Gas Tank Removal required to Remove Bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jun 26, 2022.
  1. Jun 26, 2022 at 4:40 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    Can gas tank stay installed if remove the bed of 06 pre-runner?
  2. Jun 26, 2022 at 4:44 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Yes. Think you need to disconnect the filler neck from the bed. Plus the tail lights
    srspicer, PzTank and Kolter45 like this.
  3. Jun 26, 2022 at 5:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The bed bolts can be HARD to get put.
    Good luck:fingerscrossed:
    Kolter45 likes this.
  4. Jun 26, 2022 at 7:24 PM
    TacoBell07
    Four door 2wd Taco
    What do you mean?
    Theres bed liner are they underneath that ?
  5. Jun 26, 2022 at 7:45 PM
    TnShooter
    Deogee
    STOCK
    Like super tight
  6. Jun 26, 2022 at 10:34 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Tank stays in, tail lights get removed.
    Stryker_Taco and fatfurious2 like this.
  7. Jun 27, 2022 at 6:28 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    When I removed my gas tank, you can do it without removing the bed. With that said, I had a much easier time reaching some of the upper hose hardware with the bed removed. To answer your question yes you can remove your tank with the bed on but removing the bed or raising it up about 6 inches will make the task exponentially easier. You'll need to disconnect your electrical connectors going to your tail lights and invertor outlet if you have one. Disconnect the brackets holding your tank filler line and push the fill line into the fender cavity. The 6 bed bolts might get squirrelly, liberally apply Kroil or PB Blaster the day prior. Crawl under the truck and hit the bottom side of the bolts too. Big breaker bar and the appropriately sized Torx bit to limit the possibility of stripping the bolts. If you have an engine hoist or something like that, it will help to lift the bed out, I think its about 200 lbs or so.
    -J
  8. Jun 27, 2022 at 11:09 AM
    TnShooter
    Deogee
    STOCK
    The size bit you need is T55
    I just checked mine. It’s been in the tool box of the truck ever since I had to buy it just for those bolts.
  9. Jun 27, 2022 at 9:01 PM
    TacoBell07
    Four door 2wd Taco
    So the bed bolts are not hex bolts or nuts but a torex screw bolt ?
    Also for sake of knowing if all bolts were off of bed and I tied bed to tree and burned out would the bed slide straight off or does it have to actually be lifted off ??
  10. Jun 27, 2022 at 9:45 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Don't think you would want to do that, 2-3 people should be able to lift it off fairly easily.
    I haven't taken a Toyota bed off yet but we pull beds other full size short bed trucks to do the fuel pumps at work when they come in with empty beds (usually we just move them back far enough to access the pump).
    TnShooter likes this.
  11. Jun 27, 2022 at 10:00 PM
    TnShooter
    Deogee
    STOCK
    Pretty sure your rear bump is going to stop it from “sliding off”.
    You’ll likely need to lift it.
    RocketTaco808 and PzTank like this.
  12. Jun 27, 2022 at 10:43 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Very excited for OP's upcoming Gen 2 Tacoma Bed Removal Trilogy...
    srspicer likes this.
  13. Jun 27, 2022 at 11:01 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    If you have a short bed you cant reach parts of it even with the bed removed so you would have to drop the tank. that is what I plan on doing. It def tight at the top but doable. Removing my bed would be way more work then dropping the tank. Just make sure that you have no or very little gas as that will make it a PIA.
    Jimmyh likes this.
  14. Jun 28, 2022 at 1:09 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Definitely can, while I didn't see it done my truck bed needed to be replaced 4 years ago. My brother in law did the job (he's a body guy by trade) and told me the tank stayed.
  15. Jun 29, 2022 at 2:14 AM
    RocketTaco808
    RocketTaco808 Resident Telescope Expert
    Maui
    08 4wd URD MKIII.1 6-Speed
    Poly bushings all around, URD Headers, Composite Carbon Stage II clutch, TRD short throw, URD Spec U Exhaust, Tow package, Bunny Trails, Fairy Dust, Triple Dynamat Insulated, Blood, sweat, grit and some good old fashion elbow grease.
    Don’t scratch the paint on your cab or bed corners when taking it off/putting it on. Sounds like common sense, but fairly easy to screw up on. 4 people is ideal, wouldn’t do it with less than 3. Would tape cardboard up around danger points to prevent scratches, you’ll feel stupid doing it but will be worth it!
    also the kinematic mounting guides used to align the bed when you put things back together are held in place by plastic clips. Be careful if you want to maintain that luxury.
    wi_taco and PzTank like this.
  16. Jun 29, 2022 at 12:16 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I had the dreaded bed rattle a few years ago.
    I had to spray the bed bolt top, underneath and sides (Aero Kroil) on a monthly basis. It took about 18 months for it to finally break free with my breaker bar.
  17. Jun 29, 2022 at 12:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    So you've never even looked at the bed bolts?
    Please get video if you use this method.
    PS, 'burned out' is funny stuff when speaking of a Tacoma.
    PSS, Friday is 2 days away
    PzTank, Raylo, 6 gearT444E and 2 others like this.
  18. Jun 29, 2022 at 11:19 PM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    Removed all of my bed bolts because they were really rusted. Four came out-no problem. 5th with a breaker bar. 6th took to my mechanic. He used electric heat induction to get the last one. No danger of setting the bed on fire to heat up a seized bolt.:thumbsup:
    I never removed the bed. Plan on it this year to do preventative on the frame. I put everything back together with plenty of high temp. grease on everything.
    Good luck!
    RocketTaco808, PzTank and burrito782 like this.
  19. Jun 29, 2022 at 11:37 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    You must have 2 weak friends, the bed weighs around 250 lbs. Unless you're hiring your preteen soon to lift it.
    The "kinetmatic" points you refer to are simply alignment points to make sure the bed is on the frame at the right spot, i took mine off as i found they were more trouble than they were worth.
  20. Jun 30, 2022 at 1:55 AM
    RocketTaco808
    Maui
    Don’t be that way bro.. while I agree and can lift one side with a. Strong braddah, not everyone’s built like us. LGBTQZAIONOTQUITEASMURF.
    6 gearT444E likes this.
