Gas tank overfilling?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by missioncruiser, Apr 6, 2014.
  1. Apr 8, 2014 at 9:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You don't have a problem with it... especially not on a '13.
    If blocked, it will likely throw an evap code.
  2. May 31, 2018 at 10:44 PM
    rreddogg
    rreddogg Member
    2013 Tacoma TRD 6 speed
    sway bar. add-a-leaf
    hello missioncruiser, did you ever resolve your overflowing gasoline issue? I recently acquired a 2013 quad cab 4x4 that has the same problem. It matters not which gas station I visit; the petrol spews out when the tank is full. Introducing the gas VERY slowly will reduce spewage but rarely eliminate it.
    Any insights appreciated.
  3. May 31, 2018 at 11:08 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Stick the nozzle all the way in.
  4. May 31, 2018 at 11:19 PM
    rreddogg
    rreddogg Member
    always...
  5. Jun 1, 2018 at 11:22 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I bought 2002 Ranger new, the tank wouldn’t take more than an few seconds of gas at a time. Called the dealer, suggested different pumps and stations which I already tried. Brought it back and they diagnosed some sort of vent valve failure. They said they swapped out the tank from a different truck and it was fine for another 150k..
  6. Jun 1, 2018 at 11:44 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    @missioncruiser hasn't been active on TW in 2 years...
  7. Jun 1, 2018 at 2:20 PM
    rreddogg
    rreddogg Member
    Thanks for the feedback and sorry to lose missioncruiser especially prior to some additional clues about the surging gasoline issue.
    Definitely leaning towards some problem with venting but what and where is TBD.
  8. Apr 20, 2019 at 1:59 PM
    Flatliner
    Flatliner Well-Known Member
    Robert
    2008 Tacoma Double Cab TRD Sport
    Fox and Icon Suspension upgrade
    My 08 does this every single time I fill up, for a year now. They were supposed to fix it when the frame was replaced (for an additional cost) but said the vent is clear. I guess the evap cooler is next up. To all of you who say it's the station or the driver, you are not correct. My data set is plenty large enough to rule that out. Just because YOUR truck doesnt do it, doesnt mean the OP or mine dont.
    Anyone have a link to an evap replacement video, I cant find one .
  9. Apr 20, 2019 at 2:23 PM
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    My first gen has always done this since day one, and Everything on my evap checks out. I have found one station locally that does not, but the pumps are noticeably slower filling. My theory is that the filler neck is far to narrow, and as the tank nears full the pump cannot react fast enough unless you pump slow.
  10. Apr 20, 2019 at 11:44 PM
    rreddogg
    rreddogg Member
    2013 Tacoma 4DSB w / 50k miles. I experienced what seems a similar problem immediately after I bought the truck apx one year ago.I took it back to the dealer the next week with issues of gasoline gushing back out of the filler port every time I filled up the tank. Pretty much all I got as a solution was shrugged shoulders and dumb looks.
    So far the best and the only and actually a pretty effective solution has been to estimate the number of gallons I will need at fillup time and to slow the gas nozzle down as slow as it will go for the last couple of gallons. It takes some patience but so far has been 98% effective.
