GB: 9" round LED lights
Discussion in 'Group Buys' started by Iggy, Jul 6, 2015.
  1. Jul 6, 2015 at 10:47 AM
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I only need a few to get this started, but I can get pricing lower if we can do 6 sets.
    Retail on these are $475 a pair including shipping. The group price is $400 plus shipping for 2 sets, $375 plus shipping if we can 6 sets committed.
    Shipping estimate is $20-$30.
    Options are Amber covers for $20 extra.
    Details:
    Includes a wire harness, clear lens cover and diffused (flood) lens cover.
    • Lumen Rating: 10,500 (each)
    • Size: 9" 37 X 5W high intensity CREE LED
    • Beam: Spot (includes flood cover)
    • Material : Aluminum Alloy Body
    • Lens Material: Premium PMMA
    • Operating voltage : DC 9v-32v
    • Color Temperature : 6500k
    • Watts: 185
    • Amp Draw: 15
    • IP68 Waterproof and Dust resistance
    • Life time : 50000 Hours
    • Work temperature : -40 ~ 155 °C
    • LED chip: CREE XT-E 5W
    Dimensions with mounting bracket:
    10 1/4" Tall
    9" Wide
    4 1/2" Deep
    Real Performance:
    Some night photos to compare to stock. These were taken with my DSLR on a tripod on manual mode using the exact same settings on each photo. They are untouched and all I did was resize them. These lights are really bright! I noticed mine are pointed a little high as you can see with the hotspot.
    Stock low beam:
    Stock high beam:
    LED and parking lights only:
  2. Jul 6, 2015 at 10:54 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I think I might actually be on board for these this time. Did we establish that they would fit behind the grill?
  3. Jul 6, 2015 at 10:55 AM
    Iggy
    Northern CA
    Check out the build
    They fit, but not with the supplied brackets, they will need something that comes straight down like the BAMF bar to hold them from the sides.
  4. Jul 6, 2015 at 10:56 AM
    VolcomTacoma
    Jeff
    NorCal
    Yea that's the plan. Awesome. Count me in for local pick up if we get to 6
    Iggy[OP] likes this.
  5. Jul 6, 2015 at 1:09 PM
    Buda Pest
    Buda Pest Well-Known Member
    i'm in if we can find 6 committed. Also, I'll take the amber covers.
  6. Jul 6, 2015 at 1:55 PM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    I am in with the amber covers.
  7. Jul 6, 2015 at 4:07 PM
    2012Taco
    2012Taco Well-Known Member
    NJ
    '12 DCLB TRD
    OME 886's & Dakar's & LR UCA's, LT265/75 Duratrac's on Countersteer Offroads, 100RCC, ARB 50 fridge/freezer, ARB bullbar w/ Warn 9.5xps, dual battery setup, on board air and water, PrInSu topper rack carrying the gear and more to come!
    Bump for some quality products from a trusted member of our forum - I picked these up last go around and am more than pleased with the results!
    Chux and Iggy[OP] like this.
  8. Jul 6, 2015 at 4:28 PM
    VolcomTacoma
    Jeff
    NorCal
    These will be my hidden 'GTFO of the way' lights.
    Buda Pest likes this.
  9. Jul 6, 2015 at 4:29 PM
    Iggy
    Northern CA
    Check out the build
    @2012Taco Those are some great photos! Thanks for sharing. I've been trying to tell everyone how bright these suckers are! They are a great alternative to light bars if you excellent and affordable lighting.
  10. Jul 6, 2015 at 4:30 PM
    VolcomTacoma
    Jeff
    NorCal
    Well, I will consider these an excellent addition to my light bars :)
  11. Jul 6, 2015 at 4:30 PM
    Iggy
    Northern CA
    Check out the build
    That too!
  12. Jul 6, 2015 at 4:32 PM
    VolcomTacoma
    Jeff
    NorCal
    What do the flood covers look like? I kind of want to fund a custom cover that can combo spot/flood. Maybe just find a clear cover and fuzz out the outside ring of lights for dispersion and keep the center ones for spot...hmmmmm ideas ideas
  13. Jul 6, 2015 at 4:37 PM
    Iggy
    Northern CA
    Check out the build
    The diffused covers have these sort of tubular vertical ridges that disperse the light. They make a wide cutoff beam.
    My buddy used 3 on his F350, the center has the flood, while the two on the ends have spots. I would run the left as flood and right as spot.
  14. Jul 6, 2015 at 4:38 PM
    VolcomTacoma
    Jeff
    NorCal
    Ok, I'll look at them. Maybe I can just cut out some hazy vinyl and throw it aroundl the edges
  15. Jul 6, 2015 at 4:48 PM
    Iggy
    Northern CA
    Check out the build
    Do you have access to a media/sand blaster? The best thing I can think of is get some vinyl cut in circles the size you want the spot to be, or something cool like a bat symbol, stick it in the middle then blast around it lightly. Peal it off and it should work well!
    ManBeast likes this.
  16. Jul 6, 2015 at 7:08 PM
    Buda Pest
    Stop doing 70 in a 65 zone in the fast lane, fucker, or i'll turn your night into day!
  17. Jul 6, 2015 at 7:10 PM
    VolcomTacoma
    Jeff
    NorCal
    Stop doing 60 in a 65 zone you mean :D
  18. Jul 6, 2015 at 7:11 PM
    Buda Pest
    To each is own, my friend. ;)
  19. Jul 7, 2015 at 6:59 PM
    Buda Pest
    Damnit, this needs more attention! Are people afraid to jump on board?
  20. Jul 7, 2015 at 7:20 PM
    VolcomTacoma
    Jeff
    NorCal
    Well, having seen these in person on Iggy's truck, they are pretty TOP quality lights. Not cheap chinese knock offs.
