Gas or oil smell
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacTrd2007, Mar 15, 2020.
  1. Mar 15, 2020 at 7:52 PM
    TacTrd2007
    TacTrd2007 [OP] Well-Known Member
    2007 Tacoma TRD OR
    It is hard to say if it is a fuel or oil smell. I don’t always smell it either. Any ideas what it could be? I’ve researched the site, but couldn’t really find a solution. Truck is a 2007 with the v6. Oh, and it has 307,000 miles. The smell is usually when I warm it up in the morning in my garage.
  2. Mar 15, 2020 at 7:52 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    when? where?
  3. Mar 15, 2020 at 7:56 PM
    TacTrd2007
    2007 Tacoma TRD OR
    On warm up and in the garage. I did smell it once in the cabin, but that was during the day with the windows rolled down and in traffic, so that could have been someone else’s car.
  4. Mar 15, 2020 at 7:57 PM
    0xDEADBEEF
    Thats gonna be tough to find. If you don't see anything leaking under the hood or on the pavement, I wouldn't worry about it.
  5. Mar 15, 2020 at 7:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are the valve cover gaskets leaking?
    Blockhead likes this.
  6. Mar 15, 2020 at 8:02 PM
    TacTrd2007
    2007 Tacoma TRD OR
    Yea. I’ve been searching for leaks, but haven’t found any yet. None on the ground. I looked at the fuel lines and under the hood, and nothing. The one thing I saw was fluid (which I assume was gas) on the oring of the gas cap. Not sure if that means anything, but I may just buy a new from the dealer and see where that goes.
  7. Mar 15, 2020 at 8:03 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Do you have an opem gas can in your garage? or a lawnmower?
  8. Mar 15, 2020 at 8:04 PM
    0xDEADBEEF
    Its probably fine. if its leaking, its leaking little enough that you can keep an eye on it.
    It is not leaking like the car I drove in high school, which once had the fuel tank return line pop off... :laughing:
  9. Mar 15, 2020 at 8:04 PM
    TacTrd2007
    2007 Tacoma TRD OR
    They don’t appear to be based on a visual. There is dust, nothing else.
  10. Mar 15, 2020 at 8:06 PM
    TacTrd2007
    2007 Tacoma TRD OR
    Negative.
  11. Mar 15, 2020 at 8:07 PM
    BalutTaco
    Wanted to throw a curve ball OP!
  12. Mar 15, 2020 at 8:07 PM
    TacTrd2007
    2007 Tacoma TRD OR
    The smell isn’t always around, which is odd.
  13. Mar 15, 2020 at 8:08 PM
    TacTrd2007
    2007 Tacoma TRD OR
    Would power washing the engine bay cause anything under the hood to leak gas or fuel fumes?
  14. Mar 16, 2020 at 7:07 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Possibly...others will chime in but I’ve always heard that power washing under the hood can cause issues with seals etc...especially on a truck with 300k miles
  15. Mar 16, 2020 at 7:10 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    OP I've noticed the same thing on my 2009 recently. When I warm it up in the morning but that is the only time. Haven't noticed any leaks on my end either, I was thinking the smell was a slight exhaust leak. Haven't been concerned enough to look into it yet.
