Gas Pedal Waaaayyy To Touchy
Discussion in 'Technical Chat' started by JDN, Jul 9, 2009.
  1. Jul 9, 2009 at 2:52 PM
    JDN
    JDN [OP] New Member
    Enumclaw, Wa.
    04 Tacoma PreRunner
    I've got a 2004 3.4L Tacoma PreRunner Doublecab with a very sensitive gas pedal. All I have to do is gently press on the gas pedal and it will throw me back in my seat. Not too comfortable for the passengers either. It's been like this since I bought the truck new from the dealer but now my son is ready to learn to drive and I don't need the severe wipelash that may result.
    Does anyone know how to adjust the gas pedal so that it will require more foot pressure to accelerate and provide a smoother acceleration?
    Thanks, JDN
  2. Jul 9, 2009 at 3:44 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Try a lighter foot? idk never heard of being able to change that out. try driving a 80's model suburban...it takes like 20 lbs of pressure to push that dang pedal
  3. Jul 9, 2009 at 9:36 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    My guess is that the twitchy behavior isn't caused by the accelerator pedal, but the throttle-by-wire system.
  4. Jul 9, 2009 at 9:40 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yup i drove an 85 6.2 Litre diesel. that thing hauled but you needed to put your foot through the floor to get it to move
  5. Jul 9, 2009 at 9:42 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Move your seat back farther.
  6. Jul 10, 2009 at 1:13 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Did you luck out and get a supercharger in the beastie when you bought it?
  7. Jul 11, 2009 at 7:27 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Are you the original owner?
    If not ... There's actually a device on the market specifically designed to make throttle-by-wire systems more 'sensitive' to accelerator manipulation:
    http://www.sprintboostersales.com/whyitworks.cfm
    I'm wondering if this (or some other such modification by a prior owner) might explain it ..
  8. Jul 11, 2009 at 3:35 PM
    reg boulette
    reg boulette Well-Known Member
    ^interesting gadget but pricey!
    The accelerator sensor may be out of spec..manufacturing defect or maybe even corrosion etc. Maybe someone at a dealership with the plug-in tool can measure voltage for you to see if it is within specs. Possibly same with actuator for throttle body blade? I am assuming you've checked the return spring ( if there is one) on the pedal itself to see if it can be tightened for more resistance?
  9. Jul 11, 2009 at 3:37 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    adjust the throttle? i dont know lol maybe that can be an option.
  10. Jul 11, 2009 at 7:12 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    if its a throttle cable, cant you just ajust the cable settings?
  11. Jul 11, 2009 at 7:29 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    An '04 would still be a throttle cable. Look at the throttle body, where the cable hooks up. There should be a little slack in it, when the throttle is closed. Perhaps yours is too tight? Maybe the cables got routed wrong durig some service work, or something?
  12. Jul 11, 2009 at 7:40 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah thats what i was thinking on that. he still has the cable cause toyota didnt switch till 05. im willing to bet thats the issue.
  13. Jul 11, 2009 at 7:43 PM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    If its a cable system, it should also have a return spring, which is probably stretched, or has been inadvertently mounted incorrectly during service at some point. Look at all the linkages where the cable ends. Should be close to the end of the cable. Even if it's a throttle by wire system, it still has to have a return spring, in this case probably connected to the pedal. My bet is a weak/incorrect spring.
  14. Jul 12, 2009 at 6:46 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Just for the record - the OP's 2004 V6 is throttle by wire, not cable-controlled. The electronic throttle control system for V6's arrived during the 2003 model year.
