gas smell at start up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glamis, Sep 2, 2012.
  1. Feb 3, 2018 at 6:41 PM
    ShuggieTaco
    ShuggieTaco Well-Known Member
    2011 Tacoma
    1.5" level front
    Crap. Should I take one out and check the gap? The auto parts guru told me not to go with champion or Bosch. Said denso or NGK were best for Toyota. Said denso makes NGK. The ones i got are 60,000 mile iridium. Wish i had checked the gaps. Could that be causing the gas smell or is the high flow filter more likely the cause?
  2. Feb 3, 2018 at 6:45 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    front 02 sensors will read and send info to the ecu and regulate the ratio back to 14.7
  3. Feb 3, 2018 at 6:47 PM
    inwood customs
    Dave
    have a v6?
    run oem coppers
    i4, run irid
    v6 interval is 30K, and some people have had issues running irid in the naturally aspirated 1gr v6
    moondeath likes this.
  4. Feb 3, 2018 at 6:48 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Supposedly Toyota engines are very particular about the plugs. The basic plugs that Toyota recommends are the best. NGK and Denso are recommended, but not the iridium. The NGK plug part # is LFR6C11. If for some reason it wasn’t burning efficiently it may cause some gas smell, but I couldn’t say if that’s your problem.
    inwood customs likes this.
  5. Feb 3, 2018 at 6:49 PM
    moondeath
    Pa, Gardners
  6. Feb 3, 2018 at 6:52 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    I always experienced the same thing when I don't drive it enough.
  7. Feb 4, 2018 at 12:11 PM
    ShuggieTaco
    2011 Tacoma
    1.5" level front
    Sooo should i take the iridiums out? I was told they were fine for my truck. Is there potential for damage to the engine? I was told to atleast run double platinum bc that’s what came from factory in my truck.
