Gas tank help with size 2000 V6 3.4 xtra cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by MrDunev, Jun 11, 2013.
  1. Jun 11, 2013 at 4:39 PM
    MrDunev
    MrDunev [OP] Well-Known Member
    Los Angeles
    2000 TRD Black Xtra Cab
    I did some research and I thought I had a tank that was 15.1gal but that isn't possible.
    I just filled my tank from half way mark and it took over 10gal. The needle is a quarter inch above the "F" I haven't had the truck on "E" yet, but I have had it about halfway between the first line and "E" and it didn't seem like it was running out of gas.
    Is my needle off by a bit, or is it possible I have a 20gal tank?
    My truck is the:
    2000
    Pre-Runner Xtra Cab
    3.4 V6 2wd TRD
  2. Jun 11, 2013 at 5:09 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Fuel gauge is just a general idea not exact. I believe you have an 18 gallon tank.
  3. Jun 11, 2013 at 5:09 PM
    169.254.255.201 Well-Known Member
    Interwebs
    What about 19? I have a 01, and I am pretty sure I have that..
  4. Jun 11, 2013 at 6:20 PM
    2000GTacoma
    Snow Hill NC
  5. Jun 11, 2013 at 7:26 PM
    MrDunev
    Los Angeles
    Read that numerous times. A little confusing to be honest. I feel like I honestly have more than 18gal in my tank, I'll just have to wait until I get to empty and see how much I can take. I don't usually let it get below halfway though.
    This only way to really tell.
    Just seeing if anyone else felt like their tank was larger than normal.
  6. Jun 11, 2013 at 7:31 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    I have a 18 gallon tank. I've filled it on fumes at 17.8 gallons before... Never again haha
  7. Jun 11, 2013 at 7:35 PM
    taco terror
    taco terror My ECT button stays clicked ;)
    Austen
    North Carolina
    Non-Turd Gen
    AR Baja wheels, 33 BFG ATs, 4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, Line-x
    I know for a fact that my gas needle drops below E before I run out, I have no clue how far down it will go and I don't want to test it. Plus I have no gas light so I am at a disadvantage. If you try to burn 18 gallons, you are going to run out of gas.
  8. Jun 11, 2013 at 7:36 PM
    taco terror
    Austen
    North Carolina
    Non-Turd Gen
    holy balls, do you recall where the needle was at?
  9. Jun 11, 2013 at 7:41 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
    Im suppose to have 18gal but i cant get more than 16 in it frome fumes to filler neck.:notsure:
  10. Jun 11, 2013 at 7:46 PM
    Mr. Biscuits
    Mr. Biscuits gentleman, scholar, part-time delinquent
    Brennen J
    Bakersfield
    2000 PreRunner TRD V6
    -Bilstein 5100/ Eibach 3" lift -Custom 2" lift rear leaf pack -Crystal clear headlight housings -updated (01-04) rear tail lights -custom front tube bumper -custom rear tube bumper -Deckplate mod -Aero Turbine 2525 exhaust -Kenwood Headunit -Pioneer Speakers -black door handles -Debadged, rebadged black -Ultraguage
    2000 3.4L here. it has a 15.1 gal at empty. probably an extra gallon of emergency fuel
  11. Jun 11, 2013 at 7:55 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Then you aren't on fumes.
  12. Jun 11, 2013 at 9:13 PM
    Interwebs
    Don't let it go empty.. I fill up when it reads a quarter. Which allows me to put 12.4 gallons approximately. So yes, I am playing it on the safe side (6) gallons, but I do not trust the needle.. I have been taking pictures the last two or three tanks of my needle throughtout the tank and it's not so accurate.. I'll post a thread sometime with it.
  13. Jun 12, 2013 at 2:20 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    factory spec is 18.8 gallons, states as such in the owners manual...I have put 18.4 in mine when it was almost dry......
  14. Jun 12, 2013 at 5:59 AM
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Well thats with the needle completely on empty or below and gas light on for 20 to 30 miles. Is that not considered empty?
  15. Jun 12, 2013 at 9:51 AM
    TallTacoma
    TallTacoma Bear fvcker!
    Charles
    The Silver State
    Come and take it from my cold, dead hands.
    3" suspension lift (ToyTec coilovers and wheeler leafs), Yakima roof rack, ARE tonneau, K&N FIPK.
    I've gotten 19 gal in mine filling to the cap.
  16. Jun 12, 2013 at 10:03 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    From a 2000 Tacoma user manual...
    Fuel type:
    ..Unleaded gasoline, Octane Rating 87
    ..(Research Octane Number 91) or higher
    Fuel tank capacity, L (gal., Imp. gal.):
    ..Two- wheel drive models except Pre
    ..Runner
    ....57 (15.1, 12.5)
    ..Four- wheel drive models and Pre
    ..Runner
    ....68 (18.0, 15.0)
  17. Jun 12, 2013 at 2:17 PM
    worthywads
    Nope that means you have another couple gallons. 3 gallons left when the light comes on it pretty typical, even 3.5.
    This somehow has caused mass confusion? even though it has been this way since tanks were first installed on cars.
  18. Jun 12, 2013 at 2:26 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    This has been visited in similar threads in reference to the accuracy of the fuel gauge needle. Fuel level sensors are NOT linear, meaning that they do not travel in a straight line. The float sits on an arm that is on an arc as it travels up and down. This means that when the arm of the sensor travels from full tank to empty it moves at a different rate as the fuel level itself goes down. Also the fuel tanks are not perfectly even shaped, which again adds to the inaccuracy of the gauge.
  19. Jun 12, 2013 at 4:03 PM
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Why does our needle go down so close to (E) before gas ligh comes on? I dont chance it, i get gas! That means im getting like 20mpg around town. WOOT WOOT!
  20. Jun 12, 2013 at 6:20 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep, 19 is what my 2000 holds pretty much
