Gasket maker for reinstalling timing chain cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Jul 7, 2015.
  1. Jul 7, 2015 at 3:52 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
  2. Jul 7, 2015 at 4:11 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    foampile[OP] likes this.
  3. Jul 7, 2015 at 4:11 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Red RTV is what I use for my stuff. :notsure:
    Highlight the word you want to be a link and then click on the button that looks like a chain (link button). Insert the URL into the field.
    foampile[QUOTED][OP] likes this.
  4. Jul 8, 2015 at 6:57 PM
    foampile
    Mid-Atlantic
    I got this at AutoZone, Permatex 82195. You think it'll be alright?
  5. Jul 8, 2015 at 10:12 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I used the Toyota black on mine.
  6. Jul 9, 2015 at 2:32 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The Ultra Grey should work, but if you use the Permatex product selector, they recommend the Ultra Black for it's oil resistance qualities. They recommend the Grey if you are using a gasket, the Black if not.
    http://www.permatex.com/products/product-selector
    There is also the JB Weld Ultimate Black Silicone. It has high oil resistance and is rated to 500 degrees F. Permatex is rated to 550 degrees.
    The Right Stuff line is 3X the price but there is no cure time.
  7. Jul 9, 2015 at 6:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
