Gas tank/fuel pump not correct??
Discussion in 'Technical Chat' started by micah323, Nov 27, 2020.
  1. Nov 27, 2020 at 9:06 AM
    micah323
    micah323 [OP] Well-Known Member
    Hi. A few months ago my truck stalled while having 1/2 tank. Dealer found tank empty and replaced fuel pump assembly
    my gas gauge has been spotty since. I just got 33 tires and lift and at 332 miles was still showing 1/4 tank
    decided to fill up because didn’t seem right. Pump took 21.0 gallons to fill
    if I am correct second gen has 21.1 tank so looks like I almost ran out of gas
    am I correct on this? Feeling like I got a faulty fuel pump replacement
    thanks
  2. Nov 27, 2020 at 9:12 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Close, 21 gallons is the capacity. But yes you were waaay too close. Never messed with it on these trucks but your fuel gauge is definitely wrong and not just a little bit. Make them take it back if you just recently had the work done.
  3. Nov 28, 2020 at 6:36 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Not the pump. Could be a faulty sending unit or bad fuel gauge. I don’t believe the sending unit is part of the pump.
  4. Nov 28, 2020 at 6:59 AM
    micah323
    I thought it’s part of it. When I ran out of gas with half tank showing dealership replaced fuel pump saying it was something in the assembly
  5. Nov 28, 2020 at 7:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    While that may be correct, it's not the 'pump' that's bad. Its the sending unit component of the assembly.
    Or as said, it could be the dash gauge.
    Either way, back it goes for an improper repair. Either a faulty part or faulty diagnosis.
    Wyoming09 likes this.
  6. Nov 28, 2020 at 7:22 AM
    gotoman1969
    It does look like an assembly. Could be when they installed they bent the little float arm for the sending unit or could still be the gauge. Dummies should have confirmed at time of install the gauge went to empty and full.
  7. Oct 8, 2022 at 9:47 PM
    Batmobile1147
    Batmobile1147 Active Member
    2012 Double Cab Sport 4wd Long bed
    I’m having this issue with my 2012 sport. I keep running out of gas but the guage says I have gas. Usually between 1/4 & 1/2 when I run out. Very frustrating… did you find a solution? I’d like to be able to accurately know how much gas I have. Kind of important
  8. Oct 8, 2022 at 9:49 PM
    micah323
    I have not. Should have taken back to dealership who did fuel pump, but now too much time has passed
    my guaige works fine till it hits quarter tank. So no I just make sure to fill up before 300 miles and reset my trip after each fill up
  9. Oct 8, 2022 at 10:24 PM
    Batmobile1147
    Aha, thanks… I have too many things to remember these days. Feel like I’ll keep running out if I don’t fix it or find a better solution. It really messed my day up
  10. Oct 9, 2022 at 8:11 AM
    MR5X5
    MR5X5 Well-Known Member
    ...another good reason to pick up an ultra gauge, or scan gauge. Displays remaining fuel accurately to a couple 10ths of a gallon.
    RedDemolisher likes this.
  11. Oct 9, 2022 at 8:17 AM
    02hilux
    Planet: EARTH
    It's only accurate as the sending unit.
  12. Oct 9, 2022 at 8:20 AM
    Batmobile1147
    What’s the approx cost?
  13. Oct 9, 2022 at 8:23 AM
    MR5X5
    $100
  14. Oct 9, 2022 at 12:33 PM
    ABA180
    East Bridgewater MA
    Not necessarily, I have an older UG and it is accurate. That said it is dependent upon the user updating the gauge fuel level every time one adds fuel.
    SR-71A and RedDemolisher like this.
  15. Oct 10, 2022 at 7:46 AM
    MR5X5
    Could be wrong, but I don't believe Ultra Gauge sources the the sending unit. I believe it calculate fuel consumption based on engine parameters. You need to program the tank size and, as stated, reset with a simple press of a button at fill up for it to be accurate. None of that would be needed if it was simply a digital representation of an analog signal.
    https://www.ultra-gauge.com/blue/obdii-standard-gauges.htm
    SR-71A, RedDemolisher and ABA180 like this.
  16. Oct 10, 2022 at 8:18 AM
    ABA180
    East Bridgewater MA
    This is true at least on the older ones (which I have).
  17. Oct 10, 2022 at 8:25 AM
    MR5X5
    Mine too. Couple years old... Can't imagine that it would have changed.
  18. Oct 10, 2022 at 8:35 AM
    ABA180
    East Bridgewater MA
    Oh wow..mine I've had about 6-7 years and I got it used.
    But agreed, I can't see how it could really sense all that at least once you add fuel without having to hardwire to the tank/sending unit. Not worth it anyway.
