Gauge Cluster Bulb Size
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cloudbreakmd, Dec 29, 2013.
  1. Dec 29, 2013 at 7:14 AM
    Cloudbreakmd
    Cloudbreakmd [OP] Well-Known Member
    Bethesda, Maryland
    2018 DCSB 4X4 V6 SR5 Blazing Blue Pearl
    Bed Mat, Factory chromed exhaust tip, Factory all weather mats
    Can someone please tell me the bulb size for the D (PRND21) light in the gauge cluster? I need it to pass inspection and would like to order it prior to pulling the dash apart.
  2. Dec 31, 2013 at 7:38 AM
    Cloudbreakmd
    Bethesda, Maryland
    Anyone?
    I have even called 2 different dealers and they want me to bring the bulbs to them so they can match them up because they are not sure.
  3. Dec 31, 2013 at 9:58 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Should be a 194, no need to order the whole unit from dealer just pull bulb out of socket and replace.
  4. Jan 1, 2014 at 12:50 AM
    tba
    tba Member
    Thomas
    Honolulu, HI
    2000 SR5
    The gear indicator lights are Neowedge Type B.
  5. Jan 1, 2014 at 8:21 AM
    Cloudbreakmd
    Bethesda, Maryland
    Thank you both! Off to buy bulbs.
  6. Jan 1, 2014 at 9:09 AM
    Cloudbreakmd
    Bethesda, Maryland
    Ok so the parts store doesn't carry the bulbs for the indicator... Perhaps I should go the super bright led direction. Are there different sizes for the Neowedge bulb and if so which one should I get?
  7. Jan 1, 2014 at 9:15 AM
    Cloudbreakmd
    Bethesda, Maryland
  8. Jan 1, 2014 at 10:43 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    its a 74 I replaced mine about 8 months ago with a blue one thats only for the floor shifter though... If you have a column shift then it should be a 194
  9. Jan 1, 2014 at 10:45 AM
    bellassaiw10
    Currituck NC
  10. Jan 1, 2014 at 11:47 AM
    Cloudbreakmd
    Bethesda, Maryland
    It's a column mounted shifter. So the 194 lights up the gear indicator too? I thought it was just for the background lighting.
  11. Jan 1, 2014 at 12:31 PM
    tba
    tba Member
    Thomas
    Honolulu, HI
    2000 SR5
    You need the Neowedge Type B bulb. I also have a column shifter and I had to replace the D bulb in the gear indicator.
    The 194 bulbs light the gauges in the cluster, not the gear indicator. The gear indicator uses a separate bulb for each gear since they have to light individually to show the selected gear.
  12. Jan 1, 2014 at 12:38 PM
    bellassaiw10
    Currituck NC
    No clue about the column shifters but i believe tba is correct sorry for the misunderstanding!
  13. Jan 1, 2014 at 2:27 PM
    Cloudbreakmd
    Bethesda, Maryland
    Thank you TBA. What size Neo Wedge Type B did you get? It seems like there are three sizes.
  14. Jan 1, 2014 at 9:18 PM
    tba
    tba Member
    Thomas
    Honolulu, HI
    2000 SR5
    As far as I know, Type B is the size. There are Type A, B and C. I've also seen them referenced as T3, T4 and T5 respectively.
  15. Jan 2, 2014 at 3:56 AM
    Cloudbreakmd
    Bethesda, Maryland
    Did you buy the bulb at the dealer or parts store? I believe the T3,T4, T5 represents 3, 4, or 5 mm size.
  16. Jan 2, 2014 at 10:33 AM
    tba
    tba Member
    Thomas
    Honolulu, HI
    2000 SR5
    I bought the bulbs from autolumination.com.
  17. Jan 2, 2014 at 1:55 PM
    Cloudbreakmd
    Bethesda, Maryland
    Thank you again.
  18. Jan 3, 2014 at 9:34 AM
    Cloudbreakmd
    Bethesda, Maryland
    Last question TBA. Did you order a clear bulb or was it colored? Meaning is the gear selector panel transparent or does it have a multicolored screen behind it? I am ordering bulbs as soon as I hear back from you.
  19. Jan 3, 2014 at 8:37 PM
    tba
    tba Member
    Thomas
    Honolulu, HI
    2000 SR5
    The panel is transparent. The color comes from the bulbs.
  20. Jan 4, 2014 at 4:48 AM
    Cloudbreakmd
    Bethesda, Maryland
    Thank you!
