Gas pump lever lock early release..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, Aug 2, 2010.
  1. Aug 2, 2010 at 3:43 PM
    Karo
    Karo [OP] Well-Known Member
    Karo
    La Crescenta, CA
    06 PreRunner TRD Sport
    Grill
    I don't know if anyone else has experienced this, but every time I fill up my tank, the gas station nozzle (all different gas stations) releases after a few seconds while it's on lock. Is there something wrong with my gas tank or the hose that's transporting gas to the tank? Has anyone ever experienced this or is it just me?
    Also, I only experience this with my truck. My friend has a Tacoma (same year, same model) and he has never experienced this before. Neither has anyone I know.
    I noticed this happening about 2 and a half years ago and didn't know whether it was a big deal. Any help?
  2. Aug 2, 2010 at 3:44 PM
    Karo
    Karo
    La Crescenta, CA
    Grill
    *****Oh and this goes for when the tank is not almost full. It happens every time.
  3. Aug 2, 2010 at 3:47 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Yeah I have noticed this too, but not all the time.
    I'm not sure how those releases work, but I wonder if it has to do with how you position the nozzle?
  4. Aug 2, 2010 at 3:48 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Mine does the same thing. It gets frustrating, but I just figured it isn't that hard to press the lever again.
  5. Aug 2, 2010 at 3:48 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    I think it depends on the pump. It happens to me all the time at a certain gas station, but others work just fine. It sure as hell is annoying tho.
  6. Aug 2, 2010 at 3:49 PM
    topgun155
    Zack
    I think it might be the postion. I have tried pulling up on the rubber cover that goes over the hole and it seems to work better.
  7. Aug 2, 2010 at 3:49 PM
    TRDfly
    TRDfly Well-Known Member
    Traverse City, MI
    Silver 07 DC, TRD off-road....it's the bomb!!
    DRL, Black Headlight mod, H.I.D's, Wet Ass Seatcovers, White instrument cluster, Illuminated 4x4 switch.
    I find I can pump almost another 2+ gallons in.
  8. Aug 2, 2010 at 3:50 PM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    I have it happen too. I even have had it "pop" every second or so. Got so annoying. I left and went to another station and had no problem there.
  9. Aug 2, 2010 at 3:53 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Yeah...I have noticed if I re-position it, it won't do it again in-till it fills up all the way.
    And on a side note just in case anyone doesn't know, after the tank fills up and the pump clicks off, don't top it off! You can wreck your expensive charcoal canister and throw a code.
  10. Aug 2, 2010 at 4:11 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    hey at least your gas pumps are still able to lock. in MA it is illegal to lock the pump for continous use. in october, they are taking away the bottom handle so theres no way to prop it :(
  11. Aug 2, 2010 at 6:48 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    Mine seems to work most reliably if I stick the nozzle in all the way, then pull it back out just a little, maybe 1/4" or so. Alsol I only put the handle lever on the first notch, so it fills up at the slowest rate.
    But different nozzles are different, not long ago I was filling up and the nozzle did not shut off, it just spewed gas all over after it got full, lucky i was standing right there, I still left a gallon on the ground and down the side of my vehicle.
  12. Aug 2, 2010 at 6:53 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Daniel
    Utah
    08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Mine used to do this on occasion, and I found it only would do it if I put the fill nozzle all the way in. When I insert the nozzle, I always slide it back out an inch or two and haven't had a problem since. It has to do with the new anti syphon fuel tank filler necks they are using in the newer vehicles.
  13. Aug 2, 2010 at 6:55 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Mine has nver done that, but my moms Lexus, and my brothers Avalanch do. Idk why.
  14. Aug 2, 2010 at 7:43 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    It depends on the station, the ones fitted with the newer nozzles won't do it. The Tacoma gas tank filler has a "goose neck" design therefore if you pump the gas too fast it can back up on you. As others have stated if you experience this just pull out the nozzle a bit and pump at the slowest rate, it's kinda annoying but at least those crooks can't steal gas out your tank.
  15. Aug 2, 2010 at 7:58 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    I have that happen when I'm in areas with stricter regulations about gas fumes. In places with the plastic/rubber nozzle covers that reclaim some of the fumes I have to push the handle of the nozzle slightly down (pivoting and raising the tip in the filler tube slightly) to avoid this.
    In areas that don't mandate the vapor reclamation gear I don't have this problem.. at least not consistently.
  16. Aug 2, 2010 at 8:56 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    I know exactly what your talking about! some nozzles dont like the angle they set at when left hanging. but if you hold it and lock it at the right angle it will be fine. sometimes i have to adjust the stupid thing 2 or 3 times before i get it to set right. its ridiculous. its mostly with a certain type of vapor lock nozzle ive noticed.
  17. Aug 2, 2010 at 9:02 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    x2 I hate it. I remember when we had them it was way better than having to stand there and hold it. was convenient when my dad had his 1st gen and we had to clean the windows
  18. Aug 2, 2010 at 10:15 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    When people top off their cars, they overfill and liquid gas gets into the vapor release and jams up the pump nozzle, makes it act stupid. Don't top off.
  19. Aug 2, 2010 at 10:56 PM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    In my neck of the woods we haven't had lockable nozzles for years...like 10 years or more. You have to stand there and hold the trigger the entire fill up. Makes me want to light up a smoke to pass the time..:D
  20. Aug 2, 2010 at 11:31 PM
    YumaTRD
    YumaTRD 22R...Legends never die
    David
    El Cajon, CA hometown Yuma, AZ
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO's
    Sig!!!!
