gauges
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sicripp83, Feb 2, 2011.
  1. Feb 2, 2011 at 5:11 PM
    sicripp83
    sicripp83 [OP] Well-Known Member
    wboro
    sic
    Has anyone added autometer or any other gauges to their rig. Voltage. Oil pressure. Temp. If so do you have any pics of your set up thanks
  2. Feb 2, 2011 at 5:52 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    no. what are we driving, fast and furious civics?
  3. Feb 2, 2011 at 5:56 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    just get a scangauge. IMO better than just 3 gauges
  4. Feb 2, 2011 at 6:07 PM
    LILFURR
    LILFURR Well-Known Member
    Mitch
    Chesapeake, VA
    2005 4.0l 6speed sr5
    6 inch fabtech, 3 inch body lift spidertrax wheel spacers, grillcraft insert with black grill, black trex3 eyelids, custom VT emblem(not mounted) courtesy metalmiller, custom VT shifter courtesy pope953, bhlm, tinted fogs
    sorry to jack your thread, but has anyone seen and pillar mount gauges for a taco?
  5. Feb 2, 2011 at 6:13 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    my bad didnt realize this was a 2nd gen post. cus it reads the tans temp on first gens
  6. Feb 2, 2011 at 6:17 PM
    LILFURR
    Mitch
    Chesapeake, VA
    thanks a ton christian added that site to my favs
  7. Feb 2, 2011 at 6:17 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
  8. Feb 3, 2011 at 6:30 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    So,,, who actually watches the road for you! :p
  9. Feb 3, 2011 at 6:38 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    These are Nexus gauges. You can program them to "flash" a different color when you get out of your comfort zone. So you do not have to watch them that closely.
    For example, the oil pressure gauge flashes red when the oil pressure falls under 20 psi.
  10. Feb 3, 2011 at 6:46 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    The Ultra Gauge wont read the tranny temp either, but you can set warning alerts for certain gauges that it does read. I think even if they are not on the 18 gauges that you can set to display.
  11. Feb 3, 2011 at 8:54 AM
    imtwistd
    imtwistd Going nowhere as fast as possible
    I forgot
    Liverpool NY
    08 dbl cab long bed sport 4x4 beast
    AllPro offroad front LT with Fox 2.5 shox and AllPro expedtion rear springs with Fox piggy back res shox, TRD skid plate, Toyota roof rack, Undercover tonnuea cover, Pro comp 3" lift, 4 Pro comp 8" offroad lights, 17" XD Series "SPY", Nfab tube steps and light bar, Fitch Fuel, Flexalite fan, Unichip, URD cai, TRD supercharger, URD y-pipe, Banks monster cat back, debadged, projection head lighs, LED tail lights and a loud stereo, Stainless Steel Brake Lines front and rear, Doug Thorley long tube headers, Walboro 255 fuel pump, KC rock guards on my Pro Comp 8" lights
    Thats one sick setup what are the different gauges you got:cool:. I just ordered the urd steering wheel pod for my trd boost gauge. Looking to fill in the second pod but not sure what to use.
  12. Feb 3, 2011 at 2:17 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Automeater volt and oilpressure.
  13. Feb 3, 2011 at 2:56 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Boost/Vacuum
    Intercooler Temp (before & after intercooler)
    A/F
    Oil Temp
    Oil Press
    Water Temp
    Volts
  14. Feb 3, 2011 at 3:50 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    I plan to leave the power train essentially stock on my truck so I'm not too worried about relying on factory buffered gauges and dummy lights for the critical engine stuff.
    However, living in the mountains and towing in the mountains, I do plan on putting a transmission temp gauge in to make sure I don't cook the ATF.
    The only other one I might want would be a voltmeter so when I'm camping and using the map lights or radio I can keep an eye on the voltage. Or also if I add a light bar and a bunch of auxiliary lights, it would be good to keep an eye on the alternator.
