Gas tank completely empty when at the E line?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, Jul 28, 2010.
  1. Aug 12, 2010 at 8:37 PM
    #101
    The Philosophizer
    The Philosophizer Well-Known Member
    Alex
    South Bay
    10 Tacoma
    nothing yet!
    so i was driving to arizona a few weeks ago and my needle was even with the end of the gas gauge.
    i was pulling jetskiis and made it 45 more miles before i ran out of gas. i was pretty stoked. haha
  2. Aug 12, 2010 at 9:41 PM
    #102
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I had a "fuel problem" in a aircraft once, scared me sh!tless as a kid ... any gas gauge never gets below 1/4 now ... never.
    Crow Horse likes this.
  3. Aug 13, 2010 at 7:13 PM
    #103
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Been watching my gas needle real close, and have been doing my normal weekly driving (city/ hwy. combined). This tank I got 16.5 mpg...
    Here are what the numbers are (needle right over the fuel level marks, not above, not below) Tank filled fully and trip odometer reset:
    *Needle at 3/4 mark at 80 miles (1/4 tank of gas, per the gauge) but I used 4.8 gallons (not 5.25), leaving 1/2 gallon 'in reserve' (the difference between the gauge indicated amount and the true gallon amount).
    *Needle at 1/2 mark at 155 miles, but I used 9.4 gallons (not 10.5), leaving 1 gallon 'in reserve'.
    *Needle at 1/4 mark at 220 miles, but I filled up with 13.3 gallons (not 15.75), leaving 2 1/2 gallons 'in reserve'... I got to a gas station at 222.6 miles to fill up as close to 1/4 tank on the gauge as possible.
    If I where to continue driving at 16.5 MPG I would run out at 346.5 miles (16.5 mpg x 21 gallon tank).
    The difference between the needle at 1/4 mark and empty is 126.5 miles.
    So, as the gauge drops...
    Full to 3/4 = 80 miles (4.8 gallons)
    3/4 to 1/2 = 75 miles (4.6 gallons)
    1/2 to 1/4 = 65 miles (3.9 gallons)
    1/4 to 'E' = 85.5 miles (5.2 gallons)
    From others and my past experiences, we have 2.5 gallons left when the needle is firmly over the 'E'...
    So, 'E' to empty = 41 miles (2.5 gallons)
    While your mileage may differ, the gallon level in the tank should be about the same when the needle reaches the different levels...
    Full mark is 21 gallons in the tank
    3/4 mark is 16.2 gallons in the tank (4.8 to fill)
    1/2 mark is 11.6 gallons in the tank (9.4 to fill)
    1/4 mark is 7.7 gallons in the tank (13.3 to fill)
    Empty mark is 2.5 gallons in the tank (18.5 to fill)
    Multiple the gallons above by your truck's MPG to get the miles for each level of your tank.
    Let's see if we all have fuel gauges that read the same way!
  4. Aug 13, 2010 at 7:40 PM
    #104
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Great post David. :)
  5. Aug 13, 2010 at 10:14 PM
    #105
    David K
    Thanks... so top your tank, zero your trip odo., and note the mileage when the gas gauge is dead over the different points... top a 1/4 tank (or E if you dare) and calculate the mileage.
  6. Aug 13, 2010 at 10:17 PM
    #106
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I ran mine down so low last nite that the light was still on when I put $6 in it.
    On fumes mine takes 17 gals and thats even up in the neck.
    Got 358 miles.
  7. Aug 14, 2010 at 8:21 AM
    #107
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    If you calculate each one of my 1/4 tank mileages and divide it by the avg MPG for that tank, you will get the approximate gallon amount in the tank.
    Now i went and did that for all of them and these are the average amounts you have in each 1/4 of the tank...trust me on this. the numbers are in front of you...
    5.475
    4.021
    4.499
    2.883
    now most of my bottom 1/4 tank mileages were near the lowest they could be so that number would be more accurately represented as 3 Gals.
    when you take the averages that are in yellow you get slightly different numbers but that is because the average tank miles factor in the 1st two tanks in which i did not record the avg MPG. however, the difference is slight and here are those numbers as well...
    5.375
    3.954
    4.389
    3.036
    Sooooooo in the end you actually have about
    5.5 in the E to 3/4
    4 Gallons in the 3/4 to 1/2
    4.5 Gallons in the 1/2 to 1/4
    3 Gallons in the 1/4 to Empty
    Then 4 more gallons after the light to give you a grand total of 21 :)
  8. Aug 14, 2010 at 9:46 AM
    #108
    David K
    So gj, that means your gauge is way different from mine.
    E to empty: your figures have 4 gallons and mine has 2.5 (off by 1.5)
    1/4 to E you have 3, and I have 5.2 gallons (off by 2.2)
    1/2 to 1/4 you have 4.5 and I have 3.9 (off by 0.6)
    3/4 to 1/2 you have 4 and I have 4.6 (off by 0.6)
    F to 3/4 you have 5.5 and I have 4.8 (off by 0.7)
    Have you really pulled up to a pump when your needle is firmly on the E line and put only 17 gallons in? I am always putting 18.5 in at that point.
