Gas ping when running 87 octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dan T, Nov 18, 2015.
  1. Nov 18, 2015 at 5:09 PM
    Dan T
    Dan T [OP] Well-Known Member
    Dan
    CT
    Tacoma 4 cyl
    Has anyone experienced gas ping when burning 87 octane gas. I'm talking about the 6cy. non-supercharged taco's.
    My truck with 26k on the clock seems happier with the 89 octane vs the 87.
    The manual says 87 or high.
  2. Nov 18, 2015 at 5:11 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Yes my truck runs much better with 89
  3. Nov 18, 2015 at 5:15 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I run 91 , no ping
  4. Nov 18, 2015 at 5:19 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    What year truck?
  5. Nov 18, 2015 at 5:22 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    Same here otherwise it does with 87
  6. Nov 18, 2015 at 5:26 PM
    g8erh8er
    g8erh8er Well-Known Member
    Land O Lakes, Fl
    2012 Tacoma DC 4x4 Sport
    My engine knocks like crazy using 87 thru 91 when in most gears and under load. If I floor it, no knock, but if the acceleration is gradual, it's there. There's a TSB for this condition for my year - 2012 that flashes the ECU. I'm getting it done next week. May or may not help according to the threads I've seen here.
  7. Nov 18, 2015 at 5:28 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Run a can Techron through the gas, burn off the carbon and ping will go away.
  8. Nov 18, 2015 at 5:37 PM
    Dan T
    Dan
    CT
    Tacoma 4 cyl
    The truck is a 2014. Runs good and was getting good gas mileage.
    This summer I started to notice a gas ping when lightly pressing on the gas peddle and if I took it out of "D" and into 4 it would go away. I ran a few tanks of the 89 and there was no gas ping and my mileage drop a little.
    I was curious if others experienced the same thing.
  9. Nov 18, 2015 at 5:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    have you had the ECU reflashed.... there is a TSB to reflash the ecu to fix this issue!
    Soul Surfer likes this.
  10. Nov 18, 2015 at 5:42 PM
    Soul Surfer
    Jimi
    The TSB # 0044-14 SPARK NOISE- Shows up in some 2012 -2014 1GR - FE - 6cly. Mine did the same thing. Bring it to the dealer and they will reprogram the ECM.
  11. Nov 18, 2015 at 5:52 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Mine pings with 87, 89, and 91 octane pump gas, but only in Drive at idle (engine under load from being in gear). I suspect a minor tuning issue on our trucks, so it would be probably be best to research the TSB.
    However, something I have noticed that my 1GR has the most power on 89 octane. 87 and 91 feel the same in terms of acceleration (which makes sense when you think about the fuel window our engines operate on stroke), 91 being much smoother performance. So I've been running 89 for the past couple months.
  12. Nov 18, 2015 at 6:00 PM
    Soul Surfer
    Jimi
    I also run 89 and add 1 oz of 360 staybill to 5gal. Of gas. The truck runs smooth and idles great.
  13. Nov 18, 2015 at 6:00 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    89 and you'll be fine. Just be glad you don't live in California $$$$. Also try changing your plugs. I'm sure you have 3 densos & 3 ngk's. Toyota does that from the factory.
  14. Nov 19, 2015 at 5:51 PM
    Dan T
    Dan
    CT
    Tacoma 4 cyl
    Thanks for the TSB info and the number. I'll call my dealer and see if they will look at it.
    The truck does seem to run nice on the 89 but I do miss the extra 30 miles (estimated) pre tank.
  15. Nov 28, 2015 at 9:20 AM
    Dan T
    Dan
    CT
    Tacoma 4 cyl
    Update: The dealer did the TSB update and reset the ECM and there does seem to be an improvement but I'll know better when I try to use the 87 octane grade gas. Thanks for mentioning the TSB.
