Gas smell during idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Texastaco2010, Sep 2, 2019.
  1. Sep 2, 2019 at 6:29 AM
    Texastaco2010
    Texastaco2010 [OP] Well-Known Member
    2010 TRD Tacoma
    i have a 2010 Tacoma 4.0 and when I start it it runs fine but when letting it idle it smells like fuel what are some possible issues to look at
  2. Sep 2, 2019 at 6:53 AM
    Taco-mama
    Taco-mama Well-Known Member
    2015 DCSB Prerunner
    Lift the hood and see if the injectors or fuel rail is leaking.
    TomTwo likes this.
  3. Sep 2, 2019 at 7:00 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Climb all over your truck and use your eyes and nose. Might sound silly, buy it works for locating issues.
  4. Sep 2, 2019 at 8:37 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Completely agree with this.
    TXpro4X4 and Hobbs[QUOTED] like this.
  5. Sep 2, 2019 at 8:42 AM
    Texastaco2010
    2010 TRD Tacoma
    Alright I’ll give a look today. I can also smell it towards the back of the truck as well
  6. Sep 2, 2019 at 8:48 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    take a look under the bed, on top of the gas tank theres a seal where the fuel pump sending unit is mounted sometimes they will leak it will look wet around it, u can smell gas when u exit the car door quickly
    Gunshot-6A likes this.
  7. Sep 2, 2019 at 8:59 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Mine runs on gas.
  8. Sep 2, 2019 at 9:59 AM
    Taco-mama
    2015 DCSB Prerunner
    I like the smell of gas!
    dsespinal408, TXpro4X4 and Hobbs like this.
  9. Sep 2, 2019 at 10:06 AM
    Texastaco2010
    2010 TRD Tacoma
    Is it a doozy to replace ?
    TXpro4X4 likes this.
  10. Sep 2, 2019 at 10:18 AM
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    It’s called a lock ring. I’m not sure on the 2010, but if your tank straps aren’t shot, it shouldn’t be too bad to drop the tank and replace the lock ring.
  11. Sep 2, 2019 at 11:05 AM
    BillsSR5
    bill
    2014 SR5
    theres a thread floating around in 2nd gen forum on how to DIY, see if I can dig it up
  12. Sep 2, 2019 at 11:08 AM
    BillsSR5
    bill
    2014 SR5
  13. Sep 2, 2019 at 12:41 PM
    lgrlife
    lgrlife Member
    Al
    Rodeo, Ca
    05 Toyota Tacoma 2.7l Base ACLB
    Blackout mod - LED Headlights - Unifilter mod - Inter. Wiper switch mod - Pop n Lock tailgate latch with moded cam.
    Does anyone know if you can get the the fuel pump assembly by removing or sliding the bed?
  14. Sep 2, 2019 at 12:47 PM
    BillsSR5
    bill
    2014 SR5
    I did that on my GEN1 truck I removed the bed bolts unplugged the light harness and me and another guy slide the bed back until I could get to that assembly area, I would definetly say it was easier than dropping the fuel tank, now on the 2nd gen bed has those rusted torx head ass bed bolts now this can be a big problem getting them off from what iread.
    cedarpangolin likes this.
  15. Sep 2, 2019 at 6:55 PM
    lgrlife
    lgrlife Member
    Al
    Rodeo, Ca
    That’s what I figured would be the easier way. I may try tackling this by going this route. I’m not to worried about the Torx bolt because rust isn’t a big problem here.
    BillsSR5[QUOTED] likes this.
  16. Sep 2, 2019 at 7:08 PM
    cedarpangolin
    Christian
    more power to ya. I would advise just dropping the tank, its less time, labor, and you dont have to fight with lining up the box after moving it... I have several friends who removed the bed to do rustproofing on the frame, and it was a nightmare to get it lined up properly, it was always offset to one side by an inch or so. They finally got it right, but its a lot of unecessary work if you can just jack it up and drop the tank.
    Either way good luck
  17. Sep 3, 2019 at 6:25 AM
    BillsSR5
    bill
    2014 SR5
    if you can get the Torx screws out that's really the work, go underneath unplug the lights and just slide the bed back or completely remove it also you may have unhook the gas filler tube somehow, that's way better than dropping the tank anyway u look at it. I replaced the fuel pump in mine while I was at it since I had 200k miles and replaced the seal/gasket at the same time it was leaking and smelling gas.
  18. Sep 3, 2019 at 6:30 AM
    BillsSR5
    bill
    2014 SR5
    when I did my bed I just finger tightened all the bed bolts, and adjusted the bed to where I liked it, then tightened them up, would have been a real nightmare to deal with a tank full of gas and unstrapping it and the trying to unplug all the hose connections, with the bed just get out the Torx screws(can be a MOTHER), unplug the tail lights,get out of the way, with plenty of room to work
  19. Sep 3, 2019 at 6:49 AM
    BillsSR5
    bill
    2014 SR5
  20. Sep 3, 2019 at 6:53 AM
    BillsSR5
    bill
    2014 SR5
