Gauge Pods on A-Pillar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NumNutz, Mar 12, 2009.
  1. Mar 12, 2009 at 3:32 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    So I am thinking about doing some gauges running down the a-pillar.
    I think the ones I want to put in are Oil Pressure and Differential Temperature.
    The oil pressure gauge is a mechanical and the diff temp is electrical. Do I need certain things to hook up the diff temp gauge?
    Also where would I hook up my diff temp to get accurate readings?
  2. Mar 13, 2009 at 10:49 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    08 Tacoma Black,Sport package,
    Sport pedals, Extang full-tilt cover, Magnaflow exhaust system, XPEL invisible paint protection, TRD short Shifter, Hood struts, Homelink mirror, Dbl power outlets,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Muth heated signal mirrors TSB. Lo-Tek Pilllar pod with Glow-Shift gauges, 4x4 illuminated switch, Pioneer Z110BT (upgraded to Z130BT) w/2011 toyota tailgate backup camera,traffic tuner, parking brake bypass. Leather interior w/heated seats. LED's installed in glove box, center console, front and rear cupholders, rear console vent, AFE CAI, LED taillights, under hood lights, LED bed lights, oil catch can, extra D-rings installed in bed, frame replaced, Bilstein 5100, fronts set at.85, FOCAL Auditor 6.5" componet speakers. Replaced lower center dash panel with 2011 dash panel, installed USB charger and relocated seat heater switches to lower panel, FLYZEYE lights, APEX stealth LED light bar brackets and Cali Raised LED light bar, Illuminated Ignition Ring,Diff. Breather mod, AC mod.
    I'm doing the Gauge pod pillar also. 1 gauge will be volts, need to keep an eye on the
    electrical. Not sure about the second gauge. Where are you getting your pod and gauges?
    Sorry I can't help you with the hook up. That is beyond me.
  3. Mar 13, 2009 at 1:58 PM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    I assume you guys dont have the side curtain airbags, right ?
    07 and 08 I dont know but you probably do.
    Wouldn't want to end up eating those guages if you happend to put it on its side.
  4. Mar 13, 2009 at 2:00 PM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    i thought about dointhe pillar gauges i had my boost gauge mounted under the parking brake, looks out of place....is the gauges hard to install? (sorry i have a 1st gen.) just wondering about the install
  5. Mar 13, 2009 at 2:59 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Go to gaugepods.com to find the trim piece you need. They have a 1st gen one.
  6. Mar 13, 2009 at 3:03 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    thanks
  7. Mar 13, 2009 at 4:23 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Your goin to go with the mechanical oil pressure gauge? Whare did you find a differential temp gauge?
  8. Mar 13, 2009 at 5:33 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    I was planning on it but then realized that it was the wrong size. It was 2 and 1/16 and not 5/8.
    So I think I will go with trans temp I think.
  9. Mar 13, 2009 at 6:05 PM
    silver07taco
    COIL
    Maryland
    Mech gauges are not easy to run, Just a heads up, Be easyer on you to go with the elec ones.
  10. Mar 14, 2009 at 5:14 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Yea thats the plan to get an electric oil pressure and transmission temperature.
  11. Mar 14, 2009 at 9:25 AM
    silver07taco
    COIL
    Maryland
    OK cool, I know someone has the transmission temp gauge on here just dont rember who.
