gauge upgrades
Discussion in 'Performance and Tuning' started by ROMYER8313, Mar 12, 2013.
  1. Mar 12, 2013 at 8:12 PM
    ROMYER8313
    ROMYER8313 [OP] Active Member
    robert
    medford oregon
    08 sport package
    supercharger, 3inch lift, Doug thorley long tube headers and Magnaflow pro series off road exhaust. urd 2.55 pulley, ucon ems, upgraded urd fuel pump, urd seventh injector system, 61lb mulit-fuel fuel injectors, and AFE cai.
    so i have already installed the flex pod and the AEM A/F gauge and i was looking to get a boost gauge for the other mount. i see that there is a 35psi and 50psi boost gauge, the thing is i don't know the difference between the two and witch one i should go with. or is there another gauge that i should use instead of the boost gauge?
  2. Mar 24, 2013 at 8:33 AM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    Won't the difference be in how much of a wide reading do want to have? up to 35 PSI or 50 PSI?
  3. Apr 2, 2013 at 7:16 PM
    TRON
    TRON Well-Known Member
    Boulder
    2008 Sport
    TRD Blower, TRD CAI, JBA Headers, Custom 3 inch exhaust, 2.7 APR pulley, APR 7th Injector, Ucon EMS, 255 Walbro pump, NST OverDrive Pulley Kit, B&M Shifter, AIS Methanol Kit, TR Lowering Kit, URD Stage 3 Clutch, Etc...
    If you have the uego aem afr and you want the boost gauge to match; the 35 psi is the lowest aem gauge they make... I bet your close to 11-12 boost on a cold day with the 2.55... I have these gauges; they are great
