gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco man31, Mar 29, 2009.
  1. Mar 29, 2009 at 7:05 AM
    taco man31
    taco man31 [OP] Well-Known Member
    do u guys think its better to run premium or the cheap stuff?
  2. Mar 29, 2009 at 7:08 AM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    yo, theres like 30 threads about this already. If you do a 'search' for gas or octane you'll come up with a few. Not jumping your shit, just giving ya a helping hand.
  3. Mar 29, 2009 at 7:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    in the tests I have done, not only is it a dollar or so cheaper to run Priemium (in the length of a full tank, depending on driveing), but the 1GR-FE makes a few more hp and about 12 lb-ft more torque with Priemium fuel.
  4. Mar 29, 2009 at 7:16 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I run 87 octane in my 08 4x4 DC. Just took a road trip last weekend and got 20.1 MPG driving an average of 75 MPH on the highway.
  5. Mar 29, 2009 at 7:17 AM
    Rickochet
    Rickochet Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    From an octane standpoint everything I have read suggests that unless the manufacturer recommends a higher octane you are wasting your money.
  6. Mar 29, 2009 at 7:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My owners manual states "For best performance, use Priemium fuel". Given that the FJ is the sme engine with the same UCU programming, and it says "Use Priemium fuel", I figured it cant hurt. Out here, its only $0.20 difference from 87 to 91, so an extra $2.50 or so per fill up. Also, I have found this online in many places:
    The 1GR-FE is the 4.0 L version. Bore is 94 mm and stroke is 95 mm. Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane. This engine features Toyota's VVT-i system on the intake cam and a compression ratio of 10.0:1. Inside, the 1GR uses a taper-squish combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency. Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls. This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block. With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc), the entire cylinder block must be replaced. For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines. For increased cooling efficiency, the 1GR employs water passages between the bores of the engine. There are such two passages for each bank for a total of four. This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
  7. Mar 29, 2009 at 8:02 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2 for chris.i NEVER run anything lower than 89.its only a little more to fill up with 92/92oct.even when gas was $4+ a gallon..
  8. Mar 29, 2009 at 9:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    Manual recommends 87.....
    The only time I run something higher is if I'm gonna do a lot of hauling, or if I'm going on a long highway trip with a lot of mountains.
  9. Mar 29, 2009 at 11:25 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I use 87 in the city. I get about 22-24 MPG. When I head home to N. Arizona I use 91, get about 25-27 MPG. I drive about 5 MPH over the speed limit.
  10. Mar 29, 2009 at 3:56 PM
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    87 in my 07 Prerunner 4cyl. I get about 22MPG consistently. It's got the suspension TSB so it sits a little higher. Overall...no problems with 87. I've even pulled the ski boat with 87 and no problems there either.
  11. Mar 29, 2009 at 4:20 PM
    zigzagg321
    zigzagg321 T100
    Ohio
    96 T100 SR5
    sliding rear window
    89 in my 96 2.7... works fine
  12. Apr 10, 2009 at 6:16 AM
    mnerren
    mnerren 2006 Tacoma TRD Sport XSP
    Jacksonville, FL
    2006 Tacoma TRD Sport Double Cab
    I have tried all Octanes on my 06 Tacoma and have 40,000 miles of testing. The 87 sucks in the 4.0 L engine, in my opinion and the way I like to drive, which is hard. I like to accelerate hard and get up to speed, I have found 89 and 91 perform almost the same. If I use 87 I can make the engine ping under heavy acceleration, which is not good. So, I have chosen to stick with 89 octane fuel for now, unless I am going to be pulling the boat which weighs around 5,000 lbs and then I will put the 91 octane in. JMHO
  13. Apr 10, 2009 at 6:23 AM
    Joe B
    Joe B Well-Known Member
    I ran premium before the supercharger and of course after.
    Usually Shell.
  14. Apr 10, 2009 at 6:48 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    If you can find 100% gas at 87 run that for best bang for the buck IMHO. If you have to get the premium (BP) 91+ for 100% gas that is again better bang for the almighty dollar vs the Ethanol blend crap
  15. Apr 10, 2009 at 7:05 AM
    geoff5093
    geoff5093 Well-Known Member
    Goffstown, NH
    2013 Subaru BRZ
    I wish, here in NH all gas has 10% ethanol. I've always ran 87 octane in my truck. Sure you may be able to get 3HP more, but will you notice that? IMO if it runs fine on 87, I'm sticking with it.
  16. Apr 10, 2009 at 7:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, you do notice the 12 lb-ft of torque. My truck, when useing 91, is much more "Peppy" off the line, and near the top end.
  17. Apr 10, 2009 at 7:12 AM
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    I guess I'll have to give it a try and use 91/93 the next few fill-ups.
  18. Apr 10, 2009 at 7:52 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    +1 I'll add...
    Here's an easy way I see a diff w/ a 6spd. Level ground, radio off. At only 40 in 6th. Punch it. Try with regular, try with premium.
  19. Apr 10, 2009 at 8:07 AM
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    I'm sure this has been asked several times, but how many tanks does it usually take to see a difference between regular and premium, or do you notice it on the first premium fill-up?
  20. Apr 10, 2009 at 8:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Seems to me that 2 tanks are what it takes to notice a diff in performance.
