Gear Fluid for Rear Diff (75w90/75w110)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by httuner, Mar 29, 2016.
  1. Mar 31, 2016 at 8:26 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    What did you have? I was big into isuzus before I bought the tacos. I loved every isuzu I drove. They were rock solid, just no aftermarket parts. Even on my trooper when I changed the fluids at 80k the t-case oil was clear, trans was dirty full of particles but I remember what a difference in made in shifting. It became very effortless.
    https://www.marlincrawler.com/tech/differential-break-and-care-information
    ECGS has a slightly different procedure, but it's pretty close in the sense that long distance driving shouldnt be done.
    http://eastcoastgearsupply.com/files/PDF Files/break-in-procedure.pdf
    httuner[OP] likes this.
  2. Apr 1, 2016 at 9:10 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    1993 Isuzu PUP four banger. I beat that fucker hard. The oddest thing was that the manual transmission had 30 weight motor oil not gear oil...
    Thanks for the links...
  3. Apr 1, 2016 at 9:18 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    If you're going to change it every 30k miles then any decent 75W90 or 80W90 GL5 gear oil will be fine.
    Lester Lugnut and httuner[OP] like this.
  4. Apr 1, 2016 at 9:30 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I miss my '95 Rodeo - V6 - was pushing 300K when I sold it. Had original engine and GM 4L30 transmission. Shifted as smooth as it did the day I bought it.
  5. Apr 1, 2016 at 11:29 AM
    Sep1911
    2016 Taco
    I was surprised too. Even the late stuff called for 30wt motor oil. My 2000 trooper was manual and had an air in transmission I believe it was an r series and it too was recommended to use 5w30. Of course I put in red line mtl
  6. Apr 1, 2016 at 4:55 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I ran severe gear in my 06 and at 205,000 she's still on the road trouble free. I towed with it often too, when changing fluids it still looked good.
    ABNFDC and httuner[OP] like this.
  7. Apr 1, 2016 at 5:03 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  8. Mar 20, 2019 at 4:47 AM
    psyWAR1988
    psyWAR1988 Well-Known Member
    2012 DCSB TRD Barcelona RED
    2012 DCSB 4x4 TRD Sport in Barcelona Red Suspension/Driveline Front – Icon LT 2.5 Coilovers Rear - Icon Progressive 3-leaf add a leaf with overload with Bilstein 5100s Icon Tubular UCAs with Delta Joints Toytec 3 degree axle shim OME FK29 CB drop kit Wheels/Tires/Armor Desert Rat Rattler Tracker II rims BFG A/T KO2s 275/70/17 U.S. Off-road Hidden Winch Front Bumper (powdercoated diamond flat black) Trail Gear Weld-on Sliders (painted Hammered Black Rustoleum) Mods TRD cat-back exhaust TRD Pro Grill install TRD Pro Headlights install ARE MX Camper Shell (plasti-dip black) Redline Tuning Hood Struts Relentless Tailgate all metal skin plate Relentless Off Road all-steel tailgate cap Total Chaos Bed Stiffeners Precision LED Interior Lights Birddawg Rear view mirror relocate w/ ram ball AJT Designs CNC Billet 6061-T6 Aluminum Tacoma short shift Knob (Anodized Black) AJT Designs Injection ABS Climate A/C Knobs (Black with Black Anodized Alum. screws) AJT Designs Injection TRD Key FOB case (Cement Gray with Red Anodized Alum. Screws) UNI Filter Mod Weathertech Floor Mats AVS window rain guards MagLite Mod 8 inch Mini Antenna mod Mob Armor Cell Phone mount OneTigris Tactical Molle Seat Back Panels with Molle Pouches (Cutters, Medical, Axe etc) De-badged To-Do (Have but not On yet) Entune Radio Bezel for radio, center console, 4x4 knob (awaiting shipping but purchased) OG Fabrications “Oh shit bar” Aluminum Overhead Molle Panel (awaiting delivery OG Fabrications Center Console Aluminum Molle Board Panel (awaiting delivery) ECG Bushing for Vibration Wheeler’s front superbump stops. Rear Diff Breather mod
    Dealer says they use 75w140 in the rear diff and 75w90 in the T case and front diff. I told them manual says 75w85 GL-5 for rear, they pretty much said w/e is clever.... so yea
  9. Mar 20, 2019 at 5:19 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Is it easy as removing the fill and drain plug. Reinstall drain plug, then fill till it starts to trickle out? I need to do this soon.
  10. Mar 20, 2019 at 5:23 AM
    psyWAR1988
    Yea sort of. First start with removing the fill plug FIRST. That way, if for some reason when you go to remove the the fill plug but you can’t bc it’s seized or w/e , you haven’t drained all your diff fluid yet and aren’t left unable to fill it.
    Remove fill plug
    Remove drain plug and drain.
    Flush if desired (recommended)
    Replace the washers on the plugs
    Install drain plug
    Fill with oil until no more can go in (this is indicated by oil starting to dribble out of the fill plug.
    Install fill plug
    Drive the bejesus out of your pretty tacoma beast.
  11. Mar 20, 2019 at 6:05 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    How are you flushing your rear axle?
    In all my years, I have never heard of this. Only thing I have heard of is refilling the axle, and doing another drain and fill in 50 or 100 miles.
  12. Mar 20, 2019 at 6:14 AM
    psyWAR1988
    Perhaps “flush” is misleading. It’s not a flush like a tranny, but similar (tranny is usually a power or running flush)
    Once drained, Simply keep adding clean gear oil through it (open drain) and allow it to continue to drain through as you add oil. When I start the job and I initially drain mine completely, I usually add/drain another clean quart through to ensure any shavings or grime get completely out. Then I install drain plug back in and add as normal.
  13. Mar 20, 2019 at 6:22 AM
    Scott B.
    Scott
    Georgia
    I see.
    Just to rinse out any remaining gunk.
  14. Mar 20, 2019 at 6:34 AM
    psyWAR1988
    Exactamundo. If I have been towing it hard or off-roading, I will not only do this, but also run 50-100 miles on new oil, and then change it again Lol. I drive hard and beat up the outside, but baby it in maintenance
  15. Mar 20, 2019 at 6:39 AM
    #35
    Scott B.
    Scott
    Georgia
    I change mine every 15,000 miles. Of course, I tow and off-road.
    My idea is it is easier to change things on Saturday afternoon in my garage, than at midnight, somewhere on the side of a trail, in the mud and rain...
  16. Mar 20, 2019 at 6:53 AM
    #36
    psyWAR1988
    Literally takes 1 minute to get t started draining, go grab a beer and watch the first half of football, add oil during half time (cuz the half time shows are garbage) and watch the last half knowing you accomplished something (at least had more beer) lol
