Gas siphoning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HawkShot99, Nov 2, 2016.
  1. Nov 2, 2016 at 10:02 AM
    HawkShot99
    HawkShot99 [OP] Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Is it possible to siphon gas out of the tank of my Tacoma? I do it every fall to my motorcycle and mowers no problem but they have a big open filler neck.
    I think I may have gotten some bad gas, as my mileage is plummeting for no reason on this tank of gas. I'd like to siphon it out into jugs and refill. Not sure if the neck truly prevents this or what but I couldn't get a hose down into the tank.
  2. Nov 2, 2016 at 10:06 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I think you can get a hose down it. Not sure you want to. Not sure about the Tacoma design but I have seen fuel gauge senders messed up by siphoning. If it is just MPGs and not performance then throw some additive in there and tough it out.
  3. Nov 2, 2016 at 10:10 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    could just be the switch to winter fuel, or depending on how many miles you have, have you changed your plugs etc...
  4. Nov 2, 2016 at 10:11 AM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    Winter fuel????? That's funny!
  5. Nov 2, 2016 at 10:12 AM
    jpereira2
    Massachusetts
    Summer blend gasoline is more difficult to produce than winter blend gasoline, which is why gas prices tend to rise along with the temperatures. But in the winter, when evaporation is less of a concern, gasoline is made with a higher Reid Vapor Pressure
    Jester243, digitaLbraVo and Noelie84 like this.
  6. Nov 2, 2016 at 10:14 AM
    NewRider
    Travis
    '87 4runner
    Never heard that one before
    jpereira2 likes this.
  7. Nov 2, 2016 at 10:16 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Winter gas typically yields lower MPG's. I went from averaging 21-22 MPG's to 18-19 MPG's on one tank when the local station got their delivery of winter gas.
  8. Nov 2, 2016 at 10:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    moondeath, eon_blue and jpereira2 like this.
  9. Nov 2, 2016 at 10:25 AM
    stump jumper
    Bill
    Texas
    colder air temps will drop the mpgs as much as the fuel. In DFW I notice a slight drop when they switch over but it drops a lot more when we have a cold snap. In this area we can be in 60s one week and 20s the next during winter.
  10. Nov 2, 2016 at 10:29 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    wait, "so I'm getting bad gas mileage with this gas so I'm going to take it out (giving you 0 mpg for every gallon, which you have already paid for, you remove btw), buy more gas and replace it" I don't see how this would help anything.
    Shwaa, eon_blue and WildLand like this.
  11. Nov 2, 2016 at 10:30 AM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Not possible to siphon gas unless you pull the tank and rip out the fuel filter. There are antisiphon valves in each new vehicle to avoid spillage in a roll over
    koditten likes this.
  12. Nov 2, 2016 at 10:31 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yep, i have always believed that temperature difference was the reason for poorer mpg in winter.
    It takes more energy to combust gas at 10 degrees F. Than it takes to combust gas at 80 degrees F.
  13. Nov 2, 2016 at 10:32 AM
    yota243
    E.J.
    north Alabama
    also to keep things a nice 14.7:1 afr, considering colder air is denser it requires more fuel for the amount of air you are putting in during cold temps.
  14. Nov 2, 2016 at 10:32 AM
    koditten
    Kirk
    Central Michigan
    Most gas thieves just punch a hole in the tank and drain into an oil drain pan.
    It's quiet, and they don't have to wait around for the gas can to fill. They just come back later when the cost is clear.
  15. Nov 2, 2016 at 10:33 AM
    eon_blue
    Azusa, CA
    haha I was thinking the same thing. He's losing even more money but not using the gas he paid for at all. Just burn off this tank and use a different gas station.
    yota243[QUOTED] likes this.
  16. Nov 2, 2016 at 10:34 AM
    Noelie84
    Noel
    Wales, Maine
    True, but my local station switched to winter gas maybe 3 weeks ago and our temps were in the 60's & 70's still at that point, but I still lost the MPG's. My route and driving habits haven't changed.
    I actually noticed the difference as soon as I tanked up, because I have the instant mileage readout on the truck and run the same route every morning, and when I got onto the highway and set my cruise I was averaging about 2mpg's less at the same speed and similar temperature. :notsure:
  17. Nov 2, 2016 at 10:35 AM
    HawkShot99
    Kingston, NY
    I have not driven at all this tank different than any of my past tanks.
    If I got watery gas I'd preference to not send that through my engine. it's not so much about the lost mpg's they are just the visible sign. I'd prefer to not damage a engine with water gas.
    eon_blue likes this.
  18. Nov 2, 2016 at 10:42 AM
    yota243
    E.J.
    north Alabama
    does it drive differently? as in acceleration or just an overall lack of power at any given rpm? water and gas don't mix, so if you have "watery gas" it would actually be the you have water under the gas in your tank. now some of both could get into the pump and into the injectors if the levels were right but you would definitely notice a change in drivability. and if that is the case just adding better gas wont solve this problem as the water will always be in the tank until you drain it completely (or run it dry which wouldn't turn out well) could there be a chance that maybe you put e-85 in your tank, that would lead to about a 35-40% lower mpg.
  19. Nov 2, 2016 at 11:24 AM
    Smitty93
    Smitty93 Well-Known Member
    Jacob
    Chandler, AZ
    2008 Off Road DCSB
    I'd would take a look at your air filter, MAF sensor and plugs before going through the trouble of trying to siphon gas
  20. Nov 2, 2016 at 11:30 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Youve also claimed changing diff fluid is a waste of money. lol
    NewRider[QUOTED] likes this.
