gas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tt01, Apr 21, 2010.
  1. Apr 21, 2010 at 9:19 PM
    tt01
    tt01 [OP] Active Member
    Canal Fulton Ohio
    01 tacoma 6" suspension lift
    35" tires, 15" wheels 6" suspension lift (fabtech),
    how many gallons of gas is left in the tank when the low fuel light comes on in a 01 4x4 2.7L
  2. Apr 21, 2010 at 10:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    There have been a couple of times when I've happened to fill up as soon as the light comes on. I've only been able to put in 15 to 15.5 gal in those situations. I think I read in the owner manual that the tank capacity is 18.3. This tells me I had 3 gal left in the tank when the light came on.
    Since then I've noticed that how level the truck is can have a big impact on when the light comes on. My low fuel light always seems to come on first when I'm going uphill (lots of hills around here), then it'll go off going down the other side.
  3. Apr 21, 2010 at 10:17 PM
    tt01
    Canal Fulton Ohio
    i never thought i had a light either then was stuck in traffic forever and thought i was going to run out then the light came on and i didnt even think it had one and i thought that maybe i read in manual that it has a 17.5 gallon tank but i could be wrong
  4. Apr 21, 2010 at 10:20 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    about 3 gallons for mine.
  5. Apr 21, 2010 at 10:55 PM
    tt01
    Canal Fulton Ohio
    just found online that 01 tacoma has 18.49 gallon tank
  6. Apr 22, 2010 at 2:37 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    its always about 14 gal for my fill up but i thought my tank was only 16 gal? 2001 pre-runner?
  7. Apr 22, 2010 at 8:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I wouldn't worry about it too much. The low fuel light is mostly fluff, and way overrated. :gossip:
    If toyota was serious about wanting to send a message about getting low on fuel they woulda made the warning progressive. Starting out where it is fine, with the light coming on at the 3 gal mark. But is should progress from there. :D Maybe change color to bright red at the 2 gal mark and finally at the 1 gal mark start to flash and emit a warning screech with a voice like Steven Hawking's saying "hey stupid, better fill up soon!"
