Gear grinds shifting from 1st to 2nd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Madbaumer, Mar 30, 2012.
  1. Mar 30, 2012 at 6:41 PM
    Madbaumer
    Madbaumer [OP] New Member
    12 toyota access cab
    I just purchased my first Taco. I love it. However, I am concerned about the grinding when shifting from 1st to 2nd. It doesnt always grind, and sometimes I have to shift very slowly. Sometmes the gind is very slight. Should I be concerned or is this normal? Any help would be appreciated. Thanks.
    P.S. It is a 2012 and only has 500 miles on it.
  2. Mar 30, 2012 at 6:49 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Pretty normal on the 4 banger 5 speeds. Two things that have helped others are the short shifter kit from URD and using Redline MT-90 gear lube. I've got the short shifter and it is a big improvement over stock, but a slight grind can sometimes happen if my timing isn't right.
  3. Mar 30, 2012 at 9:23 PM
    GrEeN WeEnY
    GrEeN WeEnY Well-Known Member
    Aaron
    Behind Enemy Lines, OR
    2023 TRD Sport DCLB, my sixth Tacoma
    Have you tried pushing in the clutch?
    j/k :D Mine will do it too, just remember it's a truck transmission, it;s heavy duty and just needs a little more sychro time between holes
  4. Mar 31, 2012 at 8:07 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I had this issue on my last Tacoma. Running Redline MT-90 helped a little, but didn't eliminate it.
