Gauge/gauge pod installation
Discussion in 'Performance and Tuning' started by dvd0020, Feb 15, 2012.
  1. Feb 15, 2012 at 9:11 PM
    dvd0020
    dvd0020 [OP] Well-Known Member
    Dave
    Colorado Springs
    08 Off Road Double Cab
    TRD supercharger, 4.88 Nitro gears, Doug Thorley long tube headers, aFe stage II intake, Pro Comp 6" DB lift (Icon Coilovers, Alcan 6" Springs, Bilstein RCD rears), NST lightweight pulleys, Morimoto mini projector retrofit for Spyder headlights, Cobra CB, 4' Fire stick, Pioneer AVIC-U310BT head unit, 2 10" alpine S, CBI Moab 2.0 front bumper, Smittybilt XRC8 winch, NFAB tire carrier, custom Colorado pinstripes
    Did a quick search, didn't seem to find anything on here. I just ordered the TRD supercharger and plan on setting up an AFR gauge and boost gauge. I would like to run the pillar pillar set up with dual gauge. Here is a link to the gauge pod im thinking of getting.
    http://www.gaugepods.com/05tacoma.jpg
    Question is, do gauges typically run the same diameter, or do I need to make sure the gauges are the same size to fit the diameter of the gauge pod? I found a couple gauges on URDs site, but they don't seem to mention diameter size.
    Also, I thought I saw a wide band bung on URD before, but can't seem to find it. If they don't sell it anymore, do all WB sensors fit in the same size bungs, so I could just buy any bung and the sensor would fit? Hope this isn't to confusing. Thanks much!
