gas pedal occaisonally does nothing
Discussion in '1st Gen. Tacomas (1995-2004)' started by tarby04, Sep 21, 2023.
  1. Dec 9, 2024 at 10:13 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I removed the tps and ten re-installed it. On occasion I do the 100 gas pedal stomp. I believe you can buy a new tps now from some parts houses.
  2. Dec 9, 2024 at 10:27 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  3. Dec 9, 2024 at 10:42 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
  4. Dec 9, 2024 at 11:20 AM
    Tkoedel
    Tkoedel Member
    I did that until recently it stopped working. Changed tps and still doing it.
  5. Dec 9, 2024 at 12:38 PM
    O'Silver_Taco
    MD
    The 'apps sensor' was commonly used in late 90's dodge's with the Cummins.....
    they where notorious for going out.
    But at least you can buy another one.....
    When Toyota did same in 03/04 engines.........that sensor separate from the TB....
    is NO BUENO........not even aftermarket....
    its a national secret they're trying to keep from the Russians....
    maybe a bunch of captured Hi-lux's they need to keep out of service....
    Everybody that has an 03/04 and is lucky enough to still have it......
    will eventually fall to this......it's 'progress'....
  6. Dec 9, 2024 at 6:57 PM
    Tkoedel
    Tkoedel Member
    How is this issue actually repaired. I'm doing the same thing. What is it doing to make this work temporarily? I changed my TPS and it didn't help.
  7. Dec 9, 2024 at 7:12 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    It could be a grounding problem. These trucks are getting old, check for codes, last resort change the throttle body
  8. Dec 9, 2024 at 7:26 PM
    Tkoedel
    Tkoedel Member
    Ok thank you!
