gasoline types
Discussion in 'General Automotive' started by fireturk41, Dec 29, 2008.
what kind of gas
  1. High octane
    41 vote(s)
    28.3%
  2. medium octane
    32 vote(s)
    22.1%
  3. low octane
    71 vote(s)
    49.0%
  4. none mine never leaves the garage!
    1 vote(s)
    0.7%
  1. Dec 29, 2008 at 4:02 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    in your trucks doest it matter "health" and performance wise what kind of fuel you use, i mean is it better high octane low octane or medium? also what kind do you use?
  2. Dec 29, 2008 at 4:10 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I have the 2.7, so higher octane would be a waste of money. I use 87 octane from Chevron.
  3. Dec 29, 2008 at 4:21 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I've always used 87 octane, it's what's recommended in the manual.
  4. Dec 29, 2008 at 4:37 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
  5. Dec 29, 2008 at 4:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I use the higher octane. We have the same engines that the FJ's have and they call for premium. They also get a 239hp rating as opposed to ours at 236. Just some usless info that I have learned on here.
  6. Dec 29, 2008 at 4:41 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Our vehicles are also capable of retarding or advacing the timing. Allowing the trucks to run at their optimal performance reguardless of octane rating, however some have noticed better mileage with the premium.
  7. Dec 29, 2008 at 5:10 PM
    Cobra69
    Cobra69 Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    I have noticed a big difference in Mileage in my Taco........i use 92 octane.
  8. Dec 29, 2008 at 5:17 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I use 87 on my Tacoma. Usually use ARCO or Chevron
  9. Dec 29, 2008 at 5:17 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    87 octane. i to have the 2.7L it would be a waste of money to run premium
  10. Dec 29, 2008 at 5:35 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I run the cheap stuff. I have noticed if I pull a boat it will ping sometimes, so I went up to 89. As far as the cleaner gas, my buddy had a VW Corrado with a factory supercharger, it was required to use 92 or 93. When his charger finally bit the dust we put a turbo on it, the internals were no cleaner than any other engine I have been into and he ONLY ran 92 or 93. That's my 2 cents
  11. Dec 29, 2008 at 5:46 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    2.7L here with Shell 87. Anything else is a waste IMO.
    From what I've read, The 2.7 & 4.0L engines dont have anything over the norm for compression either. I could'nt see justifiying the 93 other then for a little extra performance gain like some noted above.
  12. Dec 29, 2008 at 6:22 PM
    northlite
    northlite Active Member
    Cape Cod/Northern Newfoundland
    05 Acc. TRD OR Black Beauty
    I've only had my four banger a couple of weeks and gas prices are fairly low so I ran a tank of 93 to "clean it out" and now 89. From what I read elsewhere here at TW, and also from the comments here, there is no point in using anything other than 87 with the i4. On the other hand, there do seem to be some real if marginal advantages to using higher octane in the six.
    My last two cars have been an Audi A4 Quattro and a Subie six. The first, with its turbo, only liked premium and the Subie six recommended premium but ran mid-grade and in some remote areas, regular. So I got used to paying at the pump.
  13. Dec 29, 2008 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 4.0 V6 has an 10 to 1 compression ratio, and will benefit from the use of higher octain fuel. My tests showed an increase in mpg, as well.
    Some more info:
    http://en.wikipedia.org/wiki/Toyota_GR_engine
    The 1GR-FE is the 4.0L version. Bore is 94 mm and stroke is 95 mm. Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane. This engine features Toyota's single VVT-i, variable valve timing, system and a compression ratio of 10.0:1. Inside, the 1GR uses a taper-squish combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency. Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls. This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block. With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc), the entire cylinder block must be replaced. For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines. For increased cooling efficiency, the 1GR employs water passages between the bores of the engine. There are such 2 passages for each bank for a total of 4. This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
  14. Dec 29, 2008 at 7:24 PM
    SC4333
    Grant
    FL
    :eek:My bad, I was under the impression it was on the lines of 9:1. 10:1 i think is higher then Ive ever seen in a truck! Wonder if the math balances out or makes it most cost efficient to run the 93 rather then 87 in a 4.0?
    This topic also has me wondering what the people above 3000-5000 feet are doing. Any 85 octane users???
  15. Dec 29, 2008 at 7:48 PM
    Tacoma02TRD
    Tacoma02TRD Well-Known Member
    Walla Walla WA/ Klamath Falls OR
    02 Tacoma TRD
    3inch Revtech lift,Flowmaster Muffler, K&N cold air intake, 33x12.5 Maxxis Bighorns, TRD stock locker, Hella 500 Fog lights, Scanguage II, 6k HIDs, Painted Black Rims
    I run Shell or Chevron 87 most of the time with no engine pinging. Now that gas is cheaper I'll pump it up to the mid grade stuff. I was talking with the Chevron owner today in town and he told me an interesting tidbit. He was talking about how its not always wise to fill up with the fuel truck there. Reason being that it stirs up all the crap in the bottom of the tanks that inevitably winds up there and could reach up into your tank. Could be a urban legend but seems logical. Take or leave, thought I would share.
  16. Dec 29, 2008 at 8:01 PM
    SC4333
    Grant
    FL
    I'm remembering this one the next time i see the fuel truck! I would bet the older the station, the worst it gets too. I have stopped filling at most older station solley based on the reasoning that a handful of older tanks can leak water in, as well as obviously fuel out. Check out some old tanks that have been pulled out of the ground next time you drive by an old station (30 or 40 yrs) getting demo'd. You'll more then likely be quite surprised.
  17. Dec 29, 2008 at 8:16 PM
    Tacoma02TRD
    02 Tacoma TRD
    ^^^ I bet I know behind my Dad's work they ripped out some old holding tanks and they didn't look to hot. I never fill up at Non branded stations cause they don't use some of the detergents and generally have some amounts of water in fuel as well.
  18. Dec 29, 2008 at 8:20 PM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    93, engine runs great ok miles needs plugs, but my exhaust tip never turns black.
  19. Dec 29, 2008 at 11:37 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    personally ive tried all 3 i like premium when i can afford cause ive heard that its best, are there any negatives to doing this
  20. Dec 30, 2008 at 2:12 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Premium.
