Gas tank replacement? Really?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dragon129, Feb 3, 2016.
  1. Feb 3, 2016 at 2:31 PM
    dragon129
    dragon129 [OP] Mod wannabee
    Lexington Park, MD
    05 speedway blue PreRunner Double cab
    No mods
    Okay, so I guess my first mistake was letting the wife take the Taco to the dealership to find out why the check engine light is on. I am a 6 hour drive away and thought a diagnostic would tell me which O2 sensor to change and I would be good when I got back. Turns out, they told her the gas tank needed changing along with one of the hoses. WTH? That will be almost $1200. Is a 2005 Taco with 98,000 miles on it have a faulty gas tank? Unless they stabbed the tank, really???? A new tank? Do they have to separate the bed from the truck, turn the bed around, laser align the bed with a custom gas tank. I'm confused. Wow....
  2. Feb 3, 2016 at 2:32 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Dropping the tank isnt that bad...... but id want pics of WHY it needs to be replaced
  3. Feb 3, 2016 at 2:34 PM
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    Where's the paperwork they gave her? Can you scan it and upload it here? I'm certain she's getting mixed up on what they said. Maybe she's getting EVAP canister confused with gas tank.
  4. Feb 3, 2016 at 2:36 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I doubt an EVAP canister would be $1,200.00
    Justus likes this.
  5. Feb 3, 2016 at 2:37 PM
    DanielTaco
    Daniel
    Iceland
    I've seen worse ripoffs.
  6. Feb 3, 2016 at 2:38 PM
    File IFR
    Central MA
    True. Nothing from a dealer's service center would surprise me now.
    Justus and NAAC3TACO like this.
  7. Feb 3, 2016 at 2:39 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    Sounds like bullshit
    Justus likes this.
  8. Feb 3, 2016 at 2:39 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Take it somewhere else. The only thing I use dealers for are recalls.
    YotaDriver631 and Justus like this.
  9. Feb 3, 2016 at 2:43 PM
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    I wouldn't give the dealer a dime until I'm sure what exactly is the problem
    Justus likes this.
  10. Feb 3, 2016 at 2:49 PM
    dragon129
    Lexington Park, MD
    No mods
    I guess I will drop the tank and take a look now. The canister was the worst case scenario that I thought of. No pictures were taken but I kept repeating myself to her making sure they said gas tank. She said something about the technician having a problem separating a hose from the tank but damn. I wonder if they didn't screw something up and just said, "Hey, you got a problem here."
  11. Feb 3, 2016 at 3:19 PM
    Shelf Life
    Rob
    Central Oregon
    This ^^
    spacecat, kgarrett11 and mahaloTaco like this.
  12. Feb 3, 2016 at 3:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What are the codes they pulled, for the Check Engine light?
  13. Feb 3, 2016 at 3:45 PM
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    If it is a 2005 you should be able to find a reputable mechanic that is not at the dealer to tell you why that light was on. After seeing how the local dealer has tried to rip off my wife I would not trust anything they tell her.
  14. Feb 4, 2016 at 7:56 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't think you need a new gas tank. What I do think is there was a failure to communicate. Your wife should have gotten a work order that had the prognosis written down on it. If not call the dealer, they should be able to look it up and explain exactly what is needed.
    You probably need a replacement Charcoal Evap Canister and they have an issue with one of the hoses going to the gasoline tank. They will probably need to remove the bed to get to this hose. When you add up a couple hundred for the canister, a hundred for the hose assembly, shop fees and three hours of labor at 150 and hour it is going to be close.
    I would go elsewhere or do it myself.
    adanfon and Torspd like this.
  15. Feb 4, 2016 at 7:59 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Yeah...exactly what are the codes? I wouldnt be dropping anything till I got those...I dont trust dealerships at all...
  16. Feb 4, 2016 at 8:02 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Another day, another dealer clusterfuck.......Why not just cut the damn hose and use a metal splice and 2 clamps to reconnect it? If that is even what is going on.....
  17. Feb 4, 2016 at 9:22 AM
    dragon129
    Lexington Park, MD
    No mods
    The wife just sent me the work order. Vent hose and gas tank replacement. So is that hose permanently attached? Doubt it. Don't remember the code but it was for evap.
  18. Feb 4, 2016 at 9:25 AM
    Shelf Life
    Rob
    Central Oregon
    There you have it! The old why pay for this expensive repair when we can give you low book for a trade in?
    devkurf and 12TRDTacoma like this.
  19. Feb 4, 2016 at 9:34 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Insane. Replace the whole tank because the vent hose has a leak. Unless the nipple the hose goes on broke off the tank there's no reason for that
    T@co_Pr3runn3r likes this.
  20. Feb 4, 2016 at 9:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Physically look at the vacuum hoses by the tank. From the fuel filler neck and the large accordian hose going to the charcoal canister. You might find a very simple issue. There is also a solenoid attached to the upper plenum of the intake manifold. Has a vacuum hose routed to it from just behind the throttle body. Check those hoses as well.
