GE nighthawk... are there alternatives?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PROseur, Nov 5, 2018.
  1. Nov 5, 2018 at 1:44 PM
    PROseur
    PROseur [OP] Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
  2. Nov 5, 2018 at 1:46 PM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Did you check rigid industries (truck-lite)? Had some on my JKU rubicon and they were impressive
    PROseur[OP] likes this.
  3. Nov 5, 2018 at 2:12 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Firstly, those don't fit your truck anyway.
    But not many, if any companies offer a decent aftermarket alternative to our headlights. The earlier trucks (pre 2000) that use the the sealed beams have some options, but honestly most of the aftermarket brands just suck.
    Best bet is the "proper headlight upgrade" or a full-on HID etrofit. "proper" upgrade is best bang for your buck, IMO. Either OEM housings or the CAPA certified ones form RockAuto.
    If you can change a lightbulb, you can install the wiring harness from the proper upgrade.
  4. Nov 5, 2018 at 2:13 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I thought you were a big dick baller, you don't want those cheapo GEs you want these...
    http://www.jwspeaker.com/products/led-headlights-model-8900-evolution-2/
    or perhaps for slightly smaller e-peen
    https://www.rigidindustries.com/5-x-7-headlight-kit-pair-55003.html
    hell even these will radar out the orange county dilfs for you
    http://www.truck-lite.com/webapp/wc...p_category=&parent_category_rn=&storeId=10001
    cruiserguy likes this.
  5. Nov 5, 2018 at 2:59 PM
    jbrandt
    Justin
    I'm not sure any of those would fit in the pre-2000's, let alone the 2001+ trucks. At least not without a bunch of fabrication.
  6. Nov 5, 2018 at 3:03 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    They are all 95-97 only
  7. Nov 5, 2018 at 3:15 PM
    Speedytech7
    Well that's what he was asking about, he's got lots of beaters if I recall
  8. Nov 5, 2018 at 3:19 PM
    jbrandt
    Justin
    huh? OP has a 2001 (and a couple 3rd gens) according to his sig, and didn't seem to want to do even a wiring harness. I'm not aware of what else you're referring to.
  9. Nov 5, 2018 at 3:21 PM
    Speedytech7
    He owns lots of other junk, some of which might have sealed beams
  10. Nov 5, 2018 at 3:27 PM
    jbrandt
    Justin
    it's not junk!
    :D
    :thumbsup:
  11. Nov 5, 2018 at 3:43 PM
    tony2018
    tony2018 Well-Known Member
    Get Chinese junk and be happy. They all chinese.
  12. Nov 5, 2018 at 3:45 PM
    jbrandt
    Justin
    True, the CAPA cert housing I have probably were made in china, though I don't know for sure.
    But there's a HUGE difference between the CAPA certified junk made in china and the ebay no-name brand junk that's (also) made in china.
  13. Nov 5, 2018 at 4:03 PM
    tony2018
    I think my retrofit came out to that much. Maybe a bit more.
  14. Nov 5, 2018 at 4:06 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I'm about to retrofit some LED projectors into some 7x6" headlights.
  15. Nov 5, 2018 at 6:59 PM
    PROseur
    Pussy
    I thought I already sent you picture of my 3 inch dick?
    Truck lives on a farm 250 days a year
    Thanks for the suggestions
  16. Nov 5, 2018 at 7:00 PM
    PROseur
    Pussy
    Will check
    My Pro has the rigid fogs, not really impressive
  17. Nov 5, 2018 at 7:01 PM
    PROseur
    Pussy
    01 Truck has the CAPA lights - you recommended them last year and we changed them then. That one is fine
    I need a sealed beam replacement for a farm truck
    jbrandt[QUOTED] likes this.
  18. Nov 5, 2018 at 7:03 PM
    PROseur
    Pussy
    Correct
    I was asking for a sealed beam application for a farm junker
    Thanks. The rigid you linked - are they better then the GE? Same price essentially
    If $500 is the going rate - gonna have to get them.
  19. Nov 5, 2018 at 7:06 PM
    Speedytech7
    The only reason the Rigid would be better is their warranty is insane and they're heated so they won't freeze over in cold weather
    PROseur[QUOTED][OP] likes this.
  20. Nov 5, 2018 at 7:11 PM
    Wulf
    rock raisin
