-Runner aka "BLUE BEAST"
    Evo Mod// Eagle Eye Halo Projectors// Magnaflow Exhaust// Yellow Foggies// Trd Badge
    Shell V Power ftw
  9. Jun 10, 2009 at 6:00 AM
    #109
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    I started using 91 in my v6 taco and the last fill up was 22.5 mpg. it was nice to see that!
    a little caution on 4 bangers and 91 or 93 octane gas... my fist truck, 91 s-10 4 cyl, I bought used from a guy with 110,000 miles on it and he had had it since new and only used 91 octane or better and recommended I do the same. I did and at 180k the valves had burned in it. I was told that running the high test had made the valves burn out. I'm sure motors have changed a lot since then but this may be something to watch out for with the 4 cyl engines
  10. Jun 10, 2009 at 7:44 AM
    #110
    Old Soul
    NC
    wow, straight ethanol. if you had a popcorn popper in your engine you could have had popcorn to eat while cursing over your burned up engine
  11. Jun 10, 2009 at 8:48 AM
    #111
    Old Soul
    NC
    I'm not sure if Ethanol is added here in NC or not, I'll check it out. Not sure what to do if it is though, seems the person at the pump has no choice in the matter
  12. Jun 10, 2009 at 7:35 PM
    #112
    slimsdepot
    slimsdepot slimsdepot.com
    SoCal
    08 PreRunner
    Is this true...???
  13. Jun 10, 2009 at 7:39 PM
    #113
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^I have noticed this, yes.
  14. Jun 10, 2009 at 7:58 PM
    #114
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I noticed a definite performance increase when I switched to 93 octane (from 87).
    For the past 2 tanks, I am exclusively using Shell V-Power 93. So far, I have gotten about 2mpg better than when I was using 87. I am tracking my results for each tank on a spreadsheet. I plan to use 10 tanks of 93 and average my results. Then, I will switch back to 87 for long enough to determine if it's worth the extra $7-8 for the higher octane.
    I figure I will pay more but get that back in mpg + enjoy the benefits of the higher octane.
  15. Jun 10, 2009 at 8:35 PM
    #115
    commtrd
    commtrd commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    I may try the higher octane but with prices increasing at the pump it will hurt!
  16. Jun 10, 2009 at 8:37 PM
    #116
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Try a tank and track it. If it works out for you and you save a buck or two with increased mileage, stick with it. If not, no big loss.
  17. Jun 10, 2009 at 10:19 PM
    #117
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Pretty much the same. I can't say for certain because my tires are 265-70-16 instead of the 275-60-16 that it should have come with.
    I fill up with Co-oP, but when it's not possible, I put Shell in there. I like how they have a separate hose and nozzle for Premium. Means I don't get a first 2 liters of regular and the next guy filling with regular gets my 2 liters of premium.
  18. Jun 11, 2009 at 4:27 AM
    #118
    jandrews
    '09 FourDubDee TRD OR
    91 isn't an option at most places here in NC...simple solution I've used before on 91 octane vehicles is to alternate each fill up - one tank at 89, the next tank at 93, and assume it evens out.
    Anyone know if this is a problem or not?
  19. Jun 11, 2009 at 5:48 AM
    #119
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Switching between the 2 octains does nothing. In most cases, it takes 1 tank of running the particular fuel for the computer to fully adjust to the new octain, and give best performance.
  20. Jun 11, 2009 at 11:44 AM
    #120
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    HA! You suck! I poop on you!
