Gear Head's Solid Axle Turbo Tacoma Build
Discussion in '1st Gen. Builds (1995-2004)' started by Gear Head, Jan 13, 2015.
  1. Jan 7, 2016 at 6:46 PM
    #921
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    :worthless:
    *Insert video in place of pics*
    Gear Head[OP] likes this.
  2. Jan 7, 2016 at 6:54 PM
    #922
    Gear Head
    Gear Head [OP] Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Haha I will try to get one soon. It sounds wicked
  3. Jan 7, 2016 at 6:55 PM
    #923
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Oh and a huge thanks to @Mothman and his buddies that came up to help even though it's ended being something stupid
    ajohnson likes this.
  4. Jan 7, 2016 at 6:55 PM
    #924
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Let's see a drift vid
  5. Jan 7, 2016 at 6:55 PM
    #925
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Braaap
  6. Jan 8, 2016 at 3:29 AM
    #926
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
  7. Jan 8, 2016 at 6:59 AM
    #927
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    @MadTaco461 what is your afr at idle and regular driving?
  8. Jan 8, 2016 at 7:28 AM
    #928
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Mine sways from 14.5 to 15 at idle. Driving stays like that. When I jump on the throttle it gets lean and will rich back up after a second. I think my o2 is getting old. Open loop part throttle it will jump in the 10s. Open loop wot in the low to mid 11
  9. Jan 8, 2016 at 7:42 AM
    #929
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    Trying to get that boost dialed in?
  10. Jan 8, 2016 at 8:08 AM
    #930
    ckeene9
    Chesterfield, VA
    See Build Thread
    Moar boosts!
    ajohnson and Mothman like this.
  11. Jan 8, 2016 at 9:26 AM
    #931
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Nice, that's about where mine was. Every now and then it would show full rich at idle though. If it's not raining when I get off I'm going to get it out and drive it around and see what it looks like.
    Also my bov was only opening after revving to WOT. This mean the spring is too stiff? Could I just cut it down some? I'm not sure what spring rate is in it. It's a knockoff and the springs weren't labelled
    Mothman likes this.
  12. Jan 8, 2016 at 2:34 PM
    #932
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Gauges are in! Just have to tidy up some wiring and I might be able to take it out for the first spin
  13. Jan 8, 2016 at 3:31 PM
    #933
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Just drove it... Holy shit
  14. Jan 8, 2016 at 3:57 PM
    #934
    ajohnson
    Andy
    Charlotte, NC
    Much brap?
  15. Jan 8, 2016 at 4:00 PM
    #935
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Where's the video, I can't afford this stuff so I have to live through you.... I'm dying right now!
    Gear Head[OP] and ajohnson like this.
  16. Jan 8, 2016 at 4:37 PM
    #936
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Too much braap lol
    Haha can't video while driving stick! I'll work on it... @Mothman the people want a video
  17. Jan 8, 2016 at 5:51 PM
    #937
    Mothman
    Advance
    single cab
    The one I took looks like shit..
  18. Jan 8, 2016 at 5:58 PM
    #938
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    I meant come back and take a real one haha. We can piss off my neighbors by making some pulls in the street
    Mothman[QUOTED] likes this.
  19. Jan 8, 2016 at 6:02 PM
    #939
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    @MadTaco461 any reason it would go full lean if I just bump the gas? It also goes full lean everytime I clutch in or let off the gas. Boost controller is 100% closed and I'm seeing 6-7psi and 12-13 AFR under load. If I go from a stop or slight roll straight to WOT it gets real lean 16-17 AFR and doesn't want to richen back up. If I get my rpm's up by downshifting before going WOT it doesn't lean out and stays at 12-13.
    All I've got for exhaust is just the downpipe. In the instructions it said to mount the wideband 36" away from the turbo, mine is 29" and is right where the wastegate converges with the turbo downpipe. Also the downpipe ends about 1.5" after the wideband, think it could be picking up outside air?
    @Mc1337sauce I'd also like to hear your opinion on this as well
  20. Jan 10, 2016 at 4:49 PM
    #940
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    @Mothman came over for a bit and we managed to get a quick vid together. Just a little cruising around, still showing a little lean at WOT from time to time and showing lean and wanting to die when clutching in to stop. Overall it's running pretty good though
    la0d0g, Scenekyd, Speedytech7 and 6 others like this.
