Gas Tank Fills slow
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bluewave, Dec 28, 2020.
  1. Dec 28, 2020 at 4:37 PM
    bluewave
    bluewave [OP] Well-Known Member
    Hawaii
    SR5 Tacoma
    A couple down and out locals ran out of gas in a remote location so I stopped to help out and let them siphon some gas from my 2017 Taco.
    Little did I know the 1/4 tube they used effed up the flapper valve or something so when I fill my tank I can only pump gas at very light pressure for a few seconds at a time and it shuts off...
    Has anyone heard of this or know the fix??
  2. Dec 28, 2020 at 4:46 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Get a new fill valve? Or start doin the ole poke n prod, fonzi routine with a screwdriver? I'm surprised they were able to get fuel from the tank.
    Tacospike likes this.
  3. May 1, 2021 at 3:50 AM
    bluewave
    Hawaii
    SR5 Tacoma
    Help please... Replaced the fuel filler neck but the slow fill problem persists. Search everywhere for a rollover check valve for a 2017, but it doesn’t exist. It seems this may be part of the tank,....will I need to replace tank?
  4. May 1, 2021 at 4:27 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Try dealer . it may or may not be expensive. At least they can troubleshoot . Sometimes, $hit happens when you're just trying to help. Hope you can get it fixed
    Hairless_Ape and Chew like this.
  5. May 1, 2021 at 4:43 AM
    Fpc187
    Fpc187 Well-Known Member
    That’s the kind way of your tacoma telling you not to stick stuff down her throat...lol
    Just joking I hope you get it figured out before too long bud...sucks even worse because you were just trying to help someone else out
  6. May 1, 2021 at 6:04 AM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    Good deeds are usually punished.
  7. May 1, 2021 at 9:24 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Sounds like the tank is not able to vent while filling.
    Try taking a look at the vent hose if you can.
    bulalo likes this.
  8. May 1, 2021 at 9:42 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Try taking the truck for a rough bouncing ride .
    SandyTaco4x4 likes this.
  9. May 1, 2021 at 10:03 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It could be the vent valve or “refueling valve” is stuck.
    Or possibly the evap canister is saturated with fuel.
    Unfortunately, this is another situation where helping someone else, cost you.
    I know the feeling, I’ve been on both sides. I will commend you for being a nice guy and actually trying to help someone in need. Next time, you would be better off bringing the person fuel. A fuel can is cheaper than a repair bill on your truck.
    @Bishop84
    bluewave[OP], Chew and ktbell444 like this.
  10. May 1, 2021 at 10:12 AM
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    It’s not the roll over valve, that is usually on top of the tank and has no effect on filling. There should be a plastic flapper in the filler tube or connected parts (it may be stuck on good to either of the connection points). This flapper acts to shut the pump off by closing when fuel starts running up the neck. Check that.
    The EVAP “could” cause the issue by not allowing the tank to vent. You would also notice a loud “pshhh” noise after running the Taco as the tank cannot vent. This is highly unlikely to be harmed. Most likely the tube was forced in and broke the flapper apart. Pull the fill tube and check for debris.
    bluewave[OP] likes this.
  11. May 1, 2021 at 2:26 PM
    bluewave
    Hawaii
    SR5 Tacoma
    It seems that this would be true for other than 3rd Gen, I cannot locate a part # for this, on another forum someone posted it's part of the tank and not a separate part. Taking back to mechanic to drop the tank.... maybe the valve can be moved back into place, if not a new tank is about $570...
  12. May 1, 2021 at 2:45 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I usually pull a lower line and cycle the gas through to fill fuel. Never liked the idea of shoveling stuff down the filler but also rarely have a siphon or pump
  13. May 1, 2021 at 3:08 PM
    Bishop84
    Bishop84 Well-Known Member
    It's 100% the flapper, you're gonna have to drop the tank and break it off. You can't replace it, but its not critical.
    Kev250R and TnShooter like this.
  14. May 1, 2021 at 3:33 PM
    OrangeRa1n
    Houston Area
    TRD-Offroad 2021
    Fair enough :) This is all going off the assumption that these issues were a result of the siphoning. I had to replace a similar part on my Miata due to the same issue, but after looking at parts diagrams I don't know if our Tacoma's have an anti-siphon/fuel-shut-off value?
    Since we are filling an enclosed container, as fuel enters air must escape. Gas pumps know when to shut off based on pressure (or technically vacuum inside the pump handle). By using the venturi effect, the pump uses the air pressure coming out of the gas tank, and when this pressure decreases, the pump shuts off. So what can cause issues filling the tank? First, the air cannot escape solely out of the filler neck. If this occurs, the fuel going into the tank has to fight the air coming out which results in gas overflowing the filler tube and essentially blocking the air pressure to the pump causing it to shut off. This is where the EVAP system comes into play. As you drive around (remember, the exhaust system is below the tank) or park in the sun, the fuel tank heats up. If this pressure is not released, the tank could expand (which is not a good thing). We could solve this issue by venting the gas fumes out into the atmosphere, but this isn't very good for the environment so we have an EVAP system. Basically, the fumes travel through a one-way valve from the gas tank to a charcoal canister that "soaks" the residual fuel and vapors so that they do not pool up. From there, they travel from the canister in the rear of the truck to the intake where they are burned up.
    Usually, a broken flapper will cause the pump to shut off instantly, while a tank venting issue will allow you to pump for a bit. While it could be a full EVAP canister (this is why you never fill past the first click at the pump, the gas has nowhere to go but into the EVAP system or back into the pump), the gas will usually vaporize after a few days and would not be related to the potential cause. There are more things at play, but this is the gist of the system.
    bulalo likes this.
  15. May 1, 2021 at 3:34 PM
    OrangeRa1n
    Houston Area
    TRD-Offroad 2021
    Where is the flapper located? On the tank inlet?
    I also find it strange these strangers had a hose to siphon gas on them. It sounds like they were pretty forceful with your Taco.
    bulalo likes this.
  16. May 1, 2021 at 5:47 PM
    TnShooter
    Deogee
    STOCK
    Thanks man.
    I hated to tag you. But I figured you would know.
