GB for Wheeler's 5 pack leaf springs???
Discussion in 'Group Buys' started by Adam Baum, Jan 30, 2012.
Thread Status:
Not open for further replies.
  1. Apr 11, 2012 at 1:06 PM
    #61
    Adam Baum
    Adam Baum [OP] Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    Is that any cheaper than having Alcans in the rear?
  2. Apr 11, 2012 at 1:18 PM
    #62
    scocar
    scocar Patron of the Farts
    Yes. If you want that much in the back, look into Dakars or All Pros.
    These are built by Alcan for Wheelers. Not sure, but you can call Alcan to see what they can custom build for your specific needs and see what they say. Maybe some other folks who have bought custom Alcans will chime in.
  3. Apr 11, 2012 at 9:22 PM
    #63
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    ^ thanks :cheers:
    I think I'll look into other options
  4. Apr 11, 2012 at 10:47 PM
    #64
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Using shackles and a 5 pack isn't a bad option at all.
    I have 1.25'' daystar shackles on my truck now, and will couple them with the 5 pack to get ~2.5-3''
  5. Apr 12, 2012 at 7:02 AM
    #65
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Will these springs give me any more weight hauling capability ?
  6. Apr 12, 2012 at 8:40 AM
    #66
    TacoMX
    Jonathan
    Deltona, Florida
    over stock, yes. But depends on how much you want to haul. There could be better options depending on what you use your truck for.
  7. Apr 12, 2012 at 10:44 AM
    #67
    scocar
    A bit, note sure how much specifically, other than "one more leaf's worth." If you haul stuff at or near capacity regularly, you could look into the Timbrens to add to the new leafpack.
    Note that the Wheelers 5-pack does have an overload spring, whereas some other aftermarket leafs (like All Pros) do not; they are designed for flex, not load (or overload).
  8. Apr 12, 2012 at 11:11 AM
    #68
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    I'm not looking for anything extreme, basically if they handled a bed full of mulch better, I'd be happy. I hauled a load of crushed granite in a 2nd gen which actually overloaded it but I was surprised how well the stock springs handled it. So if these performed a bit better, I'd be happy, I could always add airbags if I wanted an extreme jump, don't think I need that though.
  9. Apr 12, 2012 at 1:11 PM
    #69
    Gorillazrus
    Gorillazrus To be continued...
    01 Prerunner SR5
    5100 Bilistens set @ 1" in front, Wheelers 5 leaf in rear, Leer Topper, TRD Skid Plate, Dual Band Ham Radio
    I called and talked to one of the guys at wheelers , and he said that these 5 leafs were about 10-15% stiffer than stock leafs. So they should have a little more capacity but not sure how much.
  10. Apr 12, 2012 at 1:36 PM
    #70
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    quite a lot more, by truck used to bottom out over speed bumps with about 450lbs in the bed, now it gets nowhere close.
    In fact 2 days after installing the 5 packs I loaded the truck up with waaay too much gravel, not sure how much weight but the bed was about 2/3 full. It was about 1" from the bump stops. No way the stock leafs could have done that.
  11. Apr 12, 2012 at 2:45 PM
    #71
    Gorillazrus
    01 Prerunner SR5
    Glad to hear from someone with them how they ride with weight on them as my truck bottoms out as well jut riding down the interstate with just a few hundred pounds in the back. Sounds like these are defiantly they way to go.
  12. Apr 12, 2012 at 2:45 PM
    #72
    scocar
    Actually, brings up another point. The Alcans use better steel than the stock crappy ones, which were made in New Mexico, by Steven, if I am not mistaken. So even a stock-height 4-pack replacement should provide more capacity than stock OEM.
  13. Apr 12, 2012 at 3:20 PM
    #73
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Truth. I use substandard steel in an effort to make more money(pesos) on my end.:cool:
  14. Apr 12, 2012 at 4:48 PM
    #74
    TacoMX
    Jonathan
    Deltona, Florida
    I think the 5 pack is a great fit for you :) sign up brotha!!
  15. Apr 12, 2012 at 4:50 PM
    #75
    scocar
    Yeah, I think he ^^^ is right.
  16. Apr 13, 2012 at 7:34 AM
    #76
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Hahaha... Believe me, I want to... I have some overtime coming up in the next two weeks, so it depends on when you guys are ready to place an order, I just can't do it right now, unfortunately. My normal paycheck has to go to other priorities. I'll be keeping a close eye on the GB in case I'm able to jump in.
  17. Apr 13, 2012 at 7:53 AM
    #77
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    do it do it do it Mike :)
  18. Apr 13, 2012 at 8:18 AM
    #78
    TacoMX
    Jonathan
    Deltona, Florida
    May 14th is the deadline so you have a month.
  19. Apr 13, 2012 at 8:28 AM
    #79
    TIPICOTACO
    Tyler
    nw nj
    do it do it do it Mike! :)
    I chose the 5pack for pretty much the same reason that you are looking into it, increased load capacity (w/ a lil lift) It's great to hear the above testimonials about how they preform. I do on occasion haul real heavy loads so I'm looking into extended bumps too (mayb airbags down the line)
    Hopefully the stars align and you can get in on the GB !!
  20. Apr 13, 2012 at 4:23 PM
    #80
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Excellent... If I end up being able to and there still room for me to jump in I will do it. Just don't count on me as of right now.
Thread Status:
