Gas & Oil additives
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdz2nutz, Jan 14, 2014.
  1. Jan 14, 2014 at 4:03 PM
    cdz2nutz
    cdz2nutz [OP] Member
    05 tacoma
    3" suspension lift & air bags
    I only run 93 octane in my '05 Tacoma v6 190k mi. Should I occasionally put gas & or oil additives in & any recomendations?
  2. Jan 14, 2014 at 4:34 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Do you notice a big difference between 93 and 87/89? I know alot of people say it cuts down on knocking/pinging. I run 89 (that being midgrade in NC). I've never really noticed a big change between regular and premium. To answer your question though, i put in Lucas fuel system cleaner in about once every 6 months thats about it. I've run mobile 1 motor oil since day one and never had much issue. I dont think you need much additives on newer engines like the tacomas. just my opinion.
  3. Jan 14, 2014 at 5:15 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I run 2 stroke oil TCW3 at 2 oz per tank in my Taco. It lubes the whole fuel system and upper cylinders.
  4. Jan 14, 2014 at 5:23 PM
    catsman50
    catsman50 Well-Known Member
    Jupiter, FL
    white prerunner 6speed
    Don't know much about oil additives but, I use to work for a fuel injector company and none of those gas additives do anything.
  5. Jan 14, 2014 at 5:31 PM
    jmich2001
    jmich2001 Well-Known Member
    Toms River, NJ
    12 Access Cab TRD OR
    Yellow Fog Lamps, Ham Radio
    I use Lucas fuel treatment at fill-ups. One small bottle per tank. I believe it keeps the pump and injectors lubricated and helps with upper cylinder lubrication. We run 10% ethanol here and I believe it helps negate any negative properties associated with ethanol. I have found that wally world has the best price for Lucas.
    I run mobil1 5w-30 at 6000mi change intervals and don't use any oil additives. If I were to use one it would be a Lucas product.
    I also have a 2005 Ford van with 200K miles on it. I use Marvel Mystery Oil as a fuel additive at every fill-up since it was new with no negative side-effects.
