Gauge Cluster
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ozzytoyota, May 2, 2020.
  1. May 2, 2020 at 7:51 AM
    ozzytoyota
    ozzytoyota [OP] Well-Known Member
    ossie
    2017 Tacoma TRD Pro
    I have a 2017 Tacoma. My cluster broke and is no longer working. I want to purchase a used one online. Will my original miles show up on the new (used) cluster or will the cluster show the miles from the donor car?
  2. May 2, 2020 at 7:54 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Why not go to the Dealer and find out what's up? Odometer readings are not something to mess with, maybe a wire or something came lose.
    Junkhead likes this.
  3. May 2, 2020 at 7:55 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Not sure if that is even legal. Generally, vehicle mileage is married to the cluster.
    Junkhead and Unchained 5150 like this.
  4. May 2, 2020 at 7:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You are correct
    pinochle[QUOTED] likes this.
  5. May 2, 2020 at 8:05 AM
    ozzytoyota
    ossie
    2017 Tacoma TRD Pro
    my apologies, I don't think I explained well. I was wiring my car alarm and I had removed the cluster which ended up falling off a bench i had and broke. Like the plastic casing and the screen. It does not turn on anymore. I was going to purchase a new one from the dealership but they are expensive! I saw some online used. But I want to make sure that the new (used) cluster does not show the mileage of the donor car. I am not trying to roll back miles. I don't know how that's possible with a digital cluster.
    BSFord likes this.
  6. May 2, 2020 at 8:08 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    If you get a new or used cluster, you should probably take it to the dealer and ask if they need to transfer data.
  7. May 2, 2020 at 8:09 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    It should just swap over. But you can probably get one from LKQ and if it does not work you can always return it. Most toyotas you can just plug and play. Atleast for the ones I have replaced
    ozzytoyota[OP] likes this.
  8. May 2, 2020 at 8:12 AM
    ozzytoyota
    ossie
    2017 Tacoma TRD Pro
    @Modesto Tacoma That's what I was thinking and hoping. Cause these new smarter clusters typically (I would think) display what the computer is telling them. So If i was to replace it even with a new one the original miles of my vehicle should show up.
  9. May 2, 2020 at 8:23 AM
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    Unfortunately I think these clusters store the mileage inside them.
    Source: we ever need to replace them under warranty, we have to ground the vehicle and submit forms including vin and mileage so that they can be programmed at the factory.
  10. May 2, 2020 at 8:26 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I Asked the dealer for the clear plastic on the cluster, he misheard me and thought I wanted the whole cluster. Made it seem like an ordeal, Vin, title, ID, my first newborn etc.
    @tonered anything in TS about the cluster?
  11. May 2, 2020 at 8:31 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    The replacement odometer does not have to be sync to the vehicle but you do have to put a odometer replacement sticker somewhere visible in the vehicle to be legal. What I don’t know is if the odometer information is shared with other modules in the vehicle thru the CAN bus if that’s the case without the proper computer algorithm you won’t be able to sync everything up.
  12. May 2, 2020 at 8:41 AM
    ICU1
    ICU1 Well-Known Member
    My three year old Hyundai Elantra digital instrument cluster went out on me with about thirty thousand miles on it. Unit was replaced under warranty. Hyundai tech did not reset unit.
    A few thousand miles later, my ride was totaled. I informed the insurance company that the unit was recently replaced. Insurance still compensated me as if my three year old car only had twelve thousand miles on it.
