Gates Racing OEM Serpentine belt replacement for 1GR
Discussion in 'Performance and Tuning' started by Torspd, Dec 12, 2014.
  1. Dec 12, 2014 at 10:37 AM
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Should have done this sooner, if anyone is interested. For the 2005+ Tacoma, with the single VVT-I 1GR, as well as FJ's, 4Runners, and Tundras with that same engine. :thumbsup:
    Here is the p/n. Ordered it from Amazon.
    Gates K060837RB Blue Racing Micro-V Belt.
    On my engine right now. Yes, it is a 6 rib belt instead of a 7. Less friction = MOAR POWA! ;)
    Been running it since I think September. Always is great. :thumbsup:
    Lucario Runner likes this.
  2. Dec 14, 2014 at 4:46 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Interesting.... Is this less friction one less rib better for throttle response, a popular mod for other car communities? On another note; you know anyone using the AEM infinity yet on 1gr?
  3. Dec 15, 2014 at 6:04 AM
    Torspd
    Tor
    The Great America!
    I have no idea about anyone else using less ribbed belts. I just wanted to try something different, and see if it would work. Just to see if there could be a different option than the OEM. Now there is. As there wasn't anything I could find, prior to me test fittings this one, of someone else running any form of Gates Racing belt on the 1GR.
    I also didn't feel like getting an 8 rib and cutting one off. To much risk of damaging the rest of the belt. This was the easiest method.
    I have heard of no one with a 1GR, using the Infinity EMS. If I was just starting this journey of mine, that is what I would use, most likely. If it could be wired up to control the throttle body.
  4. Jan 8, 2015 at 8:18 AM
    Torspd
    Tor
    The Great America!
    Update.
    Still running this belt. Lucario Runner is as well, and has been since about the same time as me. No problems to report. No squeaks or squeals. Only a little discoloration on the blue surface where the contact with the pulleys takes place.
    A perfectly fine upgrade.
  5. Jan 15, 2015 at 6:33 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    So this is what you want me to get? :p
  6. Jan 15, 2015 at 6:35 AM
    Torspd
    Tor
    The Great America!
  7. Jan 15, 2015 at 6:37 AM
    AR15xAR10
    Well alrighty then.....logged for later.
    Seriously no issues with one less rib? Silly Amazon claims it doesn't fit.
  8. Jan 15, 2015 at 7:09 AM
    Torspd
    Tor
    The Great America!
    Been running it daily for months. Lucario Runner and I both.
    You just have to make sure that you line it up properly in the grooves.
  9. Jan 15, 2015 at 9:04 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
  10. Jan 15, 2015 at 9:48 AM
    Torspd
    Tor
    The Great America!
    That is not the accessory belt, that you posted. The length is too short. The link I posted is for the OEM serpentine belt. Which is what this thread is for. :thumbsup:
  11. Jan 15, 2015 at 9:50 AM
    Ostrichsak
    Jer
    Actually, I may have ordered the wrong belt now that I look at it. D'oh!
  12. Jan 15, 2015 at 9:59 AM
    Torspd
    Tor
    The Great America!
    That's no good man.
  13. Jan 15, 2015 at 10:29 AM
    Ostrichsak
    Jer
    See? I do make mistakes! :p
  14. Jan 15, 2015 at 10:39 AM
    Torspd
    Tor
    The Great America!
  15. May 28, 2016 at 11:24 AM
    LoneStarTaco
    LoneStarTaco Well-Known Member
    Skylar
    Longview
    01 Xtra Cab TRD 4x4 Std
    Toolbox, 265/70/16 BFG AT's
    Still working well?
  16. May 28, 2016 at 11:12 PM
    Torspd
    Tor
    The Great America!
    Yup. Stock engine, to built engine, and going to be moving on to the newest built engine. In the truck which is my DD.
    Biscuits and AR15xAR10 like this.
  17. May 29, 2016 at 7:08 AM
    LoneStarTaco
    Skylar
    Longview
    Sweet. I'll be ordering one in the next few weeks then. Bout to hit 100k and still on the factory belt (I think)
  18. Jun 3, 2016 at 9:41 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    No problems with mine. has a couple trackdays on it, still good.
    Biscuits and LoneStarTaco like this.
  19. Jan 30, 2017 at 3:55 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    glad I found this @Torspd! I will get this belt then.
  20. Jan 30, 2017 at 7:54 PM
    Torspd
    Tor
    The Great America!
    My pleasure mate. Still running the one this thread was started about. :thumbsup: As is Lucario.
