Gasket transfer case
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bigbuck1999, Feb 17, 2020.
  1. Feb 17, 2020 at 12:34 PM
    Bigbuck1999
    Bigbuck1999 [OP] Well-Known Member
    1996 Tacoma, 2017 TRD off road
    Guys I have an A340F transmission in my 96 tacoma. Im swapping transmissions but using the same transfer case. Anyone know the part number for the gasket that goes between transfer case and transmission not having very good luck. Thanks
  2. Feb 17, 2020 at 12:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Toyota FIPG
    #00295-01281
    Used for diffs, transmission, and if I recall correctly, transfer case to transmission.
    I'm only 2wd so I'm just assuming that's what'd be used.
    Wyoming09 likes this.
  3. Feb 17, 2020 at 3:02 PM
    Bigbuck1999
    That’s just gasket maker right? I seen kits where they sold the actual gasket I thought. Thanks
  4. Feb 17, 2020 at 3:09 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    FIPG means Form In Place Gasket. It’s like a RTV sealant that you use
    Kwikvette likes this.
  5. Feb 17, 2020 at 3:12 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    There is no gasket between the Trans and T-case.
  6. Feb 17, 2020 at 3:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As mentioned above yes, a gasket maker in other words.
    It begins to settle right away so don't open it up until you're ready to use it.
    Get the one I posted above; best you can use.
  7. Feb 17, 2020 at 5:55 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Why are we still talking about gaskets and gasket makers... lol
    There is no gasket (and you do not need gasket maker) between trans and T-case.
    It's a metal to metal connection. What are we trying to seal here?
    You have trans fluid in trans and gear oil in T-case. Nothing flows between the two assemblies.
    TWJLee and Wulf like this.
  8. Feb 17, 2020 at 6:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Exactly why I was thrown off lol but wanted to make sure that if the OP did anything relating to the transmission, that he use what Toyota uses; the FIPG.
