Gear down for 31 inch tires?
Discussion in 'Wheels & Tires' started by pherpher1985, Sep 21, 2008.
  1. Sep 21, 2008 at 6:59 AM
    pherpher1985
    pherpher1985 [OP] Member
    tulsa
    1998 Tacoma ex-cab SR5
    I have a 1998 tacoma extracab 2.7 4x4 with 31x10.50's. I was just wondering, since stock tire size was 225/75/15, has anyone tried gearing down when they went to 31's? I know that the larger size reduces RPM's and is a little extra weight to sling around and I was just wondering if I should try to do a gear swap. Thanks
  2. Sep 21, 2008 at 7:04 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Were those 225/75/15 factory? That calculates to a 28" tall tire. My 90 toyota pickup came factory with 30.6" tall tires. Either way unless you do some serious offroading you will be fine with your factory gear. Assuming it is a 3.73 or shorter.
  3. Sep 21, 2008 at 7:18 AM
    pherpher1985
    tulsa
    Ok I looked at my factory sticker and it tells me that I have an 8" 2 pinion open rear end with 3.58 gearing. Sounds a bit high to me. The sticker also says that the stock tire was indeed 225/75/15.
  4. Sep 21, 2008 at 7:24 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Well then if you really offroad alot, I doubt that you do seeing as how you have an open diff, and need the gear yes definately get new gears. Your setup now will translate to a 3.25 gearing. I'm surprised to see such a short tire on a 4x4. Being a 4x it makes gear swaping expensive. If you decide to go that route a 3.90 gear or the negibhorhood of will put you back close to factory. However if you are changing your gears and want a little more installing 4.10 gears will make your truck handle like it has 3.70.
  5. Sep 21, 2008 at 7:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you are going to re-gear, get 4.10's. That way, when you get new tires, you could even go with a 32" tall tire if you decided. I had 4.30's on my 2000 4x4 5 speed, and it was great! :)
  6. Sep 21, 2008 at 7:30 AM
    pherpher1985
    tulsa
    I mainly do highway driving and a lot of around town. I've just noticed that I lack power in 5th gear. If i get into 5th below 60 mph the truck shakes as if it is underpowered in that gear. Just trying to figure out if I've got the optimal gears.
  7. Sep 21, 2008 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With 31" tires, My truck was turning 2300 rpm @ 60 mph. If its has "shakes" at 60 in 5th gear, you may have another issue.