    Anyway, I guess each of us needs to do this test to see how our gauge matches the actual amount of gas in the tank.
  9. Aug 14, 2010 at 9:51 AM
    #109
    gjbonner
    Guy
    Northern Idaho
    well my E light comes on a little bit before the needle gets to the E mark.
    I only go to the E light. I still have about a Gallon and a half before i get to the E mark.
    our numbers there for after E light are the same.
  10. Aug 14, 2010 at 10:01 AM
    #110
    gjbonner
    Guy
    Northern Idaho
    it seems like our numbers are really only off by about .5 gallons on all the tanks... if you add our numbers from full to 1/4 we are only off by a total .6 or so not bad if you ask me.
    you are talking about less than 10 miles per 1/4 tank which is an acceptable margin of error when you consider we are paying attention to our needle on a hashmark... and when is it that we decide it rests firmly on the mark? from how we set in our seat it could look a little different from another guy...i make sure to try and look a the gauge with my head in the same position every time because that can change how it looks. the top 1/4 can be off due to the way you top yours off. i go to the 1st click, wait 10 seconds and then go to the next click.
    Edit: You also have to be careful o when you take your reading. if youve just gone up or down a hill it takes a few miles to let the float level back out to the appropriate reading. many factors come in to consideration here but i think we have it down to the .5 gallon with our figures...
  11. Aug 14, 2010 at 10:25 AM
    #111
    gjbonner
    Guy
    Northern Idaho
    One more thing to think about...how much data have you collected?
    because if you are not getting consistent mileage in all of the 1/4tanks then you can be off a bit. i have data for over 10 tanks. you really need a lot of data or you could be off a bit.
    its hard to take an average mpg for the whole tank and divide a certain 1/4 tank by it to get the gallons if that specific 1/4 of a tank was actually a really poor mpg. this is why i've been collecting data...and a lot of it.
    I will continue but im going to start topping it off till it is completely full and find out what is the most i can stuff in to the top 1/4 of the tank.
    I will go till the e light comes on, fill up and then see how far it goes above my other fill ups when i only went to the second click. i will also collect data on how many miles i get in that tank and then be done with it.
    I have one right now but i only have partial data but I hope to eventually have a little laminated card in my visor that hs my high/low and avg 1/4 tank calculations so i'll never have to wonder...i will KNOW how much time i gt left should a bad situation arise one day:)
  12. Aug 14, 2010 at 10:37 AM
    #112
    David K
    Well, we could just top the tank at each level and note the gallons put in... but this is not that important... as long as we know there is gas beyond E... at least 2.5 gallons from repeated times I have filled up at E.
    Since I did fill up at 1/4 tank, no light... However, my light comes on when there is about 4 gallons in the tank (at E there is 2.5 gallons and at 1/4 there is 7.7 gallons in the tank).
    The mileage doesn't matter, we all get different miles per gallon... the gauge accuracy is based on the gallons in the tank. We are using our mileage to estimate the amount of gas at each level of gauge reading, except when we fill up.
    I do look close at the needle and confirm its position... and sure there are a few miles where the needle stays over a mark before you notice it move. This is all an approximation.
    Thanks for your input... always fun to play with our trucks!
  13. Aug 14, 2010 at 11:01 AM
    #113
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    I never run mine below a 1/4 of a tank
  14. Aug 14, 2010 at 11:37 AM
    #114
    David K
    So, how many gallons go in when you are at 1/4 tank???
  15. Aug 14, 2010 at 4:31 PM
    #115
    2006_TOY_TACO
    2006_TOY_TACO Well-Known Member
    Los Angeles
    06 White Prerunner TRD Access Cab
    MagnaFlow Muffler, American Racing Chamber Rims Teflon Black, 2" Front Readylift Suspension Lift, Black Badges.
    Lowest I've ever had it....wasnt sure if id make it the the gas station. When i turn off the key the needle still goes a bit closer to the E though...so im not sure how much more i had.
  16. Aug 15, 2010 at 10:17 AM
    #116
    David K
    Again... HOW MANY GALLONS to fill it up? That will tell you how much you had left... and how in the world do you average only 10.3 mpg??? A V-8 in four wheel drive can do better!
  17. Aug 15, 2010 at 10:25 AM
    #117
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
  18. Aug 15, 2010 at 10:27 AM
    #118
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    You have around 3 gallons after the light comes on.
  19. Aug 15, 2010 at 5:22 PM
    #119
    David K
    We know... it is 3-4 gallons. What we would like to see is documentation... that is what this thread is about... documenting the relation between the gas gauge and the actual gallons in the tank. '2006 Toy Taco' just told us (above) the gauge was at the lowest ever... but failed to add the important data of HOW MANY GALLONS the tank took to fill. That would tell us how much was left in the tank when the needle was THAT low...
    Have a nice day!
  20. Aug 15, 2010 at 5:50 PM
    #120
    2006_TOY_TACO
    Los Angeles
    Sorry guys. Wasn't asking a question, just posting a picture. I know how many gallons the tank is and that i have about 3.5 left when the light comes on. I didn't fill up my tank after I took the picture so I don't know how many gallons It was. I let it run low like that again and update with gallons.
