Gas Tank Vibrating
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trinimd, May 18, 2009.
  1. May 18, 2009 at 10:53 AM
    Trinimd
    Trinimd [OP] Member
    Has anyone had this problem.
    I have a 2 door prerunner 2003
    The gas tank rattles on the highway.
    Any suggestions on the fix?
  2. May 18, 2009 at 10:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Interesting....Are you SURE its the gas tank??
  3. May 18, 2009 at 10:58 AM
    BSPDX
    BSPDX Well-Known Member
    It may be your heatshield on your cat...
  4. May 18, 2009 at 11:11 AM
    Trinimd
    Trinimd [OP] Member
    Yea I can see the gas tank door moving when I drive.
    thanks
  5. May 18, 2009 at 11:29 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Is the vibration constant or only at certain speeds/gears?
    What have you done as far as investigating the issue?
  6. May 18, 2009 at 12:38 PM
    Trinimd
    Trinimd [OP] Member
    I noticed the gas tank is kinda loose. Thought maybe it was a known problem.
  7. May 18, 2009 at 12:40 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No, I have never heard of it or experienced it. You should be able to just tighten the straps up.
