Gaz Odour in Motor Oil ????? Need Help !
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Suroit, Mar 21, 2011.
  1. Mar 21, 2011 at 10:41 AM
    Suroit
    Suroit [OP] Active Member
    Jack
    New-Brunswick Canada
    Tacoma TRD SR5
    Front Susp., Tires & Mags
    I have a 2009 Taco V6, 75000 miles. I Pulled the deep Stick yesturday & the oil Smell Gaz... ? What Cause That ??? Need Help !
  2. Mar 21, 2011 at 10:59 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Octane too high in fuel maybe, or Spark plugs need changing.
  3. Mar 21, 2011 at 11:20 AM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    2.5 King RR in front, LR ucs' s, 2.0 King RR rear, B.A.M.F shock mounts, ATO shackle flip, 4X sliders, ARB front bumper with XRC8, CBI hc rear, weathertechs, Leer cap, Thule rack, ubolt flip, etc.
    Change the oil and make sure there isn't actually gas in it. If so, you could be getting blow by (piston rings).
    I've also heard that it could be caused by the cold weather.
  4. Mar 21, 2011 at 2:12 PM
    tony216
    tony216 I like my member
    NEPA
    TRD OR DC
    Do you let it idle for really long periods of time? 75k isn't a lot of miles to need rings.
    Does it smoke? Maybe you have a set of rings lined up. I don't know enough about to Toyota's to know if it's a three or two ring set up.
  5. Mar 21, 2011 at 2:18 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    WTF is Gaz? Is this some sort of gasoline with an additive in it?
  6. Mar 21, 2011 at 2:50 PM
    jrdbrn
    jrdbrn Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    Gaz Odour is a new type of motor oil.
  7. Mar 21, 2011 at 2:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Have the oil anylized. The smell alone is hard to gauge how much may (or may not) be in it.
