Gasket for 2014 Manual Transmission Drain Plug?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cpyne, Oct 4, 2016.
  1. Oct 4, 2016 at 7:45 PM
    cpyne
    cpyne [OP] Member
    Ashland, MA
    2014 Tacoma Double Cab TRD Off Road
    I'm going to be doing the 30k mile oil change on my 2014 V6 Off-Road manual transmission. I see many threads out there that show the process, but I couldn't find the part number for the crush ring gaskets.
    Does anyone know the part number for these gaskets?, (drain and fill).
    thanks
    Charlie
  2. Oct 5, 2016 at 9:39 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    2013 AC TRD OR 4x4 4.0 V6 (should be the same for your 2014)
    Transmission drain plug (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs, ($1.51/ea)
    Transfer case fill plug (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs, ($1.51/ea)
    Transfer case drain plug (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs, ($1.51/ea)
    Front diff drain plug washer (copper) = part #90430-24003, 48 ft lbs, ($1.74)
    Front diff fill plug washer (crush style) = part #12157-10010, 36 ft lbs, ($1.23/ea)
    Rear diff drain plug (crush style) = part #12157-10010, 36 ft lbs, ($1.23/ea)
    Rear diff fill plug (crush style) = part #12157-10010, 36 ft lbs, ($1.23/ea)
    cgm, sawjai526 and (deleted member) like this.
