Gas Pedal .... why do i need to cut it???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 81shark, Aug 18, 2010.
  1. Aug 18, 2010 at 7:30 PM
    81shark
    81shark [OP] Well-Known Member
    2006 Base Access CP1
    so i was cleaning my carpets and was curious. so i got down there are started to poke around.
    this is what i found
    pedal all the way up
    and pedal down. the closest the pedal ever gets to the floor mat is a good 1 - 1.5 inchs.
    so to conclude, there is zero chance that the gas pedal is ever going to hang up on basic tacoma floor mats.
    and just to prove i'm not some dumbass, here is a pic of all three pedals. :D
  2. Aug 18, 2010 at 7:31 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Don't get it done, they will butcher your gas pedal.
  3. Aug 18, 2010 at 7:31 PM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    If you properly secure mats that were made for your truck (like factory toyota mats, the all weather tacoma mats) then you won't have issues. It's the people who put in huge 1 inch think aftermarket walmart plastic floor mats that have issues.
  4. Aug 18, 2010 at 7:33 PM
    81shark
    trust me, i'm not. never intended too. i was bored tonight
  5. Aug 18, 2010 at 7:33 PM
    jdcrowe75
    jdcrowe75 Well-Known Member
    North Florida
    2010 DC TRD OR 4x4
    Is there any chance the floor mat could slide forward? If so, it might hang up the gas pedal.
  6. Aug 18, 2010 at 7:33 PM
    81shark
    agreed. i tried a set once. they were brutal. pulled them out and said screw it. floor mats are meant to get dirty.
  7. Aug 18, 2010 at 7:35 PM
    81shark
    stock mats are held in place by two clips. unless you don't have the clips, the pads aren't going anyplace. and even if you didn't have the clips, i don't see them sliding up to the point of interfering with the pedal.
  8. Aug 18, 2010 at 7:38 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Because you're an idiot that believes anything the media can convince you of? You don't know how to turn off the key if you're stepping on the gas by mistake (instead of the brake)? You don't know how to put it in neutral? You don't even know which pedal IS the brake? You're just plain stupid?
    If you meet all these criteria, and I do mean ALL of them, then that's why you need to have someone remove your pedal and take a hacksaw to it.:D
    BUT WAIT!!! This is only the beginning. Have you ever done anything stupid in your life? Wait till you see the tools they have to fix that!
    (okay, end sarcasm now...LOL)
  9. Aug 18, 2010 at 7:42 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    The item completely ignored by the media in this whole floormat situation was the improper use of equipment. If you have multiple stacked floormats, some of which are not made for your vehicle, shit may happen.
    Concurrently, if you remove your driver's seat, reinstall it facing backward, and attempt to drive the vehicle by straddling your legs around the backrest, you may find operation of the vehicle more difficult.
    Lesson: When equipment is operated improperly, it may perform improperly. How this surprises anyone is a mystery to me.
  10. Aug 18, 2010 at 7:43 PM
    81shark
    clearly, this isn't directed at me, as i'm sure you saw the thrid pedal :lol
  11. Aug 18, 2010 at 7:49 PM
    timbo805
    timbo805 Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
    i swear im not tryng to make stuff up but a couple days ago i was passing someone and my pedal got stuck not because my trucks fault but because my fault i took the hooks out when i washed my carpet and i forgot to put them back so the floor mat whent all the way forward and made a wedge with the gas pedal it was a scary situation but with a little bit of brains you will do just fine, first i shifted into neutral but accidentally went into reverse no biggy but noticed i was reeving high 6k7k high so i turned the truck off pulled my floor mat and heard the gas pedal get unstuck took it to the dealer to make sure everything was fine and got new clips for the floor mats.
  12. Aug 18, 2010 at 7:49 PM
    05Moose
    Jim
    No it wasn't directed at you or anyone else. Just trying to provide a little humor to a ridiculous situation.
  13. Aug 18, 2010 at 7:53 PM
    Larry
    Larry CARL
    CARL
    You don't...and don't.
  14. Aug 18, 2010 at 8:06 PM
    Larry
    Larry CARL
    CARL
    Incorrect.
    There are idiots...scammers...cheats...frauds...and outright stupid sheeple in society.
    Thank the media...the government...and the lawyers.
    Lastly, thank Toyota for caving in to political correctness.
    (although I do give Toyota some slack, they are a corporation for profit...unfortunately, there are many including the aforementioned, who love to shake down any profitable corporation for their own political...financial...or ideological wants/needs)
  15. Aug 18, 2010 at 8:27 PM
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    I got the recall done. I got my pedal cut and the software fix that if the throttle is engaged and you hit the brakes, the throttle is closed so you can stop without the engine revving.
    Why did I do it? I'm happy for the software fix. The pedal? I couldn't care either way. With the pedal cut, I NOTICE NO DIFFERENCE WHEN USING IT. My foot sits mid to high on the pedal anyway, not at the bottom. So it doesn't hurt a bit to have it cut.
    Final thought: Getting this done might help with resale value later for some concerned, future potential buyer when/if I decide to sell it.
    Slightly on topic: My brother is a Dodge/Chrysler mechanic. He has seen people come in with 3 sets of floor mats. THREE!!!!!!! As all safety campaigns go they're designed to save everyone, even the dumb.
  16. Aug 18, 2010 at 8:38 PM
    wtbthree
    wtbthree Give 'er
    Will
    SC'ed 2010 DC
    3" Revtek lift, 17" FJ rims, 285 BFG KO's, sunroof, TRD piping, Wickedflow muffler, Avid step rails TRD supercharger,
    Ok people....I had this done the other day while getting rear spring TSB done. When I picked the truck up, I had forgotten about it, and I DID NOT EVEN NOTICE. NOTHING changes with the feel of the pedal, all they do is grind off the bottom corners about 1/4". Why is everyone making such a big deal out of this? It changes nothing about the truck...at all. NOT doing it will not be a good selling point. I'm jus surprised by all the "NO WAY!" responses
  17. Aug 18, 2010 at 8:52 PM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    No one is going to remember the recall and fairytale reports of stuck gas pedals in a year. Resale will be just fine.
    If the frames rust out from underneath the body in 8 years or so.....that might affect resale :D
  18. Aug 18, 2010 at 8:55 PM
    wtbthree
    wtbthree Give 'er
    Will
    SC'ed 2010 DC
    Sure, but I don't see why people are freaking out about having some plastic shaved off the pedal, not like they're replacing it w/ a postage stamp
  19. Aug 18, 2010 at 9:33 PM
    81shark
    they could glue ADD a half inch of pedal and still not have a problem with the stock mats
  20. Aug 19, 2010 at 5:00 AM
    Larry
    Larry CARL
    CARL
    Fair post. :cheers:
    OK...the idiots started the mess...then Toyota decided to cut down the pedals in a politically correct Public relations campaign.
