GEAR CHANGES
Discussion in '1st Gen. Tacomas (1995-2004)' started by duty, Nov 23, 2011.
  1. Nov 23, 2011 at 7:02 PM
    duty
    duty [OP] Well-Known Member
    ok getting a 2002 tacoma with 6'' lift and 315/75R16 tires it has stock gearing with a v-6 truck has 123,000 on it well im going to upgrade the gears to either 4;11 or 4;56 im going to tow jet skis and be on the highways just wanted to know what your thoughts were on the best i think 4;11s and if you guys know a good place what kind gears u want with and prices and kit neeeded to to do the installs ??? thanx im in south jersey near philly pa
  2. Nov 23, 2011 at 7:05 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
  3. Nov 23, 2011 at 7:07 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    my v6 come from the factory with 4.10s same as 4.11s though
  4. Nov 23, 2011 at 8:02 PM
    duty
  5. Nov 23, 2011 at 8:13 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
  6. Nov 23, 2011 at 10:09 PM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    Is the truck manual or Auto.
    With the 35s, best to run a Manual with 4.56 or 4.88, Auto 4.88 or 5.29
  7. Nov 24, 2011 at 5:00 AM
    duty
    opps truck is automatic
  8. Nov 24, 2011 at 5:26 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner
    4.88s or 5.29s i would go with 5.29s for towing with 35s. about 800-900 rpm difference from stock with 5.29s, 4.88s about 500 rpm higher. i am regearing with 4.88s w/ 285s rpm @ 70mph should about 2500
  9. Nov 24, 2011 at 7:15 AM
    quattrokiwi
    Bruce
    Nor Cal
    I would agree, 5.29s with the auto and 35s
    I have 33s and 4.56s with a manual and kind of wish I had gone with 4.88s
  10. Nov 25, 2011 at 4:26 AM
    duty
    what about the motor screaming on the highway ? im use to going like 80 mph when im not towing .......... thanx for everyones input
  11. Nov 25, 2011 at 5:36 AM
    quattrokiwi
    Bruce
    Nor Cal
    It doesn't scream when doing 80, its just over 3000 rpm, but if your worried about it go with the 4.88s.
    Check out this if you haven't already.
    http://www.ttora.com/forum/showthread.php?t=56784
    Edit: after putting your numbers in, for 80 mph, 4.88s with be at 2700 rpm, 5.29s -2900 rpm.
    I would say 5.29s if your towing.
    VVVVVV As for 4.56s with 35s Don, thats just silly, no where near getting you back to stock gearing.
  12. Nov 25, 2011 at 6:00 AM
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    4:88s if youre going in the mud, otherwise 4:56
  13. Nov 25, 2011 at 10:32 AM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    i would say with an auto 4.88
    but try it stock once there is only a 500-600 rpm change going from 4.10 to 4.88
    if you take od off on interstate it would give you about same rpm change as 4.88's then you can decide if its too high rpm for you
    http://www.superlift.com/images/misc/gear-chart.gif
  14. Nov 26, 2011 at 5:51 AM
    duty
  15. Nov 26, 2011 at 5:54 AM
    duty
    i seen the code on the door it says BO3A so does that mean that its an 8" ring gear and has 4:10s in it now ??? in want to be sure its 2002 v6 with an automatic in in it trd model...............
  16. Nov 26, 2011 at 5:56 AM
    duty
    the tires are 315/75/18
  17. Nov 28, 2011 at 2:06 PM
    duty
  18. Nov 28, 2011 at 2:08 PM
    duty
    have another question talked to a 4x4 shop that does this work for over 20 years he said not to changed the gears cause the front rear will snap the ring gear with the gear change since the ratio will be changed the new ring gear and pion is smaller and with such bigger tires onm it the pion will snal since its smaller than stock ..........???????? input on this thought please
  19. Nov 29, 2011 at 7:18 AM
    quattrokiwi
    Bruce
    Nor Cal
    I would find another shop that knows what they are talking about, ie toyotas.
    Yes there is a small chance of that happening, I've never seen it. Just get good quality gears, like yukon or nitro.
    There are plenty of people running 5.29s with 35" tyres and no problems.
  20. Nov 29, 2011 at 4:27 PM
    350TacoZilla
    Hancock MD
    X2
    I ran 4.56 and 4.88's before and was very hard on the trucks, broke cv joints but never a ring gear
    also duty .. yes you should have 4.10 gears in your truck right now
