Gauge question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaRXP, Feb 21, 2010.
  1. Feb 21, 2010 at 4:19 PM
    TacomaRXP
    TacomaRXP [OP] Active Member
    Bryan
    NC
    05 TRD 4x4 SR5
    K&N CAI
    Hey guys i just got an 05 tacoma. everythings good on it but when i start it it flashes maint reqd for about ten seconds. its got me worried but is this a start up procedure thats normal or should i go get the code looked at? thanks alot
  2. Feb 21, 2010 at 4:22 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    there is no code. its just telling you to get an oil change.
  3. Feb 21, 2010 at 4:23 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1 Welcome to the forums :taco:
  4. Feb 21, 2010 at 5:48 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    After you change your oil here is the procedure to reset that light your talking about
    Or if your oil is already nice and clean you can reset it
    Just some fyi in case you don't know how to reset it. TcBob could we make this a sticky?
    This is directly from the owners manual Section 1-6 "Operation of the Instruments and Controls" under "Service reminder indicators and warning buzzers" Subsection G "Engine Oil Replacement Reminder Light" page 150
    Clearing the "Maint Reqd" light on 2005 and up Tacoma's
    This light acts as a reminder to replace the engine oil.
    This light will come on when the ignition key is turned to "ON" and will go off after about a few seconds.
    When you drive for about 7200 km (4500 miles) after the engine oil replacement this light illuminates for about 3 seconds and then flashes for about 12 seconds with the ignition key turned to the "ON" position. If you continue driving without replacing the engine oil, and if the distance driven exceeds 8000 km (5000 miles), the light will come on after the ignition key is turned to the "ON" position. The light will remain on thereafter.
    If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road conditions. IF the light comes on, replace it as soon as possible.
    The system must be reset after the engine oil replacement. Rest the system by the following procedure.
    1. Turn the ignition key to the "OFF" position with the odometer reading shown (For details, see "Odometer and two trip meters" on page 143 in this Section.)
    2. Turn the ignition key to the "ON" position while holding down the trip meter knob.
    Hold the knob for at least 5 seconds. The odometer indicates "000000" and the light goes off.
    If the system fails to reset, the light will continue flashing
